Question about Kenmore HE2 Plus Front Load Washer
The machine doesn't drain 100% of the water out. You can move the tub and hear the water sloshing around in the machine bottom and the moisture is now starting to form mold on the front seal
  • 106 Answers
All the water does not drain. The front tub has ballance ring with water sealed in it to off set off ballance loads. The sump hose on the pumpwill also hold water. You can clean your pumps clean out trap to make sure the pump is working good. Also a drain hose higher than 6 ft off floor will cause pump not to drain all water. Front loaders all have a mold problem. no air gets in when your done washing because you close the door. If you dont use bleach and hot water washes it makes matters worse. Fabric softner is even worse.
You need to clean your washer with bleach in the front seal by hand some times.
Its the price you pay for saving water.
Posted on Nov 17, 2009
Kenmore 2600 TOP LOADER smells like Mildew. I can hear water sloshing around under drum. Is that Normal?
The drain on all washers have this issue. Unless the drain hose runs down hill, when the pump stops, water runs back into the machine that was in the hose but was not drained.
Feb 17, 2014 | Kenmore Washing Machines
There is water left under the tub after the wash is over. When I move the tub I can hear the water sloshing. How can I get rid of the water. It makes my towels smell like mildew.
If it is draining down and spinning the clothes dry then all of the water is draining out. There is only about a 1/2 in space under the tub. There is a balance ring around the top of the tube that holds water. That may be the sound you are hearing? Try washing a load without anything in it on hot and use a box of baking soda. See if that will help with the smell. My washer leaves a mildew smell sometimes. I started running an extra rinse cycle on it. And that helped. I think it was my water.
May 28, 2010 | General Electric WCSR2090D Top Load Washer
Is some water in the tub of a top loading washer normal?
It is normal to have residual water in the drain lines and pump following a wash cycle. This is the low point of the drain cycle and gravity will ALWAYS cause some water to be there. As long as the water is not visible in the spin basket, you have nothing to worry about.
Some model washers also have a balance ring around the perimeter on top of the wash tub that is filled with fluid. This acts as a stabilizer to help keep the washer balanced during the spin cycle. If you have any questions, please post back and let me know. I hope this is helpful to you.
Apr 21, 2010 | Whirlpool WTW5200S Top Load Washer
WHEN WASH IS COMPLETE, WHEN YOU SPIN THE TUB BY HAND YOU CAN HEAR WATER SLASHING.
The pump cannot completely drain all the water out of washers. There will be some water left in the bottom of the tub that you can't see but here slosh around if you move the basket. If your clothes are not wet, this is probably normal.
Jan 24, 2010 | Maytag Neptune MAH5500B Front Load Washer
Why won't the washer drain? Pump appears to be
if this issue is because you hear water in the machine when the tub spins......
thats normal, its called the balance ring
centrifical force, pushes the water in the lid, outward helping to use the sling weight, as a counter balance
its 100 percent normal to hear sloshing when turning the tub by hand
Oct 13, 2009 | Maytag Neptune MAH5500B Front Load Washer
The water will not drain out of the wash tub
The water drains out of the washing machine but the other day when I moved the washer I noticed that I could feel water sloshing around in the bottom of the drum but nothing is leaking on the floor.
Mar 21, 2009 | Kenmore Washing Machines
Need to drain the tub before moving
It should all be drained out of there except a little in the hose. The sloshing sound you hear in there is not old water or stored up water. It is a liquid in a balancing ring that is sealed shut but it sounds like the water is in the tub. The best way to get all the water out is to take a wet vac and **** out the water from the drain hose. Just put you hand around the 2 hoses to kind of seal it and lay it on the floor. Nothing more is really needed to move it. Just don't be too wild moving it around lol. Front load machines are usually very heavy becuase they have cement or heavy pieces to keep the basket from moving around too much in a high speed spin. Good luck
Jan 24, 2009 | Maytag Neptune MAH5500B Front Load Washer
Washer won't drain completely
water sond when tub is spun by hand is normal. there will always be wa terinside machine betwen tubs, maytag even uses a waterfilled tub ring for counter balance, totlly normal to hear. as far as mildew smells, use www.affresh.com
Apr 12, 2008 | Maytag Neptune MAH5500B Front Load Washer
Kenmore HE2 Plus Front Load Washer Logo
310 people viewed this question
Sal DeAngelo
fordexpert
Mike Carew
