Question about Creative Labs ZEN V Plus MP3 Player
Forgot password i have an creative zen v plus mp3 player and i forgot my password on the restrict volume setting. please help. thanks, fc
  • needshelp805 Jan 24, 2008
    when in recovery mode to reset my password cleanup does not do anything for my creative zen v plus
  • Elmo888 Nov 14, 2008
    i put a password on my zen v restricted volume and didnt realize that the volume was set to 4 and now i forget my passwords so i cant undo it and i cant here anything.
Push and hold the power button and at the same time prss the play button....a system recovery window eill pop up and select the first optiom "clean up" then turn it off and on again and its done!
:D
Posted on Feb 07, 2008
    President:
  • 4,402 Answers
Usually its 0000 or depending how many numbers. all zeros. just do a clean up. insert pin in reset hole while holding down power button, then let go, select clean up, let it sit and do its business, then when done, reboot
Posted on Jan 21, 2008
  • xhanewek09
    xhanewek09 Oct 08, 2012
    hello there, how about in zen neeon 2,it will work?the same solution?
  • Cherry Russel
    Cherry Russel Jan 21, 2014
    where is the clean up option in my neeon2 i have stop/play/shutting down is in same button how to cleanup it
How to off restrict volume
Hi Cherry - that's not too hard.
Restricting volume (password protected) is done through Creative Media Lite software.
How to use Creative Media Lite
After protecting the Volume Restriction settings with a password, the same password is required for subsequent changes.
If you forget your password, reinstall your ZEN Neeon 2 firmware. You can download it from Creative Worldwide Support ZEN Neeon 2
Jan 21, 2014 | Creative Labs ZEN Neeon 2 MP3 Player
Forgot password to remove restrict volume setting
Hi you will have to format your player and reinstall the firmware so the player will be like it was from the factory. That will wipe on the password you set and you can just reset it to what you want.
If you need any more help, parts or your player repaired you can go to my repair service web page and e-mial me, call me or contact me threw my Ebay user name at firehouse7777.weebly.com Thanks
Dec 23, 2010 | Creative Labs ZEN Vision:M Digital Media...
I have forgotten the password for the Restrict Volume button
Hi
Please fallow your desired step as fallow and then check
Step1
Clean Up
: Scans the player and removes invalid links from its music library.
Does not affect music files themselves.
Step2
Format (All) :
Erases all content!
Save a copy of your player's content before formatting.
Step3
Reload OS/ Firmware: Caution! Erases your player's firmware.
DO NOT select the Reload Firmware option unless you have access to a PC and you have downloaded the necessary firmware to install.
Step4
Reboots the device.
Hope it will work
Kindly Rate !
Thanks
Sep 06, 2009 | Creative Labs ZEN V Plus MP3 Player
How to break restrict password of zen
Sir,
Boot the ZVM into Recovery Mode and select Cleanup from the menu. This will reset any user defined settings, including the passwords.
thanks
good luck
Aug 17, 2009 | Creative Labs ZEN V Plus MP3 Player
How to reset code for powering off restrict volume on my creative zen neeon 2
Here is a quicker solution if you have already chosen Europe?
Well, thanks to my investigations I have found there is a solution. Pressing reset will not work and installing new f/w is a pain.
Instead, open your S9 system folder, and simply delete the "PARAM" file. Power off. Power up. (There is no need to change firmware at all).
You are back at the original screen. 1. Choose your language. 2. Next DO NOT CHOOSE THE EUROPE setting. 3. Third, choose your radio setting - any will do.
Jul 19, 2009 | Creative Labs ZEN V Plus MP3 Player
Volume too low on zen
Try going to System>Audio Settings>Restrict Volume on your ZEN. This is a password protected feature for parental controls i guess... If this doesn't work, get a hearing aid : )
Jan 28, 2009 | Creative Labs Zen Digital Media Player
Creative Zen V Plus volume control unresponsive
someone probably put a password in the volume control thingy
to change just go to settins and then where it says volume
if you cant go in it might be somone changed the password
Aug 12, 2008 | Creative Labs ZEN V Plus MP3 Player
Forgot password on the restrict volume
I have solution !!! You must turn up player!!!
then TURN ON WHILE HOPLDING PLAY BUTTON !!!!!!!
Then a screen goes on !!!!
You must choose CLEAN UP THEN REBOOT !!!
THEN IF IT DONT WORKED!!
THEN YOU NEED TO CHOOSE CLEAN UP THEN FORMAT THEN REBOOT !!!!
THATS ALL
BY DABDAB10
Jan 16, 2008 | Creative Labs ZEN V Plus MP3 Player
Creative Vplus hangs while charging
Zen V is dead
"If your Zen V is dead, wont respond to anything, try this, plug it in to the computer, hold the power switch in the on position, THEN trigger the reset button, worked like a charm for mine, I had thought it a lost cause."
May 29, 2007 | Creative Labs ZEN V Plus MP3 Player
Creative Labs ZEN V Plus MP3 Player Logo
760 people viewed this question
Top Creative Labs Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Mohamed Ismail
Mohamed Ismail
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
