Golden Eye LG Color Television Receiver:10 years old After 2 Hours working OK.Picture disappears into a thin line about half inch thick in middle of screen.Running horizontally. Sound unaffected. Is it worth getting fixed ? Thanks JS.
  • 8,457 Answers
Cold solders,easy fix,taps around for it,just resolders the PCB.Should be cheap,just time,to look for it.
Posted on Nov 17, 2009
Started with one thin horizontal black line, then 3 shades over screen, now only static picture
Check and replace its back light CCFL lamps. If these are faulty, this kind of fault can occur. When replace it, replace all. None one or two. If you wish to get more details about the back light CCFL lamps and its working, check this link. Pull up older posts there.http://electronicshelponline.blogspot.com/
May 28, 2013 | LG Televison & Video
LG 32LH30 LCD TV Problem
IMO Seriously for $119 it's not worth it.
However, it does sound like a capacitor problem
If you are "Serious" about fixing I'd find a TV repair Forum.
Else I'd go here and get a new one.
https://www.walmart.com/browse/electronics/32-inch-tvs/3944_1060825_2489948_7156390
Best Wishes.
Apr 29, 2017 | LG 32LH30 32 in. LCD HDTV
I have a 21inch TV (LG golden eye) which is 10 years old from and now i am facing a problem that when i switched on the tv the standby LED of the tv blinks for a few seconds and then automatically off....
This is line output transformer problems. Before changing LOT,watch any dry soldering is there and also check vertical output ic is good or bad ?by replacement methode.
NOTE- if you know the protection pin, isolate the pin and switch on tv through 200watts bulb seriesly.then watch the symptomes.
Thanking you
Aug 04, 2010 | LG Televison & Video
Tv is about 4 years old. Suddenly developed two
Your plasma screen is made up of 1080 verticle lines and now a few of these lines are not working. This is the screen itself and needs replacing.
May 22, 2010 | Samsung HP-T4254 42 in. Plasma Television
My Hitachi 65SWX20B Model, made in 02, just developed Picture disturbance
Can you post a picture of the set. This might be a convergence problem. seeing the set will confirm this.
Thank you,
shuttle83
Oct 28, 2007 | Hitachi 65S500 65" HDTV-Ready Rear...
Samsung hl-r5667l
sounds like a loose connection or harness ,remove rear cover and secuer all connectors / pull a.c plug first.
Oct 19, 2007 | Samsung HCN473W 47" Rear Projection...
RCA 32V420T (32 inch)
I think that vertical deplection IC of you tv set is shorted. Please check also the YOKE of the unit, its maybe grounded.
Sep 10, 2007 | RCA 32V420T 32" TV
I have a Mitsubishi VS-60.. With a Picture
Vertical IC outputs , vertical Capacitors are most like the culprit on your deflection panel. good luck
Aug 16, 2007 | Mitsubishi VS-50501 50" Rear Projection...
Vertical, pencil-thin blue line appears after 10 minutes of viewing (any source)
I would suspect a connection breaking down as the set heats up. A shop will probably have to put the set in a stand to hold it while they check for loose connections or defective components inside. Not a DIY job by any means. If this line went completely through the picture either vertically or horizontally and stayed there then this would have indicated a failure in the Panel itself. A thin Line any where on the screen consisting of one pixel in width is a Panel Failure according to Hitachi.
Jan 01, 2007 | Hitachi 55HDT51 55 in. HD-Ready Plasma...
Televison & Video Logo
152 people viewed this question
Top Televison & Video Experts
Electro Med Services...
