Question about Linksys Wireless-G Broadband Router
Wireless-G Broadband Router Failure.
I have a router that I set up and it worked just fine for quite a while, the all of a suddent, the router goes out and I don't know what to do to fix it.
It has gone out numerous times after it has been fixed by other people. I would plug in my modem and my router, then my desktop can't get internet, then I check both my laptops and they can't detect the internet also.
I need help! I want to be able to fix it on my own.
  • 1 more comment
  • StewE Jan 10, 2008
    It's a Linksys Wireless G Broadband router.
    It uses wires, but then I don't use wires to connect it to my laptop.
    The model is WRT54G.
  • wimbs Jan 19, 2008
    I cannot access the internet thru my linksys. I can access the internet without the router. I have disconnected linksys for several minutes to no avail. I have tried the reset button.PLEASE HELP! wims01@comcast.net
  • Bjpuhala Feb 26, 2008
    I am experiencing the same problems. I try restarting the router with no luck.
    Scholar:
  • 95 Answers
Several things could be happening. 1st I need the model and manufacturer of the router. It would be helpful to know what firmware version it is using. I also need to know if you are using it wired or wireless. Then we can troubleshoot the problem.
Posted on Jan 10, 2008
No connection
Are you trying to set up router ?
Make sure that your computer is able to go online directly through the modem.
If your computer is able to go online through the modem, that means the modem is working fine.
You will need to connect the computer to the router and the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Click Here for more information about the routers and network
Jun 26, 2010 | Linksys Wireless-G Broadband Router
I recdntly bought a new Dell desktop with windows 7. My Dell laptop worked for a few hours and the suddenly would not pick up the internet anymore. I have a linksys wireless-g broadband router which has...
You will need to check the wireless settings of the router.
If your network is secured then make sure that you are typing the correct network key.
also make sure that the DHCP server is enabled on the router.
is there any computer connected to the router ?
If yes then you can open the router set up page on that computer.
Router set up page is the page where you can check all the wireless settings of the router.
Click here for step by step instructions
Apr 29, 2010 | Linksys Wireless-G Broadband Router
Just set up my g broadband router. Unable to connect to internet
Your laptop may not support g wireless. Change the wireless to broadcast B and G
Nov 15, 2009 | Linksys Wireless-G WRT54G Router
No wireless connection :(
If you have your broadband configuration info written down, you could try resetting your router to the factory default settings and then re-configure it.
For most broadband connections, the default settings will work OK, but you should configure your router with a secure administrator password and wireless key.
The user manual for the router as well as configuration software can be found here:
http://www.belkin.com/support/product/?lid=en&pid=F5D7230-4&scid=221
Feb 04, 2009 | Belkin (F5D7230-4) Router (587009)
I have had a wireless dynex router for awhile and it has been working fine using wireless then when i plugged in my computer and xbox 360 to the router it has made the computers using the wireless internet...
it is getting limited or no connectivity because it is actually not connected even though it shows.the best resolution is that change your entire wireless settings and then connect all wireless devices like computer and xbox 360 again it will connect.I use to do the same when i use to work for netgear.
that will fix..
Jan 04, 2009 | Dynex DX-E401 Router
Hi, I have an old acer laptop and my wife communicates with me on it using broadband and a router with a usb pick up. I have returned home and have a new acer laptop with wireless LAN already installed. It...
Youe broadband router is working ok with the broadband cable.So it is configured with the broadband cable.Now,to work with the wireless internet,you have to configured the wi-fi router to work internet.You can see the wi-fi connection but unless & untill you will configure wi-fi router it must not work or if before it was working with the wi-fi then you can check the wi-fi router setting because it might change by mistake.Surely it will work after configurating wi-fi router.
Jan 03, 2009 | Computers & Internet
How to connect maxg with a my netgear broadband router
Try to turn off the DHCP server in the secound router, that way it'll be a swich technically, and set the secound router's fix ip address to something different, because I'm quite sure that both routers have the same 192.168.0.1 IP address and that's nogood.
Set it to anyting from 192.168.0.2 to 192.168.0.254
Nov 26, 2008 | U.S. Robotics MAXg USR5421 802.11g/b...
Linksys Wireless G Router Set up
I ended up loading the router setup cd onto another laptop, and it worked fine. I still don't know why the first laptop had the error code, but they now both, work perfectly fine. Thanks, anyway.
Sep 06, 2008 | D-Link DI 514 Wireless Router (DI-514)
Linksys Wireless-G Broadband Router Logo
70 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
