Question about GE Monogram ZISS420DRSS Stainless Steel
Refrigerator is not cold, is there a reset button or a fuse and if so where is it
  • jyappl May 11, 2010
    the monogram (sub zero style) Has so many problems that my company no longer services them. Your best bet is to call GE. 1-800-432-2737. Even they dont want to work on it. They might cancle appointments on you(truck broke down, guy called in sick, lost your appointment, etc) Keep on them but good luck finding any one else willing to work on it.
    President:
  • GE Master
  • 1,922 Answers
You need to replace the main controller assembly in the rear lower compartment by the compressor and condenser fan G.E. part # AP3885943 this is why it won't cool properly
Posted on Nov 17, 2009
My unit wont get cold, had power outage and think it needs to be reset. How do u reset compressor or unit?
See this video for the "reset" function of some refrigerators:
Easy Refrigerator Fix Reset Defrost Timer Switch if it stops running...
Does My Refrigerator Have Reset Button
How Do Reset My Frigidaire Refrigerator
Said this, I don't mean to "panic" you but if you can't find this "restet" function, your refrigerator suffered a surge effect and might have some electronic cricuir damaged; in best case, some internal security fuse, typical as result of power outage, when power returns.
If you can't find that "reset" call repair service.
By the way, get a surge protector for your refrigerator as soon as possible. See some typica protectors at Amazon, but you can buy one at your local home depot or outlet store.
1800 Watts Refrigerator Surge Protector
Sep 01, 2015 | Refrigerators
Is there a reset button or internal circuit breaker on sears refridgerator model # 795,7830
Hello;
My name is Peter. I am a retired field service refrigeration technician.
There is not internal circuit breaker or fuse in a refrigerator.
Component failure acts as the fuse.
There is a reset button on the control panel of your refrigerator.
It is a small black button. Located near where the part number is shown on the board. This is rarely the solution to a problem.
You may try to unplug your refrigerator for 30 minutes and reboot your refrigerator.
In your owners manual, it is recommended to install a surge protector. They are a good investment for $20-25.00. Static electricity, the slightest change in voltage and a magnetic field will knock out a electrical control board.
If you elect to press the control board reset button make sure you ground yourself by rubbing your hands on something that is steel.
25134658-bkvywf5rc1reqors4q4ptmqv-4-0.jpg 25134658-bkvywf5rc1reqors4q4ptmqv-4-3.jpg
Sep 24, 2014 | GE Refridgerator Relay Overload Wr07x10011
Where is reset button on rm2611
There is no reset button on that model. If your fridge wont turn on it is more than likely a fuse in the electronic board or that you do not have 12volt going to the refrigerator.
ArctiCold Refrigeration We keep it cold
Sep 18, 2014 | Dometic Refrigerators
Why is my refrigerator not getting cold?
check the fuse for the power point that the unit is plugged into . If there is power there then see if there is a reset button on the back of the unit at the compressor unit . If not call a refrigeration service person as the sealed unit has failed as a major repair is required. Check for warranty period of the unit.
Jul 16, 2014 | Maytag Refrigerators
Where is the reset button on the whirlpool model#ED5PVEXWS00
There is no reset button and you will need to replace the start relay. Here is the part to order. Below is a video to show you how to replace the relay. The model shown may be different but the process is the same.
Dec 01, 2012 | Refrigerators
We have a hotpoint refridgerater that has stopped cooling ..even the freezer and its only 2 years old....are their fuses they may have blown or maybe a reset button?
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator
Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Feb 11, 2011 | Hotpoint Refrigerators
Dometic refrigerator RM 2652 is not working
The fridge needs a 12 volt DC source to operate properly, which should be connected at the back of the fridge, outside behind cover. Check all fuses in your fuse panel as well. The upper controls are powered by 12 volt DC system, and that's what tells the fridge what to do.. (battery or converter)
May 08, 2010 | Dometic RM2852 Refrigerator
Fridigaire FRU17G4JW - all refrigerator unit not cold
Things to check
Check .
for Frost build up and if Fan is blowing,
Check condenser...
To make sure clean, and the fan is blowing by compressor & IF it is running
Check Recirclating Vents in refrigerator... to make sure theres no blockage,
CONTROLS ...should be in the middle setting,
Oct 25, 2007 | Frigidaire FRU17G4JW Refrigerator
Kitchenaid superba refrigerator not keeping cold
press reset botton for five times and it will reset kiki
Oct 12, 2007 | Refrigerators
GE Monogram ZISS420DRSS Stainless Steel Logo
321 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Lawrence Oravetz
okcchemist
Level 1 Expert
