Question about Cell Phones
WHERE DO WE FIND ENGINE # ON 1981 FORD LASER - Cell Phones
  • 106 Answers
What you need to do is go on a car report website with the vin and it will tell you everything or you just go up to napa and give them the vin and ask them to look up what you want to know about your car or truck
Posted on Nov 17, 2009
Can I put a 1981 ford f-150 motor in a 1991 ford f-150 truck
Sounds to me like you opened a can of worms that you are not equipped/qualified to deal with. To begin with, doing an engine change the way you did it is illegal. It is OK to put the newer motor in the older vehicle, but it is against federal law to put the older engine into the newer vehicle. REFERENCE: EPA ENGINE SWAP FACT SHEET
With all that said, if you want to do a swap like that, it is necessary to also swap wiring harnesses and computer modules (among several other components) if you expect it to work.
Mar 17, 2012 | 1991 Ford F150
I have a 1981 ford f150 and have a question. why dose the left exaust manifold glow red hot when i run my engine? also, my trucks engine doesn't have a catilick converter.
If it's a V-engine and the other manifold doesn't get red the one that does may draw some air, i.e. the seal between the block and the exhaust is gone. If you don't replace it, the manifold will melt.
Sep 21, 2010 | 1981 Ford F 150
Im not sure what wire goes to the distibutor cap to the spark plug on a 1981 6 cylinder Ford Ranger
Here is the firing order for the 4.9 liter in-line six cylinder engine.
Jun 20, 2010 | 1981 Ford F 150
1981 ford f-100 replaced motor firing ,rolls over
What engine do you have the firing order on a 300-6 is 153624
Jan 02, 2010 | 1981 Ford F 100
Ford 1981 KA Laser horn fuse
LOOK IN THE FUSE BOX UNDER THE DASH ON THE DRIVERS SIDE
Nov 14, 2009 | 2006 Ford Laser
1981 ford bronco failed emissions twice
Look behind the motor, next to the firewall. There's a vacuum check valve that keeps the air gulp pump from pressurizing the crankcase. Mine was shot; had the same symtoms. Also, make sure that the EGR valve is closing at low idle.
You don't need an engine light to check the codes. First, do a KOEO (key on, engine off), but, let me tell you, when this happened to me (1986 Full size with 302 EFI, multiport injection) NOTHING showed up. No one, not Ford, not emission specialists, nada, knew the vacuum check valve existed.
By the way; are you getting motor oil in the air filter housing?
Jun 03, 2009 | 1981 Ford Bronco
1981 Ford Laser Grinding in First and Reverse but not second
The clutch assembly seems to be at fault. Either its worn-out or has to be readjusted(reset). This noise indicates improper transmission of power from the machine to the wheels and since this has automatic gears, it should rectified at the earliest...sodeep
May 15, 2009 | 1998 Dodge Grand Caravan
Starting Problem, not Starting
thick battery positive connects to solenoid, as engine is neg earthed, the ignition wrte also connects to solenoid on lug, carefull not to mix them up as it will spark good luck
Feb 10, 2009 | 2006 Ford Laser
Cell Phones Logo
21 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
