I would replace the sparkplugs and wires first which is more than likely the problem.The only thing left is the injector after that.And i would not think that you would have to take the intake off just to change plugs.Try to get to them from under neath
new exhaust is to much for computer to figure out, since its flowing a lot more air , engine management cannot figure out fuel ratio hence the o2 sensor and knock sensor. u will have to install a performance chip or have computer re figured for new settings.
Did you make sure you put the sparkplug wires back in the right holes?
If so it could be a compression problem. If you have the tool you can check it yourself by removeing the sparkplug one at a time and and put the gage in the empty sparkplug hole. Have some one turn over the motor and see if your compression is right. Do this to all the cylenders to be sure. If you dont have the tool, take it to a mechanic and have it checked. He can tell what it is and what it is suppose to be. Not knowing what engine you have, I can not tell you what compression to look for. If your compression is low, the rings are gone.
Don't have a picture but I can tell you. They are located on the back end of the engine, pointing towards the windsheild. Mitsubishi made it hard for us. There are no wires, instead there a coils that are diamond shaped on top. Unscrew the one screw and just pull it straight out. You have to remove the top plastic silencer that is in line of your intake in order to do any of this.
i was wondering if you made sure that the gap on the plugs was correct for your vehicle it is different from car to car. I had that same problem of course mine was doing that right off the bat. so you never know. but again another possibility to check.
What spark plug type are you using? It makes a difference on brand types and if your using split fire platinum or standard plugs. Let me know most of the time it's .40 thousands.
get on the net to find out more,NGK, Nippondenso,or Bosch will be fine usually higher price better longer lasting plug,i dont think theres any major advantage
You dont need to take off the intake manifold but the cold air intakes these unclip grab the convaluted tubing and pull it straight back out of the aircleaner then lift it up and un clip the bottom then pullit out of the intake snorkle
