Question about Frigidaire Gallery Series GLHS269ZDB 36" 26.0 Cu. Ft. Side-by-Side Refrigerator w/ 7 Button Dispense...
Frigidaire Gallery series stove top stopped working.
My oven is working fine but the stove top will not turn on. When I turn on a burner the clock comes on to 12:00 and there is a short buzzer like sound that comes from the back of the panel. Can I fix this myself?
  • Anonymous Feb 23, 2009
    I have a large electric burner on my cooktop that won't come on and I cannot figure out how to get the top open to expose the burner.
    Please help!!!
My oven ctope working. i try tolook for fuses but can not find
Posted on Feb 18, 2008
  • 833 Answers
This sounds like a burner control. You may be able to do the job yourself. If you order the part, it should plug in. Remember to turn off the power. Any online source should have the control.
Posted on Jan 10, 2008
6ya staff
SOURCE:
Oven burner and broiler burner don't warm at all. Stove top burners work. Clock display normal. When turned on lights indicate oven on and preheating (normal). I have reset the main circuit breaker with no...
Hi Brian, thank you for your post!
Sounds like the either both bake and broiler element may be faulty or a potential wiring failure to the elements. You may want to connect with a local servicer who will be best equipped to pinpoint the problem. If you don't know a qualified technician, you can use the service locator option on the manufacturer site to find one near you.
Sep 15, 2013 | Frigidaire 30 in. Electric Gallery Series...
The control panel lights do not work nor does the oven. all the burners work fine this is a convection oven with a smooth top Gallery series
Check your main breaker in the fuse panel, it may be partially tripped. Turn the 40 amp breaker off and back on. if the display does not return to the stove, the I would suggest you contact a local servicer.
Aug 29, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
Burners abruptly stooped working on top of the stove
check electrical panel of your house and make sure both breakers are in the on possition ..
Jan 04, 2010 | Frigidaire FEF352 Electric Kitchen Range
Frigidaire Gallery Professional Series Oven Won't Turn On
Suspect a bad oven element. Worse case is a bad oven relay on the clock control board.
Sep 20, 2009 | Frigidaire Gallery GLEFM397DS Electric...
Our frigidaire flat-top electric stove stopped working
Sound like you make have a loose neutral on the cord where it attaches to the range or in the electrical receptacle where it plugs in, you can check the cord by pulling the range out, remove the small access cover to the cord connection area, after you have unplugged it and just tightened all the nuts to all connections on the cord. I advise an electrician to check the receptacle. I hope this has helped you. Have a great new year.
Dec 28, 2017 | Frigidaire FEB27S5A Electric Single Oven
My smooth top burner will not work
The #1 most likely problem is that you don't have 240 volts to the unit. Your clock and lights will come on but not the burners or the oven elements. Turn off your breaker and then back on. If this doesn't correct the issue...#2 Check your cord and the terminal where it attaches to the stove for a burnt connection, WITH THE POWER OFF!!! #3 Call a technician.
Dec 09, 2008 | Frigidaire Gallery Series GLHS269ZDB 36"...
Stove won't heat
Oven was working, I had it on pre-heat, then I turned on the stove top, but the burners won't heat. When I turn on the stove top the stove makes a short BUZZ noise and the clock area lights up, when the burner is turned off all the lights go out. Please help, food prepared.
Thank You
Dec 02, 2008 | Frigidaire FEF336BC Electric Kitchen Range
Frigidaire Gallery Professional Series - No clock/oven functions
i have an old model of the fridgedare gallery professional series stove. After self cleaning, the ignition sparks for the burners will not come off, they keep clicking and only stops when i pull out the plug. can you help me with this situation?
Nov 01, 2008 | Frigidaire FGB24S5A Gas Single Oven
Frigidaire smooth top stove
MY OVEN IS WORKING, THE STOVE TOP DOSEN'T. tHE CLOCK SHUTS OFF WHEN i TURN THE BURNER KNOB OFF AND WHEN i TURN ONE BURNER ON THE CLOCK FLASHES 12:00 AND THERE IS A SHORT BUZZER SOUND COMING FROM BEHIND THE PANEL. CAN I FIX THIS MYSELF?
Dec 16, 2007 | Frigidaire Gallery Series GLHS269ZDB 36"...
Frigidaire Gallery Series GLHS269ZDB 36" 26.0 Cu. Ft. Side-by-Side Refrigerator w/ 7 Button Dispense... Logo
492 people viewed this question
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
Thomas F. Schneider
jasbo
jasbo
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
