Question about Nokia 3600 slide Cellular Phone
How to save my pictures using usb to the computer? how to read the usb set-up?
How to download pictures from phone to a USB drive
Both devices are USB slaves. You need a USB master, such as a computer. If your computer has two free USB ports, you can connect both machines to the computer and simply drag-and-drop the pictures from one to the other,
If you only have one USB port, then connect the phone drag=and-drag the pictures to a temporary folder on your computer, then disconnect the phoe, connect the tablet, then drag-and-drop.
Oct 29, 2016 | Cell Phones
Can't save pictures to media
Pull the card out and look for a switch. Is it set to lock (read-only)? Unlock it.
Dec 24, 2012 | Electronics - Others
How do I get the saved files from my GoFlex on my new computer
You should be able to just plug it in to USB and read them since the harddrive has aleady been set up and used. The new machine should read it just like it will read a thumb drive you've saved files on. This is one of the big reasons why people like these external drives :) You can take them with you and use on another computer.
May 28, 2011 | Seagate FreeAgent 2TB GoFlex Desktop USB...
How do i get internal pictures off my panasonic Lumix DMC-LZ3
If you take the memory card out of the camera, you can view the internal pictures one by one, and delete them, or transfer them to you computer through the cable...they will show up as another drive in Computer, or My Computer, depending on which version of Windows you are running.
Good luck, and hope this helps.
May 03, 2011 | Cameras
My Scandisk Ultra 2GB shows pictures on laptop, yet not on camera...the pictures are on the card. I did download them on my computer, removed them from the card, zoomed, cropped etc on Windows, then...
It is possible that when you edited the pictures on your computer, that you might have changed the file format when you resaved them.
Check the names of your picture files on the computer and compares the endings (.JPG or .BMP or whatever) between new pictures that come directly from your camera and pictures that you have edited and resaved.
If the formats are different at all, then your camera will probably not be able to read them. Cameras usually save pictures in one specific format and can only read them if they are in exactly that format. A computer on the other hand is much more flexible and can usually read or save pictures in many different formats.
Your computer should give you the option of saving a picture file in a different format if you want. When you edit and save the pictures on your computer next time, use the SAVE AS feature, this should give you the option of changing the name of the file as well as the file extension from a drop down list. Then just try saving the picture files in different formats until you find the one that your camera can read. Or just look in your cameras Owner's Manual and find out exactly what format the pictures need to be in for the camera to recognize and display them from a memory card.
Good luck.
Apr 14, 2011 | SanDisk Ultra II 2GB Secure Digital Memory...
My computers are not recognizing the camera is hooked up with the cable, and thus I can't get the pictures off the camera. I can use a card reader for the ones saved to the memory card, but how do I get...
i don't know how to save the pictures onto the memory card maybe in your settings you can change it to external memory or something and your USB cable is probibly stuffed up so you'll have to get a new USB cable goodluck ;) and please rate this solution...
Jun 06, 2010 | Panasonic Lumix DMC-TZ1 Digital Camera
DSC-S730 copy my picture to my computer?
The procedure to transfer pictures to a Computer depends on whether or not the Camera has the capability of using Picture Transfer Protocol (PTP). If the Camera is capable of PTP (in this case; DSC-S730 - YES), set the USB mode in the Camera menu to PTP and then use the PTP procedure to copy the pictures to the computer. Otherwise, use one of the standard USB transfer procedures.
This procedure must be performed while logged in as Administrator or to an account with Administrator rights:
  1. Turn on the Computer.
  2. Turn on the Camera.
  3. Insert the recording media containing the pictures into the Camera.
  4. Set the USB connection or Transfer mode setting in the Camera menu to PTP .
  5. Use the USB cable supplied with the Camera to connect the Camera to the Computer. NOTE: Connection through a USB hub or other USB device --such as a printer or keyboard-- is not supported and cannot be guaranteed. The Camera should be connected directly to a USB port on the Computer.
