Question about Dual Electronics CECT P168 Cellular Phone
No service shows on my phone - Dual Electronics CECT P168 Cellular Phone
What are the codes for Samsung Android phone
Samsung secret code by Mubarak Sulaimon
*#06# - IMEI number
*#0*# - Enter the service menu on newer phones like Galaxy S III
*#*#4636#*#* - Phone information, usage statistics and battery
*#*#34971539#*#* - Detailed camera information
*#*#273282*255*663282*#*#* - Immediate backup of all media files
*#*#197328640#*#* - Enable test mode for service
*#*#232339#*#* - Wireless LAN tests
*#*#0842#*#* - Backlight/vibration test
*#*#2664#*#* - Test the touchscreen
*#*#1111#*#* - FTA software version (1234 in the same code will give PDA and firmware version)
*#12580*369# - Software and hardware info
*#9090# - Diagnostic configuration
*#872564# - USB logging control
*#9900# - System dump mode
*#301279# - HSDPA/HSUPA Control Menu
*#7465625# - View phone lock status
*#*#7780#*#* - Reset the /data partition to factory state
*2767*3855# - Format device to factory state (will delete everything on phone)
##7764726 - Hidden service menu for Motorola Droid
Update x1: More codes!
*#*#7594#*#* - Enable direct powering down of device once this code is entered
*#*#273283*255*663282*#*#* - Make a quick backup of all the media files on your Android device
*#*#232338#*#* - Shows Wi-Fi MAC address
*#*#1472365#*#* - Perform a quick GPS test
*#*#1575#*#* - For a more advanced GPS test
*#*#0283#*#* - Perform a packet loopback test
*#*#0*#*#* - Run an LCD display test
*#*#0289#*#* - Run Audio test
*#*#2663#*#* - Show device's touch-screen version
*#*#0588#*#* - Perform a proximity sensor test
*#*#3264#*#* - Show RAM version
*#*#232331#*#* - Run Bluetooth test
*#*#232337#*# - Show device's Bluetooth address
*#*#7262626#*#* - Perform a field test
*#*#8255#*#* - Monitor Google Talk service
*#*#4986*2650468#*#* - Show Phone, Hardware, PDA, RF Call Date firmware info
*#*#1234#*#* - Show PDA and Phone firmware info
*#*#2222#*#* - Show FTA Hardware version
*#*#44336#*#* - Show Build time and change list number
*#*#8351#*#* - Enable voice dialing log mode, dial *#*#8350#*#* to disable it
##778 (+call) - Show EPST menu
These codes are specific to HTC devices only:
*#*#3424#*#* - Run HTC function test program
*#*#4636#*#* - Show HTC info menu
##8626337# - Run VOCODER
##33284# - Perform field test
*#*#8255#*#* - Launch Google Talk service monitor
##3424# - Run diagnostic mode
##3282# - Show EPST menu
##786# - Reverse Logistics Support
WLAN, GPS and Bluetooth Test Codes:
*#*#232339#*#* OR *#*#526#*#* OR *#*#528#*#* - WLAN test (Use "Menu" button to start various tests)
*#*#232338#*#* - Shows WiFi MAC address
*#*#1472365#*#* - GPS test
*#*#1575#*#* - Another GPS test
*#*#232331#*#* - Bluetooth test
*#*#232337#*# - Shows Bluetooth device address
*#*#8255#*#*
This code can be used to launch GTalk Service Monitor.
Codes to get Firmware version information:
*#*#4986*2650468#*#* - PDA, Phone, H/W, RFCallDate
*#*#1234#*#* - PDA and Phone
*#*#1111#*#* - FTA SW Version
*#*#2222#*#* - FTA HW Version
*#*#44336#*#* - PDA, Phone, CSC, Build Time, Changelist number
Codes to launch various Factory Tests:
*#*#0283#*#* - Packet Loopback
*#*#0*#*#* - LCD test
*#*#0673#*#* OR *#*#0289#*#* - Melody test
*#*#0842#*#* - Device test (Vibration test and BackLight test)
*#*#2663#*#* - Touch screen version
*#*#2664#*#* - Touch screen test
*#*#0588#*#* - Proximity sensor test
*#*#3264#*#* - RAM version
May 04, 2016 | Samsung Cell Phones
My cell phone shows no service
if your cell phones no service , you can use
Feb 28, 2016 | Cell Phones
Codes for samsung
*#06# - IMEI number
You can find more of these spread across the internet, and they're usually very handy to have, even if just to show off your geekiness to your social circle.
Mar 14, 2014 | Samsung Galaxy Cell Phones
My sony fon G502 restarts n sometime hangs is there any solution for this?
This is a common problem for Sony Ericsson G502.
Please try a Master reset for the cell and then update your service.
Master reset
Menu > Settings > Master Reset.
Update service(needs internet active)
Menu > Settings > Update service
If not actioned on time your Mobile screen would become blank then only the service center guys could help you.
Do not try any service center other than authorised Sony ericsson.
Jan 10, 2011 | Sony Ericsson G502 Cellular Phone
Why is my service disabled, but I have minutes?
With TracFone, you not only need to have minutes, but also service time. Check your phone's display to see if your service time is up. (I have a Samsung TracFone and it tells the number of service days remaining, but my old Motorola showed an expiration date. Your Motorola model may show the date too.) You'll lose service if you don't add more time by the end of service date, even if you still have minutes. As long as you add some more airtime within a short time (I don't remember the exact number of days), you'll keep the same number.
If the phone shows you haven't reached the end of service date and you still have minutes left, there's some other problem that TracFone will need to look into. Their customer service number is 1-800-867-7183.
Hope this helps and that you're back in service soon. Thanks for using Fixya!
Nov 06, 2010 | Motorola Mobility TracFone w175 PayAsYouGo...
Nokia phone 3120 showing contact service
NOKIA 3120 contact service display on lcd after switch on
Dec 13, 2009 | Nokia 3120 Cellular Phone
Dual Electronics CECT P168 Cellular Phone Logo
69 people viewed this question
Top Dual Cell Phones Experts
William Alequin
Computer Repairing
Computer Repairing
Shehu Pro
Shehu Pro
Are you a Dual Cell Phone Expert? Answer questions, earn points and help others
