If I cook/boil water on the burner under the microwave, my light controls/fan controls don't work. I was thinking of sealing the unit with an opoxy or glue?..what do you think? It is a Kenmore model #721.62622200
  • john regrut May 11, 2010
    I am trying to make a mental picture from what you have written.. burner under the micro. what kind of burner and why would you seal it with glue???? please give a clear response... email me directly at jregsr9304@gmail.com and i will see if i can help you.. what our thoughts are and what you want to do are 2 different things at this point
  • 11 Answers
I THINK U ARE GOING TO BURN YOUR HOUSE DOWN. PLEASE DONT... PLEASE
Posted on Nov 17, 2009
OTR Samsung Microwave fan comes on with no reason. Any way to fix it?
Does this happen while you are cooking on the range burners under the control panel?? These type microwaves have a heat sensor built into them in the area of the control panel bottom. If the microwave control gets too hot from cooking on the stove below it the heat sensor will turn the fan on to keep the control panel from getting heat damage. The fan should go off after everything cools off.
Apr 13, 2015 | Samsung 1.8 Cu. Ft. Over-the-Range...
Micro won't work after boiling water under it all day
I am not sure what you mean by boiling water under it all day. If it was under the unit, it probably shorted it out and it won't work. If you were using it constantly to boil water, you may have overheated it. To be safe, please unplug it and call the manufacturer.
Feb 14, 2013 | Samsung SMH7178STD Microwave Oven
The microwave quit working. I could still use the timer and the fan. After a year, I had a pot of water boiling on the right back burner of my cook top and the microwave exhaust fan came on. I could not...
I think a bad connection in a lucar styl plug is the problem.
Check all of the connectors that come from the switch/control pannel and the magnetron's transformer.
Make certain that it is not still charged up at a lot of voltage in the capacitor is lethal!!!!
Oct 18, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Keypad not working after boiling water below
Direct spraying of cleaners on the keypad and steam from the cooktop can damage the controls.
I always recommend that you spray non-ammonia cleaner on a soft cloth (not a paper towel which can scratch) and gently wipe the keypad.
And I always recommend that you use the vent fan whenever you're cooking on the stove top to keep heat, steam, and grease out of the controls and door panels.
If it does not dry out over time, it may need to be manually dried or blown out.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
You can find helpful exploded view diagrams and order parts here.
I'd recommend that your bookmark this link to your favorites.
Otherwise, the keypad may be damaged or worn out, or control unit may be damaged.
Feel free to contact me directly (and please include your full model number from the tag in or on the unit) for a free estimate and free tips & do-it-yourself advice.
Your full model number would be one of these: JVM1540DM1BB JVM1540DM1CC JVM1540DM1WW JVM1540LM1CS JVM1540SM1SS
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Feb 09, 2010 | GE JVM1540DM Microwave Oven
Whenever anyone uses the stovetop to boil water, the steam seems to affect the microwave and causes it to turn on by itself and the panel buttons will not work
did it come with the exhaust fan under it? if so just turn it on when boiling water if it didn't try to find one that goes with the unit and hve it installed, this is theonly way to fix the problem
Jun 27, 2009 | Magic Chef CMV1000B Microwave Oven
F3 error
So far so good we unplugged the machine took the filters off the bottom let everything dry out over night and it seems to be working I'll update you tomorrow. I think the steam got the control pannel wet.
Jun 24, 2009 | GE Advantium 120 Convection/Microwave Oven
Kemore Microwave Hood Combination
I HAVE KENMORE 665/61629 LIGHT STAYS ON. AND DO NOT COOKS. AND THE FAN DOES NOT WORK.
Jan 05, 2009 | Kenmore 63662 / 63664 / 63669 Microwave...
JVM1190 wont cook
You have a blown actuator. This is the device that creates the microwaves that cook the food. The cost of one of these will be as much as a new unit.
Nov 09, 2008 | GE JVM1190 Microwave Oven
Microwave turned off
I always suggest that the hood / exhaust fan be on whenever you're cooking on the stove top. This helps keep grease and steam out of the controls.
The first thing to try is a "hard reset". Unplug it from the power line for a minute, plug it back in, set the clock, then try again.
Let us know if the hard reset doesn't fix it.
Otherwise, you may have a bad controller, which we may be able to repair for you.
Jun 29, 2008 | GE JVM2070 Microwave Oven
Fan stopped working in JVM1533BD microwave
I assume you're talking about the hood fan which ventilates the cook top and blows air through the grille across the top. If so, it's okay to use the microwave with that not working, but if you boil something on the stove, an external fan is definitely needed to keep mositure from going up into the microwave controls. If the cooling fan INSIDE the microwave (behind the keypad) is not working, then you do NOT want to run it unit it is fixed. If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk You can find helpful exploded view diagrams and order parts by entering your full model number (without the suffix) here: http://tinyurl.com/gv383
Apr 06, 2007 | GE JVM1542 Microwave Oven
k24674
jasbo
jasbo
