Question about Cameras
Battery stopper fell out (2 pieces of plastic), not sure how to reinsert..
5 Suggested Answers
  • 566 Answers
SOURCE: Printer fell...extra part?
LOL! That would be the little cleaning stick, used to clean the printer head, which is lodged in the lid inside
Posted on Jul 19, 2009
Buland Khan
  • 297 Answers
SOURCE: I replaced my battery and a plastic/rubber piece
u need to refix that rubber.......
Posted on Nov 19, 2009
  • 176 Answers
SOURCE: a spring and a plastic piece came apart from the
We need to know what size pot you have. bobbyone
Posted on Aug 11, 2010
freetek
  • 5568 Answers
SOURCE: The pop up drain connection
A similar problem required the removal of the popup assembly and a search through several hardware stores, large and small before I tried a local 'DoItBest' dealer. They have a kit under their name that has two different popup rods and associated hardware and one of them works perfectly. I think it was under $6 US.
Posted on Mar 09, 2011
Clogged drain on moen bathroom sink
There should be a stopper valve on the sink's downspout (the first section of drain pipe). You SHOULD be able to loosen the nut holding the stopper valve's lever inside the pipe. Once you remove that nut, you can pull the lever out - that releases the stopper inside the sink, so you should start with the stopper OPEN, and hold it open with a chopstick or pencil or other tool when you remove that lever.
The lever and the bottom of the stopper itself will be wrapped with masses of hair. That's normal. Clean it up and reinsert it, put the nut back on & snug it down, then readjust the stopper.
If that's not enough, you may need to open the trap (the gooseneck-shaped piece of drain pipe under the sink) to clean it out.
Apr 05, 2014 | Moen Tub Drain Assembly, Lift-N-Drain -...
Heard some rattling in the steering wheel took off the cover where the horn and cruis control is and a big metal piece with rubber stoppers fell out. what is it?
hi,
this is either the airbag or the vibration dampener. Im not sure exactly when they changed over to airbag, I think it was that year so. if that metal piece has no wires going into it then its just a vibration dampener, it just lessens road noise coming from the steering system. if its the airbag assembly be careful with that. undo the battery and let it sit for a half hour then study that box and come up with some sort of shim(styrofoam?) to keep it from rattling around in there. dont shim on top of the box if its an airbag, shim the sides somehow. use this tip at your own risk..
jm
Apr 14, 2011 | 1992 Ford Explorer
Dropped LG VX 5500 in water. Screen no longer lights up. Can receive and make calls. But cannot see screen.
When it fell in water, it entered the screen and damaged it that is why the screen is not lighting up.
The solution to that is to replace the screen, to get to the screen follow the process below:
Turn your phone over so the back is facing you. Remove the battery. Now remove the 4 screws,
These screws may be covered by some plastic covers. These simply peel off.
Next remove the 2 rubber stoppers & screws above the main screen,
Now remove the two screws below the main screen,
Run a fingernail along the join of the housing to unclip it,
The top of the phone should now be in two pieces,
Unclip the ribbon. This attaches like a plug and socket,
Now detach the top of the phone from the bottom. This involves a little force as it is a tight fit,
Double back the ribbon on itself so it is away from the LCD screen,
Use the screwdriver to lever the old screen out,
Replace the old screen with new and reverse the whole procedure for reassembly.
Take care and good luck
Oct 16, 2010 | LG VX5500 Cell Phone
I stopper on a garden tub with a delta faucet. The stopper pushes down and locks to stop water. It takes a few tries pushing it down to get it to stop and hold water. What is the best way to fix it or...
In my part of the country, the type of drain you refer to is commonly called a tip-toe drain because you can use your toes to open and close the drain. Their locking ability diminishes over time and use, and eventually won't lock at all. They cannot be repaired, and must be replaced. You must remove the one you have to get the correct replacement because there are variations in the thread diameter at the bottom of the stopper.
You will need to use pliers large enough to grab around the white plastic underneath the top of the stopper that appears to disappear into the drain. Once you have the white plastic shaft secured with pliers, grab the very top (the chrome part) and twist it counterclockwise to remove it. Once that is off you will see a round piece of brass that looks like the top of a very large screw. IT IS! Using a stantard screw driver, again turn counterclockwise to finish removing the rest of the stopper.
A good hardware store should have a replacement for you. Be sure to match up the thread diameter at the bottom of the stopper.
To reinstall, you can reverse the steps or simply thread the complete assembly into place.
Aug 07, 2010 | Home
Bathroom sink needs new drain, leaks under counter
Is it a new sink? Most of the time if it's new you'll have to get more pvc pipe because the new tail piece that comes with the new faucets usually is either longer than before or shorter. Yes you can get another tail piece or you may be able to by a longer pvc piece to to hook up the the metal tail piece. Make sure you have the plastic seals inside the pipe where they attach together or it will leak. Once you have it all together close your stopper and fill the sink with water and then pull the sink stopper and watch for leaks if it dont leak then it wont leak.
Dec 30, 2009 | American Standard Cambridge 5' Americast...
hmm..well..that may not be your only issue..if the printer fell to the floor.
Oct 13, 2008 | Dymo LetraTag QX50 Thermal Label Printer
Cameras Logo
23 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
