Question about Sony PlayStation 2 (PS2) Console
No vibration in the analog controller but the vibration is on
  • Sony Master
  • 3,866 Answers
The little motor inside would have a issue you can try to chec k this by hooking it up to another system and see the it does not work you can fix this by replacing the little motor the creates the vibration or buy a new joystick
thanks and please do leave positive feedback for your free naswer today.
Posted on Nov 17, 2009
I have a dualshock 2 analog controller for the PlayStation 2, and after a couple of years, the vibration function quit working. What can I do to get it back working again?
Take it apart and check that the little motors are OK if faulty replace them if not the fu? part starts now
Check the wiring back from the motors and the printed circuit board for damage or a poped component
Or buy a replacement
Oct 14, 2016 | Video Game Consoles & Games
Left analog stick drifting left
Hello Iwn666,
There could multiple things wrong, and hopefully nothing serious. Here is a complete list of some problems and solutions that can be wrong with the analog stick.
1. The Left analog stick may be sticky. If you eat greasy foods while playing your Xbox 360 console, try to avoid this from now on. Grease from food particles may slip into the analog stick, and make it sticky, causing the analog to move constantly to one fixed position. Please look at the next problem and solution ahead before attempting to remove your controller with a screwdriver. Here is a complete guide on how to access the inside of an Xbox controller.
http://www.ehow.com/how_5410334_fix-xbox-controller.html
2. There may be a simple glitch in configuration. Try turning off your Xbox 360 controller by holding the Xbox Guide button for approx 4 seconds untill a menu comes up. Select "Turn off controller". After doing so, try turning on your controller again. If the problem persists, there may be a greasy analog stick, or an object that broke that holds the analog stick together. Go back to problem/soltution #1.
Nov 12, 2011 | Microsoft Xbox 360 Controller
Can you use Logitech Rally Vibration Feedback Wheel Steering Wheel in PS3?
No, it doesn't unfortunately. The wheel's controller portion works well, but as soon as you start racing, the analog portion of the controller- namely the padals and wheel- do not work. Time for an upgrade.
**Tested on Gran Turismo 5.**
Dec 06, 2010 | Logitech Rally Vibration Feedback Wheel...
I noticed that every time I buy new PS2 Dual Shock 2 it only last for 3 months because I play to much almost everyday then when I try to open the black wire of the dual shock the colored wires some...
Hi, This is happen because : 1. You may bought a non original controller. 2. You may always engage the vibration function. Sony dual stick controller ( analog stick) has fine cables inside controller. The imitation ones even smaller. While you use the vibration function for long time, it make some cables apart.
Suggestion :- Use only original dual stick controller ( analog stick). Don't engage vibration function for long time - I believe you can reconnect the wires inside controller ( so just fix it yourself) and play..
Dec 01, 2010 | Sony PS2 Dual Shock 2 Controller...
How to make a ps2 controll vibrate
if it's a dual shock controller, press the analog button.
that should do it.
press it again to turn it off.
hope this helps :D
Aug 18, 2010 | Sony PlayStation 2 (PS2) Console
Right analog pulls to the left no matter what I do!!!
you have to configure settings in control pannel as well as in the gaming screen ,adjust the control as they get swapped........reconfigure the control
May 08, 2009 | Logitech Rumblepad 2 Vibration Feedback...
Right analog stick not working
Check the controls on the game's control section. If you play another game that uses the right analog control and it works on that game then it's the control set up for FIFA. Make sure that the analog control light is on when the game boots up. Sometimes if the analog control light is not on when you turn the game on and you turn it on afterwards, the analog stick controls don't work properly. That happened to me on NFS Pro Street. If this helped you leave feedback please. FIXYA!
Feb 19, 2009 | Sony PS2 Dual Shock 2 Controller...
I have just been offered a logtech wingman/rumble controller/FS2004 concord ect,what is it and how does it work,what kind of equipment do i need?pc,console if so what type
  • This item is a game playing device for PC.....desgined for window 95/98. It boasts:
  • Sophisticated dual motor technology provides maximum vibration feedback
  • 2 ultra-accurate and responsive analog sticks for precise 360 movement
  • Easy-to-reach throttle control
  • Convenient USB interface
Also manufacturers description states: Just try and hold on to the new WingMan RumblePad gamepad. Boasting nine programmable buttons, the RumblePad offers a sliding throttle for precise speed control, plus two analogue sticks to let you quickly rotate a full 360 degrees. But it's the vibration feedback that will truly rock your world! Two motors housed in the RumblePad grips let you feel every turn, bump and dip in flying, driving, adventure, SIM games and more. No batteries are required as it draws power from the USB port on your PC.
Please leave me a positive rating if you feel the description was helpful. Thank you!
Sep 03, 2008 | Video Game Consoles & Games
Ps2 dualshock analog controller not vibrating
Usually, all dualshock controllers malfunction after a year or so. Do not be surprised.
Sep 10, 2007 | Sony PlayStation 2 (PS2) Console
Sony PlayStation 2 (PS2) Console Logo
150 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
