Insignia ns-pdp50hd: power went dead, no standby
Insignia ns-pdp50hd: Unit went dead while it was on, won't turn on again. No standby or power light. No response to remote or side panel controls. Wall outlet is hot, power cord is fully seated. Seems like a fuse or something tripped or failed.
Had the exact same problem..outta warenty so I opened up and found three fuses inside,,one on the power supply board it's a funny little ceramic fuse...got it at the second Radio Shack I went to.came home,popped it in and bing bang boom it's fixed and running great!!
ordered more fuses and the geek squad at best buy gets nothing!!
Posted on Feb 15, 2010
    President:
  • 1,779 Answers
This could be your Power Supply Module or your Main board. I suggest taking it in for a diagnostic check.
Posted on Nov 17, 2009
I have a insignia ns-pdp50hd-09 plasma tv that has sound but no picture
You may try using the power switch on the TV itself instead of the remote. I have had trouble where the remote turn on doesn't work for the video, holding down on remote button longer seem to help.
Also you may want to try another input to the TV -so connect up input wires from your cable/sat to another one.
Jul 01, 2014 | Panasonic TC-26LX20 26 in. HD-Ready LCD...
I have a Insignia NS-L32Q-10A that will not power on. Now power on light or standby. I have replaced the power supply already. All caps look good and fuses check OK. What next???
ok, when you plug in the set, does the power light come on? Assuming you ordered a power supply in good working order, you may very well have a faulty main board. The power supply produces standby power that the main board uses to power the standby/power on light. Your main board also uses the standby power to provide the "ON" signal to turn on the rest of the power supply.
Feb 02, 2013 | Insignia NS-L32Q-10A 32 in. HD-Ready LCD...
We just bought a NS-PDP50HD-09 Insignia 50" plasma
Although we would not be able to assist you with power issue you're having with your TV, I can assure you that the issue with your new HD Insignia TV not turning on has nothing to do with the DISH Network receiver you have connected to it.
Phillip Chang
DISH Network Customer Service Representative
Feb 14, 2011 | Insignia 50 in. Flat-Panel Plasma HDTV
Insignia ns-pdp50hd-09 plasma hdtv will not power on. I opened it and found 2 bad capacitors on the Y-main board. I changed them but it is still doesn't work. When you turn it on it makes few clicks than...
Hi red, My name is John. Welcome to FixYa. Go back and check your plugin connections. Make sure that they are making a good connection, some can be hard to make contact.....John
Dec 11, 2010 | Televison & Video
NS-PDP50HD-09 Insignia 50" plasma HDTV I bought it from Best Buy about 2 years ago. About a month ago, it started turning off by itself, and now no picture or sound comes on altogether. The power light...
Since the power light is on the standby circuit is working fine and it is cutting up on powering the circuits, so either it could be a safety trigger or a failer. you will need to cross check by omission flow charting to find out if it is the Main power or the drive power.Check for dry joints or loose connection by tapping the main board to see any reaction to start up. good luck
Jun 29, 2010 | Insignia 50 in. Flat-Panel Plasma HDTV
I can not play my PS3 on HDMI "unsupported mode".
While turning the PS3 on from standby, hold down the power button until the unit beeps twice (it'll beep once right away, and again maybe 5-10 seconds later). That should reset the video output of the unit back to default, and you can go from there picking supported resolutions.
Jan 10, 2010 | Insignia NS-LTDVD19-09 LCD TV
Insignia plasma model ns-pdp50hd-09: When powered on the unit functions great for 15-20 minutes and then slowly begins to fade out to a black screen while audio maintains output.
if you want to narrow it down a bit-go to radio shack get some freeze spray.remove back-lay it down -use a blow dryer to heat each board till it goes out-then use the freeze to cool each board down till it works-do it a few times to make sure you get the rite board---now go to shopjimmys.com to find your board
Sep 04, 2009 | Televison & Video
Screen frozen cannot turn player on or off
Well, mine was frozen, and wouldnt respond to anything i was doing. so it wouldnt turn off. I let it stay on all night, but in the morning i went to it, and it was dead, so i went and plugged it up to charge, once it got a little battery, I turned it on, and it worked perfectly fine. try thisss(:
Jul 23, 2008 | Insignia NS-DV2G MP3 Player
Televison & Video Logo
330 people viewed this question
Top Televison & Video Experts
Electro Med Services...
