Question about Xerox DocuColor 12 Printer
I am getting an error message 027-516 server connection error SMB when i try and scan everything else works fine
  • 11 Answers
SMASH IT WITH A HAMMER NOWWWWWWWWWW
Posted on Nov 17, 2009
  • Skimask001 Dec 16, 2010
    I had this error in Network Scanning.
    Resolved by:
    1. Enabling SMB protocol
    2. Adding DNS and WINS settings.
    It is now scanning to the appropriate folder.
I have a KM 4050 and when we scan it is giving a "send error 2101" Everything else is fine. We are able to print from our computers etc. so I know our connections are ok. Any suggestions?
The following errors are simalir;
2101, 2102, 2201, 2202, 2203, 3101:
The network cable is disconnected or the hub that it is connected to is not operating properly. Check the cable and the hub. Otherwise, the server name or the host name of the SMTP server is not set correctly. Use COMMAND CENTER and register the SMTP server name and the host name correctly.
The link below takes you to Kyocera's Scan to SMB setup guide on GFBM's website (they are a Kyocera dealer). The guide setup guide is good and gives pictures and examples.
http://gfbm.net/Documents/self_help/SCAN%20TO%20SMB%20PC%20setup%20R3.pdf
I hope this is helpful,
Shawn
Feb 11, 2011 | Kyocera Copystar CS-1820 Black and White...
Scanning error 2101 scanning to smb file
you have to have a user name and password set up on the computer you are scanning to then you set that up in the address you set up on the copier.
Mar 25, 2010 | Kyocera Copystar CS-1820 Black and White...
SMB Scanning - Virtual Server envirnoment
A quick fix for that would be to enter the fix IP adress instead of the host name, or to check if the host name on the SMB server is correct, and reboot the SMB server.
A good help is to do that from another PC to check if that works:
ping the IP adress try to connect to smb://IP_adress_or_hostname
If that works on the PC, there's no reason that it shouldn't work for the scan
Jul 03, 2009 | Konica Minolta bizhub C250 All-In-One...
Can't scan to smb
in smb server, create a folder and give all rights, to that folder, if youre in domain, it may need you to use a password, so create a user and password and give rights that user in folder then go youre printer ip address, and add a contact, choose smb and fill in the fields. if error occurs, then choose details and you see whats wrong
Oct 30, 2008 | Konica Minolta bizhub 250 All-In-One Laser...
Scan-to-smb fails on SAMBA share
Hello, I have the same problem wih a Bizhub 500 and samba on SLES 9
Jul 22, 2008 | Konica Minolta bizhub 250 All-In-One Laser...
Scan to smb
Setting up a scanning template using CentreWare Internet Services (CWIS) will fail if the user login name is a domain user, for example, ADSdomain\testadmin.
  1. Open an Internet web browser.
  2. Enter the IP Address of the machine in the Address field, and then press [Enter] on the keyboard. The CWIS home page will be displayed.
  3. Click on the [Services] tab.
  4. Click on the [Job Templates] link.
  5. Click on the [Display Job Templates Screen] button. The Device Template window will be displayed.
  6. Click on the [File Repository Setup] radio button. The File Repository Setup window will be displayed.
  7. Select the required File Repository from the File Repository Setup pull-down menu.
  8. Enter a username that only exists on the SMB server in the Login Name field.
  9. Click on the [Apply] button. A 'Settings have been updated' message will be displayed.
  10. Click on the [Back] button. The File Repository Setup window will be displayed.
  11. Click on the [Template] radio button. The Device Template window will be displayed.
  12. Click on the [Create New] button, and then setup the template again.
  13. Click on the [X] in the upper, right corner to close the Internet browser window and return to the desktop.
May 19, 2008 | Xerox WorkCentre M128 Copier
RE : Xerox WorkCentre M128 016-782
SMB settings error.
if i remember right, the settings should be:
server: 192.168.1.10 / or server name
folder: Sbssvr1\Scans\SCANS
and if still not working, try give some user name and pwd, some networks require this.
Apr 24, 2008 | Konica Minolta bizhub C250 All-In-One...
Xerox DocuColor 12 Printer Logo
12,822 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
