Question about Sony PlayStation 2 (PS2) Console
PS2 Video Only had this PS2 for about a year, was working fine and now the video output is horizontal lines. I have checked the connections all, ok. I can hear the audio and the games seems to be running just the video is messed up. Any suggestions? Thanks, Gene San Antonio, Texas
    Genius:
  • 1,003 Answers
Clean lens with canned air and wipe rubber wheel on top of drive motor off with rubbing alcohol applied to a microfiber towel reassemble and have fun
Posted on Jan 13, 2008
  • DENNIS MITCHELL Jan 14, 2008
    replace cord that connects video and audio from the game console to the tv i have seen this before you can get a cord like this a gamestop walmart or target stores
When tv is powered on tv only displaying channel number and sound -no raster. using video mode displays are ok. sound is also ok
Check and replace damaged component/s at its horizontal scan output section circuit. Check the LOT (Line Output Transformer) too for damage. Replace the horizontal scan output transistor. Check the input voltage to LOT. If the voltage is absent check the feeder resistor; if any. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
Dec 06, 2014 | Sharp Televison & Video
No vertical output, but vertical ic workng fine,vertical supply ok,
Touch the input pin of the vertical IC, by the blade of the screwdriver, and see whether there is a tendency to change with width of the horizontal line on screen. If so, check and replace the horizontal, video if, vertical oscillator jungle IC. Check the frequency to the input of the vertical scan IC, with a frequency meter. If there is frequency, and still no vertical scan output, check the yoke connection, and make sure that it has no open circuit. If you wish to get some details, http://electronicshelponline.blogspot.com/ Pull up older posts.
Dec 18, 2013 | Televison & Video
I have an old 36 inch widescreen Philips CRT TV which has been working fine for 7 years until yesterday when the whole screen just went blue with a series of white horizontal lines. The audio is still OK...
Hello
Since there is a blue screen atleast, I don't think that the picture tube is gone. The fault may be either to its chroma IC or video output section. In both sections fault cases, this type of horizontal lines [parellel to each other at about 1 inch or so apart the entire screen] will be seen. Just check the voltages at the three cathode, ie, red, blue and green of the piclture tube. This can be measured at the picrture tube neck card. If you have through knoledge in electronics, have patience and enough tools to do the work, inform me through Fixya. Without these, you can't work on a tv, especially in Philips.
Otherwise, get it checked by any expereinced service technician. OK.
Feb 21, 2011 | Philips Televison & Video
My rca, when started, the sound come on but not the picture
Hello
Either your RCA tvs horizontal oscillator section or it LOT [Line Output Transistor} has some trouble. You just open your TV and check the voltage at the LOT pin. It should be around 112VDC or so. Check the voltage at its line drive transformer also. It is a small transformer diretly soldered on to the main board, and can be located very close to the above said LOT. Check voltage at its primay side , and if you have a digital multimeter capable of measuring frequency, check the frequency at this point. It should come around 15500Hz or so, without video signal. As far as sond is OK, all othere sections, ie video IF, Tuner Audio output and so, are working properly, only horizontal output is not. Check the horizontal output transistor, which drives the LOT, can be located very near to the LOT screwed onto a metal heatsink. If it collector to emitter or collector to base junction has some leak, it won't work properly, LOT will not work, and there will be no EHT [Extra High Tension], and will be no screen at all. Check these. If you wants anymore asistance from me, get me through Fixya. The fault with your TV is no horizontal sweep. OK.
Jan 08, 2011 | RCA F27442 27" TV
SONY PS2 doesn't show normal view?
This is a sign of a bad video cord. replace it and it should work fine.
Apr 03, 2010 | Sony PlayStation 2 (PS2) Console
Connecting PS2 to Bose Lifestyle 18
we use the AUX for our PS2 and it works just fine and use the yellow cord into the video in on the tv, the red and white into the BOSE
Dec 27, 2008 | Bose Lifestyle 38 System
Screen only showing single line of video in center.
hi there, is the single line horizontally or vertically? if horizontal line, you do have a vertical section problem, check some parts at vertical section, the vertical ic, the power source of vertical section ie diode & resistors. ty
Dec 26, 2007 | Zenith Z32X31D 32" TV
Horizontal lines
it is due to electrolytic capacitor failure in vertical output section.
just get it replaced.
it very very common & minor problem.
good luck.
Oct 17, 2007 | Toshiba 27AF43 27" TV
32 in RCA MODEL NUMBER f32650
TV FINE UNTIL 2 NIGHTS AGO HAVE HAD 4 YEARS, STARTED HAVING A FOGGY SCREEN WITH WHITE HORIZONTAL LINES. HAS SOUND A FOGGY SCREEN WITH WHITE HORIZONTAL LINES. called retrace lines please check 1 screen control on eht transformer is mituned 2 supply to screen of crt 3 supply to rgb video output is absent 4 connector loose 5 crt base loose thanks
Sep 11, 2007 | RCA F32650 32" TV
Sony PlayStation 2 (PS2) Console Logo
112 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
