Question about Compaq Presario 2100T Notebook
Monitor and power issue
I am having trouble with my 2120 laptop. I have it plugged in overnite and when I turn on the power button it comes on for about 30 seconds and then powers off. I wonder if it is just a bad battery. When the power is on the screen never comes on just stays black. Any help will be appreciated.
  • 1 more comment
  • BooNark Jan 10, 2008
    Thank you for the help. The model is 2120US. I left it plugged in all nite and it still will not come on not even while it is plugged in. Your help is appreciated
    I followed the link and did the instructions and it is still doing it. I have taken the battery out and plugged the power in and it still does the same thing. It powers on, all the lights come on, the disk drive runs with a disc in it, the monitor does not come on and then at exactly 30 sec. it powers off. I have no idea what it can be. But, I sure appriciate your time and thoughts. I hope the additional information might help. My daughter used it for college and I got her a new one and just wanted to use this one around the house.
    I think so too. I want to thank you for the time that you have given to me on it. I will carry it to the computer guys at my work and see if I can get a hook up.
    Thanks again for the help :)
    Scholar:
  • 95 Answers
It sounds like the battery is bad. Does it run fine with the power supply pluged in? I need the complete model number for example Compaq Presario V2120AP . Once I have this I believe I can help you
Posted on Jan 10, 2008
Monitor on my dell Inspiron one i019-1818bga does not come on. Power button is white.
Check with an external monitor. That will tell you if the monitor is faulty or the mother board has issues.
Aug 07, 2015 | Dell Computers & Internet
Power is on but monitor does not come on
check the cable, wiring harness, check the outlet for power, make sure you do not have it is a plug that may have switch some where where it turns or shut the power to that outlet.
or can it be video card issue, or plugs adapter is faulty, try a different outlet or different plug in your power strip. check the power strip if you have one, make sure the power strip is on, push the reset button on the power strip.
if you motherboard has internal vga adapter try setting resolution to the lowest setting plug you monitor into the motherboard to see if the issue is the video card or cards.
turn monitor off and on see if it getting warm.
the resolutions maybe to high try lower setting temp.
see if the monitor has manufactures restore or reset button on the monitor some where, it would be around all the connectors are located.
does the light comes on when you turn on in the front of monitor.
if all fails than it is time for a new one.
thank you rod
Apr 19, 2014 | BenQ G922HDAL 18.5 WIDE LED MONITOR
Dell Inspiron 1521 laptop monitor is dark.
It is a posible LCD problem, Might gone defective.
First trouble shooting is to turn off your laptop completele and the remove the battery and the charger and any accesories connected on yur lap top. Then press the power button for 1 minute. It will reset the settings of your laptop to default if you accidentally press the command for the hotkey to turn off the built in monitor and enabled the extended monitor.
If the issue persist it means it is an issue with the LCD and needs to be replaced.
Mar 28, 2010 | Dell Inspiron 1521 Notebook
Blue light comes on and then clicks off after a
it sounds like a virus or error on the mainframe although it could be your battery try taking your battery out and then plugging it into the mains. then turn it on without the battery in but still plugged in to the mains there may be sumthing wrong with ur batter
Mar 03, 2010 | Packard Bell Easy One Silver 2120 Notebook
Laptop doesnt boot and the monitor doesn't switch on. When we switch on the laptop the processor runs for few seconds and then shuts down and the system tries to restart itself..
You can try the following steps:
1. Unplug the power from the laptop and remove the battery then press the power button of the laptop for 15 seconds
2. Put the battery back in, turn on the laptop without plugging the power to the laptop (If this didn't resolve the issue)
3. Remove the battery and press the power button of the laptop for 15 seconds, after that, plug the power cord and turn on the laptop (if this didn't resolve the issue)
4. Remove the power cord and press the power button of the laptop for 15 seconds, disconnect the Hard drive and turn on the laptop (If this didn't resolve the issue) reconnec the hard drive
5. Remove the Optical Drive and turn on the laptop (If this didn't resolve the issue) reconnect the optical drive
6. Remove the memory chip, if you have 2 memory chips installed in the 2 memory slots (remove both of them) now test each one of the memory to each slots turning on the laptop. (If this didn't resolve the issue) Put the memory chip back in
7. Reseat the CPU and try to make sure that it's installed properly. Turn on the laptop and test if it's gonna work (If this didn't resolve the issue)
8. Reseat the power cords coming from the power supply of the laptop and test the laptop. (If this didn't resolve the issue)
9. Disconnect everything and just leave the CPU installed and turn on the laptop.
10. If all else fails, there's a big possibility that the problem may be with the power supply or the motherboard of the laptop.
(Note: you may try to clean your computer if there is a large amount of dust. You may try to remove the CMOS battery)
regards,
sl4x
Feb 14, 2010 | HP Pavilion dv6000z Notebook
Dell inspiron e1505 powers on but nothing happens. The screen is black
regards,
sl4x
Feb 14, 2010 | Dell Inspiron E1505 Notebook
Blank screen upon startup
Try taking out the hard disk, plug in power and see if you have a display on your screen or external monitor. if same thing happen, try taking out the memory card. If you hear a beep sound it's a faulty mem. card, if no beep sound appears I suspected it's a motherboard faulty.
May 31, 2009 | Lenovo ThinkPad T61 Notebook
Gateway laptop powers up but screen does not come up.
See if you can attach an external monitor to your laptop.If you can and you can see your display on the monitor the it is a faulty laptop screen .If you see nothing on the x monitor then the graphic card/chip is fried.
Dec 08, 2008 | Gateway M305CRV Notebook
Plug and play PL716s proview monitor
after almost two/ three years my monitor is starting to give me trouble its comes on then it blinks off I have to constantly turn the power button on and off I cannot keep it on. Please help.
Jun 19, 2008 | Envision EN-7220 17" Flat Panel LCD...
Going to Sleep
got the same issue
hp pavilion 1723
Nov 01, 2007 | HP Pavilion F1903 19" Flat Panel LCD...
Compaq Presario 2100T Notebook Logo
46 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
