Question about KLH Audio Players & Recorders
Model KLH KL-2400 Reciever keeps popping fuses. Resistor in power input ckt is color coded YellowVioletYellow Gold for 470 Ohms 5% Tol. However this resistor reads 370 Ohms. Resistor needs replacement? Also there is a short between both neg. Speaker outputs. Are they sharing common? Is this normal? Please help.
  • 4,234 Answers
First of all a resistor color coding of Yel-Vio-Yel is 470Kohms not 470ohms. You are probably reading some stray voltage in the circuit. Yes, both NEG terminals of the speakers are common. Usually a receiver that blows the main fuse has a power suplpy problem. Check the recifier diodes for shorts. Other than that, the output transistors may be shorted.
Check those out and post the results.
Dan
Posted on Nov 17, 2009
What Is The Value Of R2 On The Freeplay FPR2S Circuit Board?
The "Resistor Color Code is explained very well at - - http://www.digikey.com/en/resources/conversion-calculators/conversion-calculator-resistor-color-code-4-band
Your question intrieged me so I opened up my own FPR2S and took a peep. I am getting old and my eyesight is quite poor now but I believe the color bands are Orange, Orange; Yellow; Gold which converts to:3 3 0000 @ 5% or, 330,000 Ohms @ 5%
I desoldered the R and measured it - - It is 330,000 Ohms
Feb 20, 2014 | Freeplay Energy BayGen AM/FM/SW Radio
Samsung home-theater model no# HT-E330K, power supply resistor RA805 completely burnt can't see the value of the resistor. Pls help with the value of the resistor
This may sound like a lazy answer but without a schematic, its going to be tough. Perhaps you know someone...or maybe there is someone here who has the same unit who wouldn't mind opening it up to get the value. Good luck.
Oct 08, 2013 | Audio Players & Recorders
I need to know the value of the Resistor "R1" in
Let us use a bit of logic to resolve this... I have an Axiom but it would be a lot of screws to take out to get to the part... so let us think about this. The resistor value starts with a "1" and we know it is 5% tolerance (gold). we know the resistor burnt up with likely 5 volts on it... Value could be 1000 ohms, however the voltages present (12 volts max) would NOT have burned up a resistor of 1000 ohms. The USB area is mostly 5 volts and across 100 ohms is only a quarter watt... not enough to really burn up a resistor... First thing is to MEASURE that the resistor s open... in spite of being burned, it MAY still be OK... these resistors now usually either open or remain close to their value. The resistor ALSO may be a fusible resistor intended to act as a fuse... Is the resistor open or not? is it near a resistance with a "1" as the first digit? If it is not open I suspect it is not all of the problem. In that case, look for a burned circuit trace on the board. If it is open, then MEASURE the voltage across the resistor with the power applied. If you find 5 volts, then it MIGHT be a 10 ohm used to limit the USB current to 500ma. Get back to me with your findings... I have unraveled many of these things...
Jul 12, 2011 | Music
I have two crack green resistors colors are red, brown silver gold. what value is this. Its on the power board of a 24 dell monitor
The value = 0.21 ohms 5% tolerance
Use this WEB site to work out the value of the resistor.
http://www.smpspowersupply.com/resistor/resistorcolorcode.html
This WEB site gives you the color code values for resistors.
http://www.google.com.au/images?hl=en&q=resistor+colour+code&um=1&ie=UTF-8&source=univ&sa=X&ei=YHRsTfSsK5C2vQPA353UBA&ved=0CCsQsAQ&biw=1024&bih=416
Mar 01, 2011 | Computers & Internet
Model KLH KL-2400 Reciever keeps popping fuses. Resistor in power input ckt is color coded YellowVioletYellow Gold for 470 Ohms 5% Tol. However this resistor reads 370 Ohms. Resistor needs replacement?...
470.000 ohms not 470 ohms 470k ohms at 5% tol. either the main p.s. diodes are shorted or the output and driver transtors are shorted causeing the fuse to blow....
Nov 17, 2009 | KLH KL2400 Tuner
Add su bwoofer to KLH 200
the subwoofer i have, a polk, connects directly to the right and left speaker lines of the klh2400.
i then connect my stereo left and stereo right speakers to the subwoofer.
essentially, the subwoofer becomes a middle station between my speakers.
make sense?
Jun 06, 2009 | KLH KL2400 Tuner
Blowin resistor on my Acoustic Research S112PS
When I put an ohm-meter across it, I get 505-ohms. The color code looks like maybe green, dark brown, brown? Mine is discolored too. Green, brown, brown would be 510ohms. . .so that must be it. The tolerance band is gold, so that's +/-5% so that would explain the 5 ohm variance.
Feb 12, 2009 | Acoustic Research S112PS Subwoofer
NEED TO KNOW THE OHMS VALUE FOR RESISTOR ON PEANUT 8685
I have the same problem, but it is open.  The color code Brown - Green - Brown - Gold.  If it is a resistor, the value must be 150 ohms +/- 5%.  To confirm the value, I open the working trimmer and remove one leg from the circuit and measure resistance.  The meter reads only 4 ohms.  Therefore, I think it is an inductor (150uH +/-5%), not resistor.
Jan 27, 2009 | Wahl 8685 Hair Trimmer
273 people viewed this question
Top KLH Audio Players & Recorders Experts
 Grubhead
Grubhead
Michael Edwards
Michael Edwards
Level 1 Expert
Are you a KLH Audio Player and Recorder Expert? Answer questions, earn points and help others
