Question about Whirlpool Dryers
The heat element went out on my dryer a few months ago, then yesterday it stopped in the middle of a load. now it wont spin or anything.
    President:
  • 744 Answers
Hello, you either have a problem with the door switch or the thermal fuse. check the door switch by hitting it manually with the door open. if the light does not switch on or is on all the time its a bad door switch, if the light switches on and off ok then the problem is going to be the thermal switch. it looks like this. the heat element went out on my dryer a few months - b18122b.jpg Hope this helps. Mike
Posted on Nov 17, 2009
LE5800XKNO dryer not heating
The heating element may have failed
Jan 22, 2017 | Dryers
I have a Maytag Model LDE4916ACE dryer that recently the timer stopped woking two days ago, the next load it did the same went and went now today it does not heat. Any clue?
the heating element has overloaded and shorted out - new heat element is required along with a new timer switch .
Jul 23, 2011 | Dryers
Hello, I have Kenmosre 90 series dryer. Did a load ealier today, and it was fine. Went back to put another load in and realised NO heat was on, absolutley no heat in the dryer, the air inside is room...
you may need a heating element. You can go to your locale appliance store and buy the element & install it yourself . Just make sure you take All your dryer info, (etc; the dryer model, make, yr & the serial # ) this info is easy to find, its located inside the dryer door. Just call around your locale area and ask them how much it is for the heating element, for your dryer. It should be rather cheap compared to the cost of Kenmore appliance company coming out to fix it for you. The heating element is rather easy to install. I have installed a few in my own dryers and in my hot water heater.
Thank you.
Sincerely,
cat2868
Jan 28, 2011 | Kenmore 62802 Electric Dryer
Heating element is not working
I would say it could be one of two things. The heating elements could be bad, not likely though as the were working when the dryer was reset. You may want to try changing your circuit breaker, as your heating elements work off of the 2 phase 240 voltage while everything else in the dryer works off 120V. Check the voltage on each phase of the breaker in your electric panel see if your putting out the full 110-120V per phase.
Jan 09, 2010 | Frigidaire GLER331A Electric Dryer
The heating compenent works, but drum won't spin
Have you checked the belt? That's generally the problem when a dryer stops spinning.
May 19, 2009 | Whirlpool LEQ9858L Electric Dryer
Inglis dryer-spinning,not heating,Inglis washer not spinning well
Your heating element is going out. Mine did this a few months ago. It is an easy fix. Look up the part online.
Apr 13, 2009 | Amana 3.2 cu. ft. Top-Load Washer
CDE6000W, Crosley dryer stopped working in middle of load
it could just be the motor going out some dryers only last 6-8 yrs some dryers continue to be quite even if there going out i suggest call a repair preson to see if repairing it is worth it
Here To Help
Shaun
Nov 17, 2008 | Crosley CDE6000 Electric Dryer
Dead dryer
usually when the thermal fuse goes bad the dryer will not respond to anything but your job will be to remove the back panel and test the fuse with an ohm meter it looks almost like your old glass auto fuses about an inch - inch and a half except its probablly black or gray or any color it will have a terminal on each end test both sides with an ohm meter if this goes bad theres probably a blockage in the vent that can also cause the heating element to die prematurely.
Jan 05, 2008 | Dryers
Dryers Logo
89 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
