Question about HP NC8000 PC Notebook
My NC8000 laptop has 2 USB 2.0 port but it is only
My NC8000 laptop has 2 USB 2.0 port (according to the specs) but it is only running at USB 1.0 speed. When connected with an USB device, Windows shows msg "this device can run faster if plugged into an high speed USB 2.0 port". Any suggestion where I can get a driver update?
  • wongster05 Nov 17, 2009
    I went to HP site and browsed the available drivers for download, just can't figure out which one(s) to use......
    Brigadier General:
  • 10,406 Answers
Does this laptop have a built in wireless card?
No This is a reasonably old system, You will need to use either a PCMIA wireless card, or a usb wireless adapter. Both of these can work with this system.
Feb 04, 2011 | Dell Latitude C510 Notebook
I have found compaq Evo N1000c notebook quick specs but not the same ports etc as mine. Full description is: series PP2140-SN 9X39KQDZCOBS-N1000C P 180X4 30 V C 250 AUST(OPERATING SYS.XP PRO. I am...
  • See http://h18000.www1.hp.com/products/quickspecs/11408_div/11408_div.HTML
  • 2 - USB 2.0 EHCI ports (1.1 OHCI Compatible) USB2
  • 1 - PC Card Slot Supports 16 & 32 bit, Type I & II cards PCMCIA Slot for anything PCMCIA
  • 1 - Fast Infrared Port Self explanatory, use with your mobile phone or an infra red printer port
  • 1 - Parallel Port 1 - VGA Port Printer Monitor
  • 1 - Microphone in Port Self explanatory
  • 1 - Headphone out Port Self explanatory
  • 1 - RJ-11 Port Telephone line modem
  • 1 - RJ-45 Port Network cable
  • 1 - 1394 Firewire Port for anything Firewire
  • 1 - AC Adapter Port Power in
  • 1 - PS/2 Mouse or Keyboard Port Self explanatory
  • 1 - S-Video Port S-video
Feb 01, 2011 | HP Compaq Evo Notebook N1000c
Laptop Model : Dell XPS 1530 i think i m having some problems with the usb power issue. Problem 1: when i connect an external hard drive which have bigger capacity than 120gb, the power of the usb will...
It sounds like the motherboard is causing the usb ports to malfunction by allowing power surges into the power input to the ports.You maybe should try a powered usb hub to power your hardware or you may face motherboard replacement
Jan 10, 2011 | Dell XPS M1530 Laptop
Does my Inspiron 9400 Laptop have build in microphones?
Yes It is. You can check them either in COntrol Panel > SOund or Start > Run > DXDIAG.
WIth regards
FIXYA team
Oct 09, 2010 | Dell Inspiron 9400 Notebook
Windows 7 64bit with support for USB 2: when I plug my pendrive in a USB port, there's an advice saying that if I plug it into a USB 2 port, it will perform faster. But how do I know which port is USB 1...
I hate this message.
You can use a program like PC Wizard from CPUID that will tell you what all of you pc specs are.
From your specs you may not have usb 2 ports.
Device manager should also say what usb ports you have.
The best ports to use are the ports on the rear of the computer, front usb ports sometimes dont have as much power to drive external hard drives or high drain devices
Jul 10, 2010 | Linare Desktop, AMD Sempron 2200,40 GB HDD...
This usb device can perform faster if you connect it to a hi speed usb 2.0 port. I have an hp pivilion dv 6000, and according to the specs, I have usb 2.0, but I get this message every time I plug my flash...
This is just an error message. Yes, your HP Pavillion has USB 2.0, but there's a possibility that your USB flash drive has USB 1.1 specs.
If the flash drive has USB 1.1 specs, you would still get the same message. Again, this is just a message because USB 2.0 is backwards compatible with USB 1.1.
Have a great day!
Oct 10, 2009 | HP Pavilion dv6000z Notebook
Hi-speed USB host
this means that you do not have a USB 2 port or do not have the USB2 drivers installed correctly if it does,
check your chipset drivers and spec of laptop with manufacturers.
if you do not have usb2 you can get a USB 2 PCMCIA card to supply this functionallity.
it is possible this is a USB low power issue as this is a laptop, but check your drivers and spec first.
Jul 05, 2008 | Sony VAIO Digital Studio PCV-RX860...
Power on password on Compaq NC8000
close to the CMOS battery there will be a BIOS jumper. This jumper usually is colored dif. from all the rest and is labeled commonly (but not always) "J4". The CMOS jumper usually is a 3 pin lead setup and normal operating mode most of the time is with the jumper on pin 1 & 2. If this jumper is on the first and second pin you are going to then move it to the second and third pins and let it sit for about 30 seconds (or place it on pins 1 & 2 if it originally resides on 2 & 3). Once you have done that you will then replace the jumper back as you found it and reconnect all your input/output devices. Power on your computer, boot into BIOS, and use auto detect for your hardware specs. Most of the time you wont have to touch anything setting wise in the BIOS (if its good firmware it detects everything by itself).
Apr 12, 2008 | Compaq NC8000 Notebook
HP NC8000 PC Notebook Logo
170 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
