Question about HP Photosmart C6180 All-In-One InkJet Printer
I HAVE THE ABOVE ALL-IN-ONE SERIES AND IT WAS IMPROPERLY SHUTDOWN AS i TURNED IT OFF AT THE WALL. uNOFRTUNATELY IT NOW WILL NOT RESPOND PROPERLY AND KEEPS PRINTING BLANK COPIES. tHE PRINTER WILL HOWEVER PRINT COPIES. WHAT DO I DO?
  • 34 Answers
I'm not sure if this is the fix, but try it and see. ">
Posted on Apr 11, 2011
    Brigadier General:
  • 10,406 Answers
Are you out of ink?
Click the Windows START
Click Control Panel
Click Classic View
Click Printers
Right-mouse click on your printer
Click Properties
Click Print A Test Page.
If the test-page prints in black-and-colour, everything is fine.
Posted on Nov 17, 2009
My Acer Aspire M1201 won't turn on.
More than likely your power supply got fried from a power surge during that storm anyway. You'd be surprised at how worthless most surge suppressors are these days.
Jul 25, 2012 | Computers & Internet
When I try to power up my acer aspire M1201 the power button isn't responding
Check to make sure that power is reaching the power supply of your unit. If it is and still does not work, then the issue is with the supply that needs replacement. Common malady.
Jun 20, 2017 | Acer Aspire M1201 Athlon X2 320 Gb PC...
Which codes (OBDI or II) do I use for my 1994 Jeep Grand cherokee laredo 4.0 2wd
before 1996 they use onboard diagnosis system for jeep.
when you turn on key you need to count check engine light blinks.
here are codes taken from internet.
11* No crank reference signal detected during engine cranking.
12* Direct battery input to PCM was disconnected within the last 50 key-on cycles.
13** No difference recognized between the engine MAP reading and the barometric (atmosphereic) pressure reading at start-up
14** MAP sensor input below minimum acceptable voltage.
or
MAP sensor input above maximum acceptable voltage.
15** No vehicle distance (speed) sensor signal detected during road load conditions.
17* Engine coolant temperature remains below normal operating temperatures during vehicle travel (thermostat).
21** Neither rich nor lean condition detected from the oxygen sensor input.
or
Oxygen sensor input voltage maintained above the normal operating range.
22** Engine coolant temperature sensor input above maximum acceptable voltage.
or
Engine coolant temperature sensor input below minimum acceptable voltage.
23** Intake manifold air temperature sensor input above maximum acceptable voltage.
or
Intake manifold air temperature sensor input below minimum acceptable voltage.
24** Throttle position sensor input above maximum acceptable voltage.
or
Throttle position sensor input below minimum acceptable voltage.
25** A shorted condition detected in one or more of the idle air control motor circuits.
27* Injector #1 output driver does not respond properly to the control signal.
or
Injector #2 output driver does not respond properly to the control signal.
or
Injector #3 output driver does not respond properly to the control signal.
or
Injector #4 output driver does not respond properly to the control signal.
or
Injector #5 output driver does not respond properly to the control signal.
or
Injector #6 output driver does not respond properly to the control signal.
33* An open or shorted condition detected in the A/C clutch relay circuit.
34* An open or shorted condition detected in the speed control vacuum or vent solenoid circuits.
or
Speed control switch input below the minimum acceptable voltage.
or
Speed control switch input above the maximum acceptable voltage.
35* An open or shorted condition detected in the radiator fan relay circuit.
41* An open or shorted condition detected in the generator field control circuit.
42* An open or shorted condition detected in the auto shutdown relay circuit.
44* An open or shorted condition exists in the engine coolant temperature sensor circuit or a problem exists in the PCM's battery temperature voltage circuit.
46** Battery voltage sense input above target charging voltage during engine operation.
47** Battery voltage sense input below target charging voltage during engine operation. Also, no significant change detected in battery voltage during active test of generator output.
51** Oxygen sensor signal input indicates lean air/fuel ratio condition during engine operation.
52** Oxygen sensor signal input indicates rich air/fuel ratio condition during engine operation.
53* PCM internal fault condition detected.
54* No fuel sync (camshaft signal) detected during engine cranking.
55* Completion of diagnostic trouble code display on the malfunction indicator lamp (check engine lamp).
62* Unsuccessful attempt to update SRI (service reminder indicator) miles in the PCM EEPROM.
63* Unsuccessful attempt to write to an EEPROM location by the PCM.
* - Check engine lamp will not illuminate at all times if this code was recorded. Cycle ignition key as described and observe code flashed by check engine lamp.
** - Check engine lamp will illuminate during engine operation if this code was recorded.
PCM = Powertrain Control Module (the engine computer)
MAP = Manifold Absolute Pressure (the sensor that measures how hard the engine is sucking air through the intake manifold
EEPROM = Electrically Erasable Programmable Read Only Memory (a type of computer chip used inside the PCM)
Nov 19, 2011 | 1994 Jeep Grand Cherokee
Door operates properly with wall switch. will not respond to remote control. have replaced battery and tried to reprogram the control box with the remote as described on the unit. Lighted wall switch...
Sounds as if you have inadvertently turned on the vacation lock. If you have a lock button hold down for two seconds to turn off. Then your remote should start working again. May need re-programmed if you left the battery out for more than a minute or two.
