Question about Arris SURFboard® SB5101 Cable Modem
Flashing PC/Activity light
Is it normal for the PC/Activity amber light to rapidly flash all the time?
    Brigadier General:
  • 10,406 Answers
Yes. I've put a piece of tape over it, so that the blinking is less annoying.
Posted on Nov 17, 2009
Red light flashing on charger
A red light indicates the charger is charging the battery, an amber light means it has switched from fast rate charging to trickle to keep the battery topped off, and green would mean the battery is completely charged. But don't be fooled waiting for green, many times the charger will only be on green for a moment before changing to amber and keeping the battery topped off.
Flashing can be a sign of a problem on some chargers.
A rapid flashing red can on some chargers indicate a bad or shorted battery, or a bad battery contact in the charger itself. If in question, try a different battery on the charger or compare with another charger to determine if the blinking is normal.
Best regards.
Nov 19, 2013 | Motorola htn9042a charger,120v,single unit
I have filled dishwasher selected temperature and the start light is flashing but nothing happens I think the m/c type is 7197
The Start/Resume light is flashing
This flashing light indicates that your cycle or start-up was interrupted.
Possible causes: The door opened during the cycle, or the power was interrupted.
To resume operation: Make sure the door is closed, and press Start/Resume.
The Clean light is flashing
You should call for service if the Clean light is flashing and the machine is inoperable. It is normal if the Clean light stays on after the cycle is complete. The Clean light is an indication that the dishwasher has been run and that the dishes inside it are clean. Once the door is opened after the cycle is complete, the light will shut off.
The lights are rapidly flashing
Any key that gets stuck will rapidly flash. Press the key a few times in order to release it or press Cancel.
The Rinse Only light is rapidly flashing
If multiple keys are stuck, the Rinse Only light will flash. Press each key, one at a time, to release the stuck keys, or press cancel.
Jun 28, 2011 | Dishwashers
I have a motorola AP-300 which keeps on blinking amber light when i turn it on. how can i reset it or what's wrong with the AP?
From the installation guide for this AP, I find the following:
LED Indicators
The unit has LED activity indicators on the front of the case provide a status display indicating error conditions, transmission, and network activity for the 802.11a (amber) radio or the 802.11b/g (green) radio.
802.11a Activity LED Amber
The amber LED flashes three times per second until firmware is loaded. During boot, 802.11a mobiles cannot associate. After adoption, the amber LED is steady or flashes with 802.11a radio traffic.
The amber LED flashes once per second if an error prevents the 802.11a radio from operating normally.
802.11b/g Activity LED Green
The green LED flashes three times per second until firmware is loaded. During boot, 802.11b/g mobiles cannot associate. After adoption, the green LED is steady or flashes with 802.11b/g radio traffic.
The green LED flashes once per second if an error prevents the 802.11b/g radio from operating normally.
From this, it appears that the 802.11A radio is malfunctioning.
Here is the Motorola support web page for this device.
Dec 30, 2010 | Motorola AP300:802.11A/G, Internal Antenna...
When i turn the printer on the light flashes amber several times, then green then repeats flashing amber, and back to green etc. turning it off and back on made no difference. last time it worked...
when i turn the printer on the light flashes amber several times, then green then repeats flashing amber, and back to green etc. turning it off and back on made no difference. last time it worked normally after being off for a couple of days, but now it is doing that again.
Amber light flashes 7 times, then green for a couple of seconds, then amber 7 times etc.
Jun 02, 2010 | Canon BJ I6500 InkJet Printer
My canon when it's powered on advanced 2 sheets of paper the pinter head moves to the left side then back to the right side as normal then back to the left stops and begings making a chattering sound. The...
press and hold the power button until it stops flashing - the printer is simply trying to tell you that there was an issue (out of ink, out of paper, or paper jam) and is trying to resume normal activity.
Mar 29, 2010 | Cannon i70 Printer
The amber light on the power supply on my HP 550 laptop is flashing 8 times when i press the power button.it does not start ....
This is taken from page 11 of the user's manual (http://bizsupport2.austin.hp.com/bc/docs/support/SupportManual/c01627018/c01627018.pdf)
Blinking amber: A battery that is the only available
power source has reached a low battery level. When
the battery reaches a critical battery level, the battery
light begins blinking rapidly.
In other words, attach the charger to the laptop and let charge for at least 1 hr before trying to restart your computer.
Mar 24, 2010 | HP Business Notebook 550
Flashing amber light
Flashing AMBER power LED on a Dell tower is normally an indication of a power supply failure.
Dec 23, 2009 | Dell OptiPlex 170L PC Desktop
AMBER LIGHT FLASHING WHEN CHARGING
yes it flashes as it charges..Which os is installed in your laptop.
Dec 08, 2008 | Acer Aspire 5315 Notebook
Internal led of ML350 server is glowing.......how do i resolve it?
Hi Franceso, plz specify
Is it powering ON ?
Which LED is glowing?
These leds are there on the front panel :
1 Power On/Standby button
2 System power LED
Green = Power on
Amber = System shut down, but power still applied
Off = No power
3 Internal health LED (Wave sign in BOX)
Green = Normal
Amber = System degraded. To identify the component in a degraded state, refer to system board LEDs.
Red = System critical. To identify the component in a critical state, refer to system board LEDs.
Off = Normal (when in standby mode)
4 External health LED (power supply)
Green = Normal
Amber = Power redundancy failure
Red = Critical power supply failure
5 NIC 1 activity LED Green = Network link
Flashing = Network link and activity
Off = No link to network.
6 UID LED Blue = Activated
Flashing = System remotely managed
Off = Deactivated
7 UID button
If it is Internal health led then any internal h/w issue is suspected.
If it is external health led then any power supply or power source related issue is suspected.
Also check the status of the server & its IML (Integrated Management Logs) in ilo (Integrated Lights Out ) if it is configured. (2nd RJ45 port in rear)
Also make sure the cabinet is properly closed.
Nov 18, 2008 | HP Compaq ProLiant ML350 G3 Server
Arris SURFboard® SB5101 Cable Modem Logo
1,444 people viewed this question
Top Arris Computers & Internet Experts
Jerry
Jerry
Suddenlink Help
Level 1 Expert
Are you an Arris Computer and Internet Expert? Answer questions, earn points and help others
