Question about E-Machines T5212 PC Desktop
My pc will load for about 5 min and then turn off completly what is wrong
  • Hanh Le
    Hanh Le May 11, 2010
    Could be either your motherboard or power supply.
  • gvape May 11, 2010
    Please include more detailed information about your PC. Manufacturer, Model Number, Operating System etc.
  • E-Machines Master
  • 3,051 Answers
Hello there:
there are several things that could be causing this .
first if you onboard fan is not working the computer may be over heating and shutting it'self down.
your power supply is starting to fail and needs to be replaced or the connections on the mother board are loose and need to be pressed in all of the way
your system may have a virus or malware on it . and your operatins system is now corrupted.
I would try booting in the safe mode and than to do a system restore back to when this did not happen and see if thecomputer now works if so you might have a program that is damaged but if this still doesent work i think you are having a hardware issue . ok so please try these out first and let me know how they work
there is still more ideas that i can tell you but lets try these first ok
best regards michael
Posted on Nov 17, 2009
  • 62 Answers
See if the fan on the processor and/or the fan in the power supply is working. You may need a minute or 2 for the system to get hot enough to start the fans. However if both haven't run before the shutdown the replace the fan(s) or the power supply.
It sounds like an overheating problem, without knowing more.
Netflix on iPad won't complete "loading" next episode
Netflix Phone Number
Phone Number
888-638-3549
Press 0 at each prompt.
or they call you instead
http://gethuman.com/call-back/Netflix/
Average Wait: 5 mins - 24 hours, 7 days
Oct 11, 2014 | Netflix
Why does my cake shrink before taking from the oven
That is completely natural. The cake raises due to air expanding in the heat and contracting when cooling down. The shrinking can be partly compensated by turning off the heat of the oven 5 to 10 min before it's done and let the cake cool in the oven for 10 to 15 min before taking it out. Avoids also cracking of cheese cakes.
Jun 02, 2014 | Baking
My machine displays F-07 what does that mean ?
  • F07 - Heater relay stuck
  • This means your heating system has gone wrong you will need to book repair but you could try and reset machine turn off at plug for 5 mins and try again.
  • hope this helps
Aug 02, 2011 | Hotpoint Aquarius WF220 Front Load Washer
My '94 Ford Taurus stalls whenever its idling in neutral or drive, in park its completely fine. When I give it gas in drive or neutral its completely fine and runs perfect but if i come to a light, or slow...
Disconnect your battery black wire off for 1/2 hour reconnect turn on all assesorys lights radio blower start car leave run for 5 min shut off for 5 min idle is controled by the computer the load
brings the idle up. Should be ok if not you may have to ajust the idle screw a little and then do this all over
Feb 01, 2011 | Ford Taurus Cars & Trucks
My Maytag Neptune FAV6800AW top load washer only runs for the first few minutes of the cycle, it will not spin..it just stops..we've tried two cycles, the quick wash...it starts at 33 mins and then stops...
I'm and owner and will try to help. Are you handy and do you want to try a DIY fix?
From the wash times is sounds like the washer is agitating the wash load (tumblers are rotating the wash basket load) is that correct?
If so see if the machine will complete a Spin Only cycle with no clothes in the wash basket. Set the Spin setting to Spin/Hang dry seting and start the cycle. It should take about 10 min complete. Does the Spin Only cycle complete with no clothes in the wash basket?
Some handy links if you are going to DIY.........Service Manual for reference.
Sep 17, 2010 | Maytag Neptune FAV6800AW Top Load Washer
My hpdv6000 recovery got stuck at 98% and showed 5 mins remaining then after 15-30 mins it moved to 99% and still showing 5mins! its been 30 mins no action seems its stuck. I started the process by going...
Hello Humanold,
Please check the following recovery steps:
Full recovery by using recovery partition:
1. Reboot the notebook PC.
2. Keep tapping F11 when the Compaq logo displays.
3. When the Recovery Manager appears, click Next.
4. When prompted to use the Microsoft System Restore program, select No and click Next.
5. When prompted to use the System Recovery, select Yes and click Next.
6. Select the option to perform the recovery without backing up files and click Next.
7. Upon completion of the process, recovery will display "The PC Recovery was successfully completed".
The recovery process will return your PC to the factory image.
Full recovery by using recovery disks:
1. Open the disc drive door and turn off the PC.
2. Insert the first Recovery disc in the disc drive and close the door.
3. Press the power button to turn on the PC.
4. The HP Recovery Manager window appears during the boot process.
If the HP Recovery Manager can access the hard drive, a prompt is displayed to backup the user files before continuing the recovery.
If the HP Recovery Manager cannot access the hard drive to fix the system errors, the HP Recovery Manager will overwrite all the data and reconfigure the entire hard drive to its original condition.
5. Follow the prompts to insert any additional recovery discs in the disc drive.
Sep 10, 2008 | HP Pavilion dv6000z Notebook
E-Machines T5212 PC Desktop Logo
74 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