    NOTE: The Scanner and Camera Wizard should automatically start.
  6. In the Scanner and Camera Wizard window, click the Next button.
  7. Under Choose Pictures to Copy , do one of the following:
    • Click to select each picture you want to copy.
    • Click Select All to select all the pictures for copying.
    NOTE: Selected images will be marked with a green check mark.
  8. Click the Next button.
  9. Under Picture Name and Destination , in the Type a name for this group of pictures field, enter a name for the folder where the pictures will be saved.
  10. Next to the Choose a place to save this group of pictures field, click the Browse button.
  11. In the Browse for Folder window, click to select the location on the computer where you want to save the pictures.
  12. Click the OK button.
  13. In the Scanner and Camera Wizard window, click the Next button. NOTE: The pictures are copied to the Computer.
  14. After the transfer process it finished, under Other Options , click to select Nothing, I'm finished working with these pictures .
  15. Click the Next button.
  16. Click the Finish button.
If you are still unable to transfer pictures, please switch the USB mode of the Camera to Normal or Mass Storage and try again.
After following the steps above, the pictures from the camera should successfully be copied to the computer. If for some reason the pictures did not copy, try using the method for standard USB picture transfer.
I'm assuming you are using the Windows XP Operating System in the Computer. If not then follow this link:
http://www.kb.sony.com/selfservice/documentLink.do?externalId=C116935
Good Luck!!!!!!!!!!!!!!!!!!!!!!!
Sep 06, 2009 | Sony Cyber-shot DSC-S700 Digital Camera
How do I transfer information from my lg vantage (ie: pictures) via USB connection to my home desktop pc?
By default, all of the pictures you take with the camera on the phone get saved to the microSD card inserted in the slot. There are two ways you can get the photos (and other data) off the card.
1. Using the USB cable that came with the phone, plug it in your computer. Then, tap the main menu, go to settings (the last tab) and then click 'USB Mode'. There, click USB Mass Storage, and your microSD card will be read by your computer.
2. Remove the microSD card (taking off the back panel and pushing down on the microSD card gently; the card will spring out). Insert the card in a card reader and voila. :)
You can then transfer photos to and from your phone (well... actually memory card :P)
Apr 18, 2009 | Cell Phones
When we take pictures using our lg dare cell phone with the disc in the phone. When we plug the disk into our pc it does not read or see the pictures we took.
You need to change your save settings so that your camera save images to the card not the phone.
Turn on the camera. Touch the screen so your menus show up along the edges. Pic the one that looks like a little gear then scroll to the right until you come to the disc with + sign icon(save settings). Choose this then change setting to external.
Youre all set!
Mar 08, 2009 | LG Dare VX9700 Cell Phone
How do i put my camera pictures on my compter?
IF YOU BOUGHT THIS CAMERA NEW, IT SHOULD HAVE COME WITH A CABLE THAT IS USED TO CONNECT YOUR CAMERA TO YOUR COMPUTER. THE CABLE IS CALLED AN " AV/USB CABLE UC-E12 ". IF YOU DON'T HAVE THIS CABLE YOU CAN FIND IT ON EBAY OR FROM THE NIKON ONLINE WEBSITE AND IT DOESN'T COST VERY MUCH. THIS SHOULD SOLVE YOUR PROBLEM. YOUR USER MANUAL SHOULD HAVE INSTRUCTIONS AS TO HOW TO CONNECT THE CABLE TO YOUR CAMERA AND THEN IT JUST PLUGS INTO ANY EMPTY USB PORT ON YOUR COMPUTER. IF YOU NEED MORE HELP, REPLY TO ARCLIGHT1217. IF THIS HAS BEEN HELPFUL, PLEASE RATE, THANKS!
Dec 18, 2008 | Nikon Coolpix S550 10 Megapixel Digital...
Nokia 3600 slide Cellular Phone Logo
46 people viewed this question
Top Nokia Cell Phones Experts
270rexton
270rexton
