Question about Hitachi 51F59 51" HDTV Projection Television
Color was off balance and turned off in the middle of fixing it now it isn't coming back on
  • Hitachi Master
  • 8,457 Answers
Convergence it dead,must buy a convergence kit.Know how to solders?Tries these websites Tv repair Worl.com or Tv Repair Kits.
Posted on Nov 17, 2009
    President:
  • Hitachi Master
  • 1,779 Answers
What exactly were you adjusting at the time? Be specific and complete.
How to set perfect color on samsung 48" led smart tv
To achieve true life like colors, the primary colors need to be balanced to produce a perfect black and white picture. Turn the color level on the tv to 0 and tint to middle then look at the picture - does it have a reddish or other "coloration" to it? Then set the individual color levels (if your TV has these settings) of red, blue and green to balance out and get a true black and white picture. After that, bring the color level up slowly until the facial levels are natural - not over driven as seen in most store displays. You may need to use tint control slightly.....
One other way - There is a dvd from Disney called "Wow" that aids in getting your set to optimum display.
Jul 27, 2014 | Televison & Video
It seems like the white balance on my TV is wrong - colors are a sort of not realistic and even when I turn the color off there;s still some red/purple colors on the picture. I tried to adjust picture,...
Hello mvadima11,
Welcome, and thank you for using FixYa!
To answer your question: The white balance isn't the issue on this set, in my opinion.I would be more inclined to believe that someone had placed a speaker or large magnet too close to your television.If you have speakers right next to the set, move them away. If someone set a magnet on the set sometime recently, you will have to rebalance the tube.
To try rebalance of the tube, find the largest magnet you can find. Then starting from the outside edge of the tube, go in clock-wise circles, slowly, all the way to the center of the television. Once you have arched the center, pull slowly, straight out. Now turn your color back up to normal. This should fix your issue.
Have a great day!
Oct 16, 2011 | Sony FD Trinitron WEGA KV-32HS420 32" TV
When traveling over 50 miles an hour you get a vibrating noise coming from the middle of the dashboard,. dealer is telling me it is air coming thru the air box and gm wont' fix it
There could be a simple solution you should try. Swap wheels and tires from front to back and see if it makes any difference. This will indicate either a bad or broken belt in one of your tires or simply wheel balance.
If this makes no difference whatsoever take it to a tire shop that will "road force" balance the front two wheels. This compensates for imperfections in your rims that a normal balance will not catch.
Other more complicated opptions could be a simple four wheel aligmnment. (2 wheel is a waste of money).
Failing that it could be a host of issues from a defective front CV or axle.
Jan 27, 2011 | 2007 Chevrolet Malibu Maxx LTZ Hatchback
My game will save, but when I turn it back on, there is only the "new game" and "options" displayed...I can't continue from where I saved.
there isn't a way to bring back a corrupted Gameboy game save. The reason the save has corrupted is because the small battery in the game had died. Replacing the battery might fix your game, but it won't bring back your save. Well you could use a memory stick for the game boy color and advance and orginal gameboy then instead.
Oct 20, 2010 | Nintendo Pokemon Gold
Screen has too much green all of a sudden
Try balancing the tubes out, turn your color all the way down and the brightness in the middle, then find the focus block, it will be a block with 6 controls one row will say screen the other will say focus near the picture tubes, adjust the screen controls(one control for each color) until the picture has a good black and white look to it, then turn your color up and it should look fine. This is how i balance out the picture. But there is another method that allot of techs use, the other method is to adjust the brightness up until you see what is called retrace lines it is a jagged line going down the screen, once you see these lines back the adjustment down just until they disappear. Do this for all three colors. This method works but on an older set can throw the white balance off because of tube wear.
Sep 03, 2009 | Hitachi 57F500 57" Rear Projection...
Unsteady White balance
You must switch to preset, push the awb button on the front to switch from auto white balance indoor to auto white balance sunlight (3200k to 5600k). This will automatically balance the camera to the approximate settings needed. For fine tuning the white balance.....
If you want to set the A and B buttons, first switch to A, then hit the Auto button by the user 1,2 3 button until you are off of auto total white auto focus auto iris mode AWB A ch will show in the viewer hit the Auto again and ATW shows, meaning Auto total white is on, and you will not have control over the white balance, it will continue to float and try to automatically balance in the middle of your footage. Once you are on AWB A ch from hitting the AUTO button, then point the camera at the white you are balancing to (of course put the white under the lighting you want to balance to) push the AWB button on the front of the camera and hold it in until the camera goes through the white balance mode and the black balance mode,...the camera will go dark while this is being done but an OK with the correct color temperature will show briefly on the screen when it is done and you can release the AWB button. Now you have set the A button to the white balance for the current lighting.
If you are going to be switching between indoor and outdoor, do the same for the B button above and set it's white balance to the exterior light color temp. that way you can just switch between A and B when you are moving fast between interior and exterior shots and have the correct color temp.
You could always leave the switch on preset, and hit the AWB button on the front to switch from 3200 to 5600, but remember not all light is either 3200 or 5600, that is why we use the A and B settings and get the White balance for the exact color temp of the space being shot in.
Jul 25, 2009 | Panasonic AG-DVX100B DV Digital Camcorder
Sony KP-511HW40 fleshing with green color and shuts off
this is a common fault adjust the little black box in front behind the small wooden cover. you will see 6 controls don't adjust any of the top 3 only the bottom knobs 1 for each color. slowly back the control counterclockwise turn the set on and wait untill it shows a picture, slowly adjust the control for the color in question utill the color balance is correct- black and white with the color setting turned down all the way with the user menu when balance is ok you are all set.. turn the color back up with user control. rtepeat process if needed.
Dec 26, 2008 | Sony KP-51HW40 51" Rear Projection...
Nikon D200 / photos coming out magenta somtimes blue
Set it to a manual white balance colour temperature, 5200K being an average one to start testing at. Does this make a difference? If not, then the sensor, RGB lightmetering sensor or exposure board may be at fault. The peripheral area of most sensors is used for white balance metering, which denotes a sensor issue, although if the exposure board isn't reading this information correctly, then it will give varying results. However, Nikon's 420 pixel RGB sensor on the D200 may also be taking WB readings. I'll be talking to Nikon soon, but try manual settings first.
Jun 30, 2008 | Nikon D200 Body Only Digital Camera
Redish/Pinks color to scans.
You need to reset your scanner's color management settings to default..
Which utilty software r u using?Arcsoft Photostudio?If yes go to Edit ->preferences
Set RGB settings to the same level(adjust the slider next to red)
If it doesnt work or u r not using arcsoft..post back..
Nov 04, 2007 | Canon CanoScan LiDE 600F Flatbed Scanner
Hitachi 51F59 51" HDTV Projection Television Logo
Top Hitachi Televison & Video Experts
Jaime Hernandez
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
