Question about Acer Aspire One PC Notebook
The computer boots up fine, but i have no response from my keyboard or my touch pad....any ideas? I think there is a chip malfunction on the board....
  • Acer Master
  • 3,051 Answers
Hello there:
First i would boot into bios and check the advanced section or your periphal devices and see if the mouse and the keyboard is enabled and iof it is you cantry to go to the device manager and see if they are showing up there if so you can use the device manager to uninstall the device nd once it is uninstalled reboot the machine and upon restart if everything is good with both of these items you mentioned it will reinstall all the drivers for this ok?
I hope that this is verey helpful for you
bvest regards michael
Posted on Nov 17, 2009
Key L,AZ and spacer does not work. lenvo s10e idea pad
try to boot to safe mode by tapping F8 repeatedly as soon as you turn on the computer. If your keyboard is not working fine when you are in safe mode, you need to replace the keyboard of your laptop. Call your computer's manufacturer if your laptop is still in warranty.
Mar 22, 2011 | Lenovo IdeaPad S10e Netbook
The touchpad (and buttons) stopped working. No response at all. External mouse works fine, so it is not a software issue. Could this be a loose connection? or do these fail after a while? Are the...
Is there a button with a light on it near your touch pad, sometimes these buttons don't have lights? Usually this button is centered on the bottom or top of the touch pad. If there is a button like this, then try pressing it to see if it gives you functionality of the touch pad. If you do have a button like this and it doesn't resolve the problem then there is a possibility that the touch pad has malfunctioned or that the connector has come loose somehow. If you don't have this type of button then look at your keyboard to see if there is a function key for turning off\on the touch pad. Look for the FN key. What color is it? Then look at the keys that have icons in that color. If you find one that you believe is for the keyboard then try pressing that key and the FN key at the same time.
Jun 25, 2010 | Toshiba Satellite M55-S325 Notebook
My acer Aspire 3000 with a fresh windows xp home install, is having issues with the touchpad pointing device. I plug in a wired USB mouse and have no issues, but with the touch pad i am getting very eratic...
you may need to reinstall the drivers for keyboard and touch pad, if you still have the drivers cd on hand look for these two important drivers, since you have the new xp installed all drivers have been erased.
hope this helps
Nov 19, 2009 | Acer Aspire 3000 Notebook
Eratic movement of cursor using touch pad
Sounds like you have a touchpad malfunction. If its an older laptop, I would recommend replacing it. Not worth the hassle of trying to install a new touchpad...
May 12, 2009 | Dell F3534 Touchpad
Touch pad not working
If Windows service pack 1 - doesnot all recent drivers and will not recognize your touch pad and even keyboard.
Try to boot on Safemode.
Just press on F8 when your start your computer - and connect an usb mouse and try to install the touch pad drive manually.
Then boot on normal mode and install your other drivers..
It is recommended to update quickly your os to Service pack 2 or 3 for best performance of your computer.
Oct 14, 2008 | Acer Aspire 5100-5022 Notebook
Touch pad failed.
Look along the top of the keyboard for an "f key" that shows a "touch pad" icon, IF you see it, press the "function key" (along the bottom of the keyboard) PLUS at the same time the "f key" (that you found along the top) and that should "toggle" the touch pad back on....
Also, IF you plug in a USB mouse that will allow you to move the cursor around--but the USB mouse doesn't fix your touch pad problem.
Hope this helps.
Oct 04, 2008 | Toshiba Satellite A65-S1065 Notebook
System freezing when touchpad not being used.
This will be one of three things; 1- a driver glitch with the touch pad. Uninstall the drivers for the touch pad from the device manager, then reboot. The machine will find the touch pad and reinstall the drivers automatically. You might also look at Compaq's support site for any updated drivers or patches for the touch pad. 2- You may have a loose connection. Remove the keyboard, check and clean the touch pad connection/connector. 3- A faulty touch pad. If the other two don't work, then disconnect the touch pad and try using the machine with an external mouse. If this works, then the touch pad has malfunctioned and needs replacing. Ty these and let me know.
Aug 01, 2008 | Compaq Presario V4000 Notebook
Frozen mouse and keyboard on acer 3100 notebook
acer notebook- froozen keyboard and touch pad.......any help
Jul 01, 2008 | Acer Aspire 5100 Notebook
Keyboard and touch pad locked
You need the password to unlock it.  If yo don't have it you are out of luck. Password is stored on a separate chip and needs special tools and knowledge how to replace it.
If your laptop's memory can be upgraded there is usually a small panel you remove under the laptop. Then you need to tell some one at the computer store where you buy memory chips the make and model so they can give you the right chip.
Oct 31, 2007 | Acer Aspire 5050-3242 Notebook
Computer freezes...but not in the normal manner
The intel chip that is under the touch pad is the culprit. If you open the laptop by removing the keyboard, you will notice the chip just under the cover. i have tried putting pressure on it with an eraser and got some results. Mackay Rigava
Oct 12, 2007 | Compaq NX6110 TFT XGA Notebook
Acer Aspire One  PC Notebook Logo
61 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