Aug 15, 2011 | liftmaster Chamberlain Garage Door Opener...
The uid light is always showing red 1mins after pressing the power button
This issue happens when one of the following condition has occured:
  1. Improperly seated or faulty power supply. (Was the pwr sup replaced?)
  2. Loose or Faulty power cord. (Check to make sure it is properly seated and connected)
  3. Improperly seated component or interlock problem. (New drives or cards? Make sure they are properly seated in slots, secured and power cable fully inserted.)
  4. Power source problems. (Bad or faulty wall outlet, low battery on a ups unit.)
Check these items and correct if needed and this should correct your issue.
Good Luck
C2Solutions
Jan 24, 2011 | HP ProLiant ML350 G5 2.33GHz Small Form...
I am using XP.. net modem working case if take a long time for System shutdown.. if put off modem immiditly shutdown. how to shutdown if working modem.
Windows Server tries to "gracefully" shutdown.
This implies that any "active" network-connections that use the modem will be signalled to "properly" close. This may take a while, waiting for the "other" end of the connection to respond.
However, if you have no active network-connection, then Windows does not need to "wait" for the "other" end of the connection to respond -- it can immediately close the "severed" connection.
Sep 13, 2010 | Microsoft Windows Server 2003 Enterprise...
Cant comp to work,it's plugged in and when you go
Remove Any Docking Stations or Port Replicators From the Computer Note: Docking stations and port replicators are optional equipment. If you are unsure if you have a docking solution attached to your computer, refer to Table 1 and Table 2 for examples. To remove the docking station or port replicator, perform the following steps: Shut down the computer. Remove the docking station: Universal Docking Stations: Disconnect the docking station's USB cable from the computer. D/Port or D/Dock: Remove any cable locks from the security slot on the right side of the docking station. Move the slide lock forward to the unlocked position. Press the Eject button and lift the computer from the docking station. C/Port II or C/Dock II: Remove any cable locks from the security slot on the left side of the docking station. Pull the locking lever forward until it stops to eject the computer, then slide the computer out of the docking station. Dell manufactures the following docking stations and port replicators (Table 1): D-series DocksC-series DocksSpecialty Docks D/PortLatitude? C/Port IIMedia Bases D/DockLatitude? C/Dock IIInspiron? Advanced Port Replicator Table 1: Dell Docking Stations (Click an image to enlarge it) Universal docking solutions are also available from third-party manufacturers including, but not limited to, the products below (Table 2): TargusKensingtonBelkin Table 2: Universal Docking Solutions (Click an image to enlarge it) Disconnect All Peripherals from the Computer Remove all external connections from the computer. This includes but is not limited to the following devices: docking station or advanced port replicator keyboard mouse speakers or microphone printers scanners USB or 1394 devices palm pilots zip drives secondary battery Plug the AC Power Adapter into the Laptop Computer Remove the battery from the computer. Connect the AC adapter directly to the computer Verify That the AC Power Adapter Has a Solid Green or Blue Light Verify the AC power adapter displays a solid green or blue light. Older Latitude? C Series laptop computer AC adapters may not have a light. The new E series power adapter indicator light is either a blue ring or a blue dot and is located at the tip, on the DC connector, not on the power brick itself (Figure 1). Figure 1: E Series Power Adapter Indicator Light Location Numbers reference image above: E Series Power Adapter Indicator - Blue Ring E Series Power Adapter Indicator - Blue Dot D series power adapters have a green lights located on the power brick (Figure2). Figure 2: D Series Powed Adapter Indicator Light Location Numbers reference image above: D Series Power Adapter Power Brick D Series Power Adapter Power Indicator Light Shut Down the System If the computer currently is turned ON, running on the battery, shut down the system: 1 Click Start. 2 Click Shutdown. 3 Choose Shutdown from the menu. 4 Click OK. 5 Allow the system to power off. Plug the AC Adapter into a Known-Good Wall Outlet Verify the wall outlet is known-good by testing it with another device, such as a lamp. Confirm there are no power strips, surge protectors, or uninterruptible power supplies (UPS devices) connected to the power cable. UPS devices provide temporary power for a computer when there is no electricity available from the wall socket, such as during a power outage. Plug the power cable into the known-good wall outlet. Power up the system. Replace the MiniPCI Door, Rubber Feet, and System Motherboard
Nov 07, 2009 | Dell Inspiron 1150 Latitude D600 14.1 LCD...
Refrigerator compartment not cooling properly.
Yes The circulating fan behind the rear freezer wall is waring out. The fan with labor and material cost is around $300.00.
Jul 11, 2009 | Refrigerators
Compaq presario f700 sudden shutdown
Less than one year old? Then, it can be fixed at NO COST to you, via "warranty" from the vendor.
Apr 12, 2009 | Compaq Presario-Notebook 700 Series, 2500...
I took some pictures on my camera and everytime i go to view them it says cannot display image. what do i do?
HP Photosmart E327 has error message Cannot display image. HP website says that it is because of being shutdown improperly. Their suggestion is to transfer them to the pc and keep them their, I guess. Lesson, always shutdown properly.
Cheers
Apr 04, 2008 | Cameras
HP Photosmart C6180 All-In-One InkJet Printer Logo
101 people viewed this question
Seeker5211
Seeker5211
