Question about Motorola Mobility L6 Cellular Phone
The roaming is not working in the california the network provider said that it was in the phone set up
What is data roaming
Data roaming is simply cellular internet data but using out of your country. For ex. when you go on holidays to Spain you can use cellular internet from roaming. Roaming is for calls and sms too. And important thing is that roaming is much more expensive then normal in your country
Jan 08, 2015 | Cell Phones
Samsung flip phone manual
Roaming setting is part of a service from your phone service provider and is not controlled by the phone itself. You will have to call your phone service company and find out what roaming you need.
The network selection mode setting will have to change on your phone to ensure you pick up the correct network overseas once your roaming service is set.
Aug 29, 2014 | Cell Phones
Does my nokia 2220s purchaes in australiawork in canada. wont let me txt or call and says NO NETWORK COVERAGE Please advise howto change settings
hi there!
that actually depends on the network provider (telco) that you have (at&t, telus, verizon, etc) these phones have roaming capabilities but that is still based on the subscription you have with telco. better call your telco about this issue and request for roaming settings. if thats not possible, your phone must be open line with other network provider for you to be able to use a different sim card.
Apr 08, 2011 | Nokia Cell Phones
My phone is saying digital roam mode when i make an outgoing call, how do i take it off so i can make outgoing call with no problem.
This is pretty much what you need to do. Just turn off all the roaming features. However when you roam it typically means you dont have service through Sprint so dont be surprised if when you turn off roaming capabilities your phone doesn't get ANY signal. Here's the link to your phones manual page 112 is about roaming.
Setting Roam Mode
Your phone allows you to control your roaming
capabilities. By using the Roaming menu option, you
can determine which signals your phone accepts.
Choose from two different settings on your phone to
control your roaming experience.
1. Press > Settings > More... > Roaming > Set Mode.
2. Highlight an option and press .
n Sprint Only to access only the Sprint network and
prevent roaming on other networks.
n Automatic to seek service on the Nationwide Sprint
Network. When Sprint service is unavailable, the
phone searches for an alternate service.
Call Guard
Your phone has two ways of alerting you when you are
roaming off the Nationwide Sprint Network: the
onscreen roaming icon and Call Guard. Call Guard
makes it easy to manage your roaming by requiring an
extra step before you can place or answer a roaming
call. (This additional step is not required when you make
or receive calls while on the Nationwide Sprint Network.)
To turn Call Guard on or off:
Call Guard.
2. Select On or Off.
To place roaming calls with Call Guard on:
1. From standby mode, dial 1 + area code + the
seven-digit number and press .
2. Read the message and press .
Note Call Guard is turned on by default on yourphone.
To answer incoming roaming calls with Call Guard on:
1. Press .
Data Roam Guard
Depending on service availability and roaming
agreements, yourphone may be able to access data
services while roaming on certain other networks. You
can set your phone to alert you when you are roaming
off the Nationwide Sprint Network and try to use data
services such as messaging.
To set your Data Roam Guard notification:
Data Roaming.
n Always Ask (default mode) sets your phone's Data
Roam Guard feature on. You will see a prompt that
will require you to respond anytime you access
data services while roaming.
n NeverAsk turns your phone's Data Roam Guard
feature off. Your phone will not notify you of your
roaming status when you access data services.
Touse data services when Data Roam Guard is active:
© When a notification appears informing you that data
roam charges may apply, press ROAM (left softkey)
to connect.
Note If the Call Guard feature is set to On, you need to
take extra steps to make and receive roaming calls.
Mar 08, 2011 | Sanyo SCP-2700 Cell Phone
My samsung tocco lite has only just started showing a r next to the signal strength what is the R representing
It stands for roaming, which means that the phone is connected to your providers network. You may want to check with your provider to make sure that your not being charged extra for roaming, as this can become costly.
Hope this helps
Ray
Mar 03, 2011 | Cell Phones
HOW TO ACTIVATE A ROAMING???
go to your network settings but firstly, dont forget to contact your network provider to confirm that you want roaming for your line.
Apr 25, 2010 | Motorola Mobility Krave™ ZN4 Cell Phone
I cant manually activate my blackberry pearl I went to options, mobile network but all it says is roaming.
See if this works....
-Press menu key
-Click OPTIONS
-Select Mobile Network
-Click on "START PROVISIONING"
It should give you a message saying: PROVISIONING COMPLETED SUCCESFULLY.
You wont need a MSL code if you do it this way.
Nov 13, 2009 | RIM BlackBerry Pearl 8130 Cellular Phone
Red triangle on left hand top corner - K800i
hi
triangle means roaming if its a red triangle then your internet is turned off while roaming
go to options>mobile network> data services and select what setting you would like either on all the time, off, or off while roaming
solid triangle means extended network (coverage with another carrier that your service provider has an agreement with). some services might not work
blinking triangle is roaming (on a network with no agreement)...most carriers have simply disabled roaming entirely, you either get their network, or extended network to avoid additional charges. int'l roaming is different, not restricted. if you're near either of the borders, i'd say choose "home only" under network options to avoid int'l charges
Hope that helps
May 25, 2009 | Sony Ericsson K800i Cellular Phone
NO NETWORK COVERAGE ON MY SONY ERICSSON K800I
Try setting your handset to manual network selection and select the network for your connction provider. If you don't roam around much, this works well. Please revert back to the automatic network selection if you go on Roaming.
Try & reply.
Sep 11, 2008 | Sony Ericsson K800i Cellular Phone
No coverage
hmmm. I had a similar problem when I tried to use an hiphone i32triband (the seller said it was a cect168 quadband)...does your wireless network support g3 quadband? or your phone's band? and if so, is your phone at the proper setting? go to settings on your phone and make sure it's at your network providers' band setting. You can also go to this supremely useful website, GSM roaming-US, http://www.gsmworld.com/roaming/gsminfo/cou_us.shtml and find your network provider's details there. u gota sweet phone!!!
Jun 12, 2008 | Samsung Ultra Smart F700
Motorola Mobility L6 Cellular Phone Logo
23 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
Rami Obeid
Level 1 Expert
D. E. Hev
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
