What is the difference between 128bit encryption and 256bit encryption
  • sumitnxt Nov 17, 2009
    wow ... excellent reply .. thanks a lot
  • 555 Answers
First, let's review the basic:
Is important to understand what a bit is. A bit is a single value and can be either 0 or 1. ( 0 =OFF, 1=ON)
8 Bits are something like this: 10001011. Your computer have a 64-bit processor, so it can process numbers like: 10010110 11001111 0001010 11010000 10011110 111100111 01111010 11011000 Quite long number, isnt't it?
Encryption is the process of securing information that is sent over the internet using a code that scrambles (encrypts) and de-scrambles (decrypts) the data, typically based on prime numbers and called a "key". The length of the key will be either 128 bit or 256 bit. A 256 bit encryption is stronger than a 128 bit key encryption key, because it doubles the number of bits.
Just to give you an idea, here are 128 bits:
10010110 11001111 0001010 11010000 10011110 111100111 01111010 11011000 10010110 11001111 0001010 11010000 10011110 111100111 01111010 11011000
Now, here is a 256 bits packet:
10010110 11001111 0001010 11010000 10011110 111100111 01111010 11011000 10010110 11001111 0001010 11010000 10011110 111100111 01111010 11011000 10010110 11001111 0001010 11010000 10011110 111100111 01111010 11011000 10010110 11001111 0001010 11010000 10011110 111100111 01111010 11011000
So 128 bits long, mathematically means that there are 2e128 possible combinations, or about 3.4 x 10e38. This is an awful lot of combinations, which is what makes it nearly impossible to crack the security encryption. However, as computers get faster the numbers of bits required to ensure secure encryptions needs to be raised
Currently, the strongest level of protection you can get in an SSL certificate is 256-bit, which equates to 2e256 combinations or about 1.5 x10e77 possible combinations. As you can see, even though it is only twice the number of bits, the encryption is exponentially stronger.
In plain English; 128 bits key encryption is is a "door key" with 128 slots. You need to have the exact combination for all 128 slots. 256 bits makes more difficult to find the combination.
Posted on Nov 17, 2009
How to remove the hdd from the imation h100
Use a hammer to crack-open the case.
Not too much force -- just enough to crack it.
Then, you can use tin-snips to cut-away the case.
Jan 14, 2014 | Imation Defender H100 320 Gb External Usb...
Tip
How to Configure your Linksys router with wireless security
Launch your Internet Explorer, Netscape or your Mozilla.
On the Address, Search or URL, type: http://192.168.1.1, then hit Enter/Return. A login screen will appear. Type admin for the password and leave the username blank or empty then hit “OK”.
Note: If it doesn’t take admin as the password you might have changed it when you have ran the RUN ME FIRST CD that came with the router so try other passwords.
If you cannot remember the password, I regret to tell you but, you have to reset the router and, reconfigure it again. Next time, remember the password to avoid unnecessary reset and reconfiguration.
To reset the router to factory default
1] Press and hold the reset button for 30 sec., after that
2] Unplug the power keep holding down the reset button for another 30 sec.
3] Then, plug back the power keep holding down the reset button for 30sec., after that
4] Release the reset button.
Note: Configuring WEP in the router varies depending on the model number and firmware version of your Linksys Router.
Cisco Interface (If your Setup page has a Cisco Logo)
Go to Wireless Tab > Wireless Security > Click the drop down arrow then select WEP:
Regular Linksys Router Interface (If your Setup page has a no Cisco Logo)
Under Setup > Click WEP Key Settings or Edit WEP Key Settings
Using passphrase 64bit
Encryption LEVEL 64bit > type a passphrase > click Generate > copy key1 on a piece of paper (10hex character). Then hit Apply or Save Settings.
For manual key entry of 64bit encryption:
Encryption LEVEL: 64bit > Under Key 1 type a 10 digit character from A-F and 0-9.
(e.g.: A0B3F58C9E, 0123456789, ABCDEFABCD). Then hit Apply or Save Settings.
Using passphrase 128bit
Encryption LEVEL128bit > type a passphrase > click Generate > copy key1 on a piece of paper (26hex character). Then hit Apply or Save Settings.
For manual key entry of 128bit encryption:
Encryption LEVEL: 128bit > Under Key 1 type a 26 digit character from A-F and 0-9.
(e.g.:0123456789ABCDEF9874561230, 012345678901234567890123456, ABCDEFABCDABCDEFABCDABCDEF).
If you want better security for Vista computers, you may want to select WPA personal (WPA-PSK) under security > set the Algorithm to TKIP and type your personal security code (any code you want, any characters)
on Jan 06, 2010 | Computers & Internet
Can't connect ae1000 to a WEP encrypted bg access point
To connect to a WEP or any encrypted site, you will need to know and supply to your network connection:
  • the SSID (especially if the ID is not being broadcast as an additional safety feature).
  • the exact Encryption Key (normally entered in Hex format).
  • You need to exactly specify the security type (Open, Shared, WPA or WPA2) used for your wireless WEP connection as define on the access point wireless modem/router.
Hope it helps.
Sep 27, 2010 | Linksys AE1000 IEEE 80211abg IEEE80211n...
Cant connect my ps3 psp go to the internet using
Check to see if your router has backwards compatibility to wireless G because the N router uses 256bit encryption coding while the G uses 128 bit encoding. PS3,and PSP use the 128 encryption coding also. If the router does not support 128 bit encoding you will never connect with it.
Nov 22, 2009 | Sony Playstation 3 (PS3) Console
What's the meaning of 64bit, 128bit, or 256bit on video cards and which one that suit asus p5vd2-x?
go to asus homepepage and type in your model number and it will bring up what your computer is and what it will handle video card wise.
Sep 20, 2009 | ASUS P5VD2-MX Motherboard
Encryption of Di-624
You can download the manual for this router (revision A1) from here.
Look at page 13 of the manual, which describes how to set up your wireless network.
Note that you only have 128bit encryption, not 256bit!
To see the differences (especially in characters and the number of characters) and to generate a good key, have a look at this page.
If you have any more questions, just come back here and leave a comment - I'm happy to help!
Mar 30, 2009 | D-Link AirPlus Xtreme G DI-624 Wireless...
Lock folder on External HDD
The best way is to use an encryption software. This will encrypt the folder and lock it via a password no matter what user/system tries to access it. WinRAR, and WinZIP also offers some encryption techniques. The best I've used was actually an updated windows folder encryption program.
If you're running a higher version of windows vista (business or ultimate) you could use the software that comes with windows to encrypt the folders. Though, I'd suggest looking around at different applications on the internet. www.google.com is the best place to start. If you have any questions on certain types of applications I can help with that later on. However, I'd suggest at least a 128bit encryption application as the encryption is very difficult to break. :)
Hope this helps bud!
Sep 11, 2008 | Computers & Internet
No display
have you tried different powersupply? make sure your powersupply has enough wattage and amps to supply your pc's components.
Jun 10, 2008 | Intel Motherboard
UBCD396T SCANNER
now i can tell you what there using for there audio encryption but thats as far as im going to with this the rest you will have to find out there is laws on these digital signals that can get you into trouble
there using skye nec encryption 256bit
May 11, 2008 | Radio Communications
Computers & Internet Logo
27 people viewed this question
David Payne
David Payne
