Question about Refrigerators
Dw64 where is the thermostat located?
Dw
64 where is the thermostat located? beverage air dw64 can't find location of thermostat. Please help
  • 460 Answers
The thermostat is the knob you turn to regulate the temp..
Posted on Nov 17, 2009
Beverage-air dw series. How can I check the temp control? The unit freezes everything and it seems like compressor runs all the time. I am pretty certain the refrigerant level is ok.
Fridge freezing up- and no fan or air circulation:
AT TIMES The fan usually stops working AND CAN MAKE FUNNY NOISES AS WELL due to ice obstruction when the defrost terminator has gone out and u get ice build up? u can check the terminator with a multi meter for continuity but do not check at room temperature. stick the terminator in cup of ice water for 20 minutes then check it for continuity, should be closed when cold and open at room temperature.
May also need to check the defrost timer, The defrost timer is usually found behind the front grill "toe kick" of the refrigerator. Or in the fridge compartment near middle top section.
u can get by and test manually by placing a small screw driver into the tiny slot or hole underneath the timer and turn slowly clockwise till u hear 1 click. this will engage ur defrost cycle in about 15 minutes u should be able to come back and feel the heat in freezer as it melts the ice providing ur terminator is not bad?
Another way to test it is with a multi meter. Remove timer it from fridge and you will see 4 prongs numbered 2,1,4,3 in that order. Place ur meter prong on prong 1 & 3 (if your fridge has a capacitor wired in series with the windings, then u check for micro fares rather than OHMS) If u cannot confirm this test, still try the next.
Take ur meter prong and connect to prong 1 & 4, it should read resistance or ohms ( closed) now remove prongs and place on prong 1 & 2, this should now read infinity or open (no ohms) now take a small screwdriver place it in the tiny hole or slot under the timer. Turn it clockwise slowly till u hear 1 click. Now ur 1& 2 should read closed ( showing ohms or resistance) now place meter prongs on 1 & 4 and you it should now show open ( or no resistance - no ohms) this is how u know ur timer is good, Remember when testing for ohms ADJUST meter to use a high ohms rating in the thousands as the resistance is very high in OHMS. And adjusting to low ohms rating may give a false reading or not show the proper resistance..
Another item to check with a meter is the heating element itself. Located under the evaporator coils. It should show continuity or resistance OHMS WHEN TESTED AT BOTH ENDS OF THE PRONGS .
Lastly check the cold control thermostat with a meter for both OHMS and volts ( VOLTS is a live test with fridge plugged in so be careful) It must show 110 volts. An open or thermostat that reads infinity will not allow the proper cooling and defrosting cycles to operate and may in fact stop anything from happening as if there is no power to the unit?
ALSO CHECK THE AIR FLOW VENT SYSTEM and THERMISTORS At times it can get stuck to far closed or open. Some units feature a digital electric adjusting vent system while others are manually set. Check for any ice build up or other obstruction in the vent damper, see if u can manually open or close it. Some times when u have the settings set to the highest it closes off one area while allowing to much cold air flow to the other area!
THERMISTORS in the freezer and fridge section for continuity OHMS and for amount of OHMS current being put out. In most models around 1300 ( give or take 150 ohms) ohms is required
God is so good: so this is why I give free advice so please thank him not me.
Oct 05, 2013 | Beverage-Air DW64 Beverage Cooler...
Beverage-air DW freezes
Try turning thermostat knob all the way to left or counter clockwise. This should shut the compressor off. If the compressor continues to run the thermostat is stuck closed & bad. If the compressor remains off with thermostat turned all the way to the left try turning it slightly to the right (warmest setting). See if it stops freezing. If it continues to freeze set at warmest setting replace the thermostat. Try pricing a thermostat out at Refrigeration Hardware. Link attached. Refrigeration Hardware Supply
Oct 05, 2013 | Beverage Air Refrigeration Deep Well...
I'm trying to find out the age of my Beverage Air BM23 Kegerator. It's serial number is #823620I.
Scott,
Your Beverage Air Kegerator model BM23 / serial: 823620I - that serial didn't bring anything up when I called the manufacturer but based on the first 2 digits of the serial and the roman numeral 1 at the end of it - it would appear that your unit was manufactured in 1982 (If that number was on a metal tag then it defiantly was 1982).
We specialize in cooler gaskets and can help you locate the gasket part your unit needs. We also are able to get many other hardware and accessory parts for Beverage Air units and other manufacturers. Let us know if we can help.
Matt at coolergaskets.com
orders@coolergaskets.com
855-288-2259
Aug 25, 2013 | Beverage-Air BM23
My beverage air MT 12 works but it turn on and off every 5 minutes
for cooling or heating is similar in the same basic funtion they need a thermostat for on and off cycles , don't know how it is integrated in your refrigerator but try to trouble shoot that sector first ,maybe locating the thermostat, see if the manual has spec for readings with a multimeter if not might try to research values on the net and tested first , see if it helps good luck hope you can fix it
Feb 23, 2012 | Carrier Beverage Air® Marketeer® MT12-1-B...
Won't get cold one of the copper tubes has a hole on the tip and air is coming out is that right
Hello Ramrecycling,
I understand that you are having a problem with your commercial beverage cooler. If I understand right that one of the refrigerant lines have a hole and the refrigerant is escaping from the unit. This will cause the unit not to get cold as the refrigerant is what produces the cold temperature when the fan blows are over the coils.
I am sorry to inform you that this is not a DIY project as it requires many special tools, vacuum pump (recovery unit), refrigerant gauges, scale, and more items that the common DIY does not own or wish to purchase at a costly price.
I would check with local HVAC contractors and tell them that you have already located the leak in the system and what the cost of patching and recharging would be. Then I would look at how economical it would be to fix or just replace the unit.
Thank you for choosing FIxYa.com
Justin
Mar 29, 2011 | Beverage-Air DW64 Beverage Cooler...
Head pressure high; suction pressure low. Unit not cooling
Good day,
It's a restriction.
It could be in the liquid line dryer, cap tube as well as the condenser. If it's a R134A system, it's a common problem.
In either case, the repairs can become extensive, with the factory when under warranty, authorizing, replacing the dryer, cap tube,
condenser, and many times the compressor.
Feb 03, 2010 | Beverage-Air DW64 Beverage Cooler...
Have commercial beverage air kegerator that keeps tripping fuses when plugged in, what's wrong
There is 2 kind of compressor location on those beer coolers. I have video of both. Hope that helps.
Oct 25, 2009 | Beverage-Air Kegerator - Beer Keg Cooler...
Hello I am having a problem with my Beverage Air UCF48A Frezzer and was hoping you can help? The problem is this. When I first start the unit it works fine and gets cold fast but then the next day or so it...
You should check the defrost timer, it is located in the back, probably on the left. The timer can stick. Next time your unit is hot inside, remove the back and turn the defrost timer clockwise (there is a little knob that clicks when you turn it) see if the unit comes on then. If it does you will need to replace this timer. If not you may have a thermostat problem or possibly a refrigeration problem. The part # for the timer is 502-171A. The part # for thermostat, if needed, is 502-111A check on www.beverage-air.com to see who your local parts supplier is.
Mar 27, 2009 | Carrier Beverage-Air Undercounter Freezer...
Looking for age on Beverage Air Horizontal Bottle Cooler
Call Beverage-Air and provide both model and serial # to the parts department and they should be able to identify the year the unit was manufactured - 800-845-9800
Matt - coolergaskets.com
Dec 09, 2008 | Beverage-Air Beverage Air DW49-S...
Refrigerators Logo
157 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
