Question about Makita HR3000C Electric Rotary Hammer
Whats it mean whene the top light comes on and it wont drill wit the makita hr3000c
Green light up : all electrical contacts are ok
red light on : time to replace carbon brushes ant if possible bring back for maintenance kit
Posted on Nov 17, 2009
How do i get the armature out
But sometimes the armature can be fused in by melting coil part of the electric field you mean ? if the electric field is damaged by overheat some shortened windings then its become sometimes a disassemble problem .
Makita HR3000C Rotary Hammer Parts
Jun 28, 2014 | Makita HR3000C Electric Rotary Hammer
How do I remove the gear knob on a Makita HR3000C rotary hammer drill
http://www.toolpartsdirect.com/manuals/pdf/repair/makita/hr3000c.pdf have a look at the manual here on page 6, it gives a description on how to remove the change lever with graphics
Oct 04, 2012 | Makita Drills
MAKITA HR3000C HOW DO I REMOVE THE HAMMER/DRILL MODE CHANGE SWITCH
The big control levers off, but the small one only comes off once you have removed the screw and have it in the down position.
Sep 27, 2012 | Makita HR3000C Electric Rotary Hammer
Makita HR3000c green light comes when trigger depressed but doesnt work
From the owner's manual: Indicator lamp The green power-ON indicator lamp lights up when the tool is switched ON. If the indicator lamp is lit but the tool does not start, the carbon brushes may be worn out, or the electric circuit or the motor may be defective. If the indicator lamp does not light up and the tool does not start, the ON/OFF switch or the mains cord may be defective.
The easiest to check is the brushes. Most newer tools have brushes with a spring loaded pin in them so when they wear down the pin pops and stops the motor so you don't wear the armature. Even without the pin the wire from the contact to the brush is short so the spring doesn't contact and ruin the armature. If the brushes are OK, you'll have to check the switch for continuity.
Aug 24, 2012 | Makita Drills
Hr3000c
It could be the brushes, see if the are stuck in the brush holders, they might be worn out also. Some of them have cutouts on them.
May 13, 2012 | Makita HR3000C Electric Rotary Hammer
Makita hammer drill hr 3000c has stopped hammering need strip down diagram to locate part fault
go to makitausa.com and you can download a parts schematic there, let me k now if you need more assistance.
Aug 26, 2011 | Makita HR3000C Electric Rotary Hammer
Drill/chisel drops out when useing
if it is the pull-back locking system to hold in the chisel, or drill bit, then the locking- clutch mechanism is worn and needs replaced
Jul 22, 2009 | Makita HR3000C Electric Rotary Hammer
Makita HR3000C Electric Rotary Hammer Logo
267 people viewed this question
Top Makita Drills Experts
epangan29
John Trevino
Are you a Makita Drill Expert? Answer questions, earn points and help others
