Question about Sharp Office Equipment & Supplies
Sharp XG-3790E projector switches off soon after it is switched on
  • 2,237 Answers
If you replaced the lamp recently, you'll need to reset the lamp timer. if it's a dlp projector, could be the colorwheel. listen for a high-pitched whir when the lamp strikes. if you don't hear it, replace the colorwheel. if you do, check the fans to make sure they work. if all else is fine, replace the ballast/power supply.
Posted on Nov 17, 2009
Testimonial: "thank you very much for the advice, I will go through your suggested processes. Regards"
Replaced bulb in Sharp XG-E1200U, the red power light comes on, when I turn the switch on nothing happens.
When the XG-E1200U shows the standby light but does not power on, it usually means several of the 100uf 16 Volt surface mount capacitors have dried up on the main board. Recommend replacing all of these for continued reliability.
Sep 03, 2010 | Sharp (BQCXGE1200U1) Projector Lamp for...
Sharp xg-e850u projector owners manual
I've searched all over...heh, I've got TONS of Sharp service manuals but *not* yours...I did find, however, the xg-e650 manuals on manualsparadise.com. Sharp units, a lot of times, are very similar in architecture, functions, parts, etc. For example, practically any Sharp remote will work on your projector...BTW, the lamp you need is a BQC-XGE850U/1 and sells for $292-389 dollars.http://reviews.cnet.com/peripheral-accessories/sharp-projector-lamp/4505-8309_7-31382143.html?tag=mncol;lst
Sep 08, 2009 | Sharp XG-E3500 Multimedia Projector
Need to reset lamp counters on a sharp XG-V10WU
1 turn projector switch off
2 remove lid and remove lamps
3 replace lid with out lamps
4 turn main switch to the on position
5 press the on switch on top
6 press enter
7 flip main switch to the off positon
8 replace lamps and lid
your done!!!!
Aug 03, 2009 | Sharp Projector Lamp for XGV10WU
Sharp xg-ph50x projector overheating
Hi
is the projector enclosed in a cabinet, hanging on the ceiling or on top of a table? needs more ventilation for it not to overheat. you can reseat the lamp, re-clean the filter. Hope this helps.
If issue persist, look for a backup projector so it won't spoil the show. Thanks for using Fixya
May 10, 2009 | Sharp XG-PH50X Multimedia Projector
Sharp xg-v10wu with good lamps and i get two red
check to see if the filter cover is open and/or the lens cover is open. there are switches in both openings, so see if the switches work (they are usually blue).
Apr 22, 2009 | Sharp XR10XL DLP Projector
Missing remote control and projector keylock is on
I think you need remote for above said process.
Get original Sharp remote for XG-P10XU from Sharp Accessories.
Nov 10, 2008 | Sharp Notevision XG-P10XU Multimedia...
My sharp xg-nv2u will not turn on. i have the power cable plugged in and everything is on....
1.Open the lamp cover and reinstall.
2.open the projector and check the Power Supply
3.check fuse/ thermal cut off switch.
Viren
Jul 13, 2008 | Sharp (BQC-XGNV2U//1) Projector Lamp for...
Changing settings
Hi cajun51man
If you go into the User Menu of the Projector look for a subfolder that reads either Flip Image or Mirror.
Scroll down to it and scroll left or right - this will switch between the image features.
May 26, 2008 | Sharp Notevision XG-C50X Multimedia...
Having problems with my sharp notevision XG-C40XE
Your lamp is not lighting up most likely. Try removing the lamp assembly and clean the contacts. If that does not work then you will probably need to replace the lamp. Also try resetting the timers. Refer to you owner's manual for info on how.
Aug 23, 2007 | Sharp Notevision XG-NV6XU Multimedia...
458 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
