Question about GE WBSR3140DW Top Load Washer
It's been leaking----found water on the floor today. It won't spin when set on the cotton side, but it will spin on the delicate side.
  • 106 Answers
Retire the machine. GE's are junk. they fallapart in 5 yrs. the seals on your transmission are most likely leaking. Brake on trans not working.
Buy a whirlpool.
Posted on Nov 17, 2009
Clothes in bosche washer gets tied up in knots in spin cycle
Are you running a load according to the care labels?? If you run delicate or easy care items on a cotton wash this can happen. Just because an item is 100% Cotton doesn't necessarily mean it will tolerate a cotton cycle check the care label. Also, if for example a cotton cycle is 6Kg, the easy care will be 3-4Kg, Delicate and woollens will be approx 2Kg. Overloading can cause items to knot during cycle. Finally, check that your inlet water is not too hot. Repost if you need any further assistance
Feb 19, 2013 | Bosch Nexxt 100 Series WFMC1001UC Front...
Found water on floor board of car
heater raidator- right side under dash is leaking.these can be a hard to replace. remove heater hose ay the fire wall see if your leak stops.
Jun 02, 2012 | 2004 Dodge Stratus
I would please like a manual for the simpson eziloader front loader washing machine
45s558e_lr.jpg A 5.5kg capacity front load washer with a stainless steel spinbowl, 8 wash programs, variable spin speeds, 2.5 star energy rating and a WELS 4 star water efficiency rating (56 litres). General Specifications Colour: white Overall Dimensions (Check installation guides in downloads for exact dimensions) Overall Height: 850 mm Overall Width: 600 mm Overall Depth: 630 mm Key Specifications and Features Capacity: 5.5 kg Energy star rating on old scale: 2.5 stars Spin Bowl: Stainless steel Wash Programs: 8 Water efficiency star rating (WELS): 4 WELS Water consumption: 56 Litres Other Specifications Door opening - Large: 300 mm Door opening angle: 165 degrees EAN: 8853328005026 Variable spin speeds: 800,650,500 rpm Other Features Colours 40/ Colours cold: Yes Cotton 60 / Cotton 60 eco / Cotton cold: Yes Cycle start/pause button: Yes Delicates 30 / Delicates cold: Yes Extra rinse: Yes EZILoader: Large EZILoader doors makes loading and unloading your washing easy. Levelling legs: The levelling legs may be adjusted if the floor is not level, to ensure correct operation of the washing machine Pre-wash: Yes Pushbutton electronic options: Yes Quick Wash: Yes Rinse/ Drain / Spin: Yes Rotary Electronic Controls: Yes Wool 30: Yes Warranty Details 2 years from the date of first purchase (3 months for commercial applications) and subject to the conditions set out in the warranty card accompanying the product when purchased.
Aug 06, 2011 | Washing Machines
2002 suburban has leak in driver side rear floor. Cannot see where water would be coming from?
We had same--water on driver side rear floor (soaked!). Driver side front floor seemed dry until feeling UNDER rug, was slightly damp. We found the location of TWO leaks causing this.
Leak #1 was through the parking brake line/cable seal; Recaulked with silicone. Removed plastic trim on floor between floor and door to reveal metal channel filled with water.
Leak #2 was where the door meets the car, near the hinge. It was the accordian-looking tube housing the wiring for the door. The big, rubber, circular plug connecting it to the main part of the car had come loose and water ran down through that, into the SAME metal channel filled with water from leak #1; will seal with silicone.
Note: We found that the channel filled extensively near the front door, BUT the carpet edge from the floor near the rear seat was dipping into it, wicking it up to the rear floor. Also, upon acceleration, the water in the channel gushed toward the back, thus soaking the rear carpet.
These leaks were found by removing all plastic trim (covering edges of carpet by doors), then one of us pouring water into specific areas of the exterior of the vehicle, and the other one watching closely with a flashlight for any signs of dripping.
Feb 18, 2010 | 2002 Chevrolet Suburban
Won't let in cold water. set on delicate, it used
remove cold water supply hose, if all is well and screens are clear , means cold water valve is faulty
Jul 25, 2009 | Equator EZ 3600 CEE Front Load Washer /...
Magic chef washing machine
Water is leaking all over the floor from the bottom of the machine when it is filling up. Can you tell me how to fix this problem.
Oct 23, 2008 | Washing Machines
Printed wash cycle info missing from front of machine
Quick wash cycle for the Hotpoint FEW12 is 'K'
A 95* White cotton, heavy soil ........ 5.5kg 2hours 30/40 mins Fast spin
B 40* White cotton Heavy soil .......5.5kg 1hour 40/50 mins Fast spin
C 95* White cotton and linen without special finishes......5.5kg 2 hours 20/30 mins Fast spin
D 60* Colour fast cotton, linen or viscose without special finishes......5.5kg 2hours 5/15 mins Fast Spin
E 40* Non-colour fast cotton, linen or viscose.....5.5kg 1hour 40/55 mins Fast spin
F 50* Synthetics, coloured nylon, polyester, acrylic & cotton mixtures, cotton or viscose with special finishes, coloured polyester & cotton mixtures.....3kg 1 hour 5/15 mins Slow Spin
G 40* Acrylics and tri-acetate blends of these fabrics with wool, polyester & wool blends....3kg 40/50 mins Slow Spin
H 40* Wool, shrink resistant machine washable wool, woolen blankets..... 1.5 kg 1 hour 15/25 mins Fast Spin
H...(Wool mixtures with cotton or rayon.....2.5 kg)
J 30* Silk, printed acetate.....3kg 55 mins/1 hour 5mins... Slow Spin
K Quick wash for freshening up lightly soiled items. Warning... not for woolen, silk or delicate items.....1kg 35/45 mins Slow Spin
L Cold wash, cold fill only, no heating action....3kg 55mins/1hour 5 mins Slow Spin
M Rinse and Fast Spin... cotton......5.5kg 55 mins/1hour 5mins...Fast Spin
N Rinse and Slow Spin... Delicates....3kg 30mins Slow Spin
P Fast Spin .... cotton.... 5.5kg 15 mins Fast Spin
Q Slow Spin.... delicates.....3kg 15 mins Slow Spin
Hope this helps
Sue
Jul 14, 2008 | Hotpoint First Edition FEW12 Front Load...
GE WBSR3140DW Top Load Washer Logo
91 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
