Question about Frigidaire FEF352 Electric Kitchen Range
Lock switch is out and stove will not close - Frigidaire FEF352 Electric Kitchen Range
  • 725 Answers
You just need to replace this switch which is very easy to do. Frigidaire is a wonderful brand! We have parts for all major brand so contact us at:
http://www.fixya.com/repair/d499389-accurate_appliance_repair_service from 7 AM until 9 PM CST for all your appliance parts supplies.
We ship overnight so you can get back to cooking again soon.
Thanks, Ella
Posted on Nov 17, 2009
I have a flat top fridgedare stove.I accidentally hit the clean button and opened the door but the latch had locked now I cant close door and oven wont come on and it just keeps flashing loccked.It doesnt...
The latch is solenoid operated. remove power from the stove (unplug or breaker). That should release the lock. Close the door and power back on. Hopefully all will be reset.
Aug 03, 2014 | Kitchen Ranges
Mcclary stove
One thermostat (sometimes at the back of the stove) is open/blown or the door locking assembly has failed. To open the door you may remove the back of the stove; take the door locking assembly apart to release the long wire that hooks the door close.
On some models you can see the locking the latching mechanism through a **** in the top front and can play with the mechanisms there to release the door.
Then you can begin to figure why the door latched in the first place.
Oct 20, 2013 | Kitchen Ranges
I have a frigidaire self cleaning oven and range top. while i was baking the temp just suddenly went off and the door was locked. tried pushin lots of buttons, nothing happened. so i unplugged it for a...
Hi, try opening the door and looking for a little black switch on the right or left side, that the door actuates this is the door switch, while the stove is plugged in, hold this switch in and see if the lock moves.
Sean
Mar 26, 2011 | Frigidaire Ovens
Frigidaire stove continuosly locks then unlocks
there is a small switch on the lock mech thats probly not making this is comon
Dec 25, 2009 | Frigidaire FEF336BC Electric Kitchen Range
I have a fridgadare stove that reads code f9.
OK, I will list the Possible causes and the solutions below to combat this issue you are experiencing.
POSSIBLE CAUSES--
1. Door motor failure / jammed. Latch
motor switch failure.
2. Control software failure, or component
failure (relay stuck).
3. Wiring Problem.
SOLUTIONS--
1. Press CLEAR key.
2. If CLEAR key does not eliminate problem, turn off power for 30 seconds, then turn on power.
3. Check wiring of Lock Motor, and Lock Switch A, and Door Switch circuits.
4. Unplug P4, apply power (L1) directly to the Lock Motor, if the motor does not rotate, replace Lock Motor Assembly. Plug P4.
5. Check Lock Switch A for proper operation (do they open and close, check with ohmmeter). The Lock Motor may be powered as in above step to open and close Lock Switch. If the Lock Switch
is defective, replace Motor Lock Assembly.
6. If all above steps fail to correct situation, replace control.
May 01, 2009 | Frigidaire FGB24S5A Gas Single Oven
I did not follow directions on self-cleaning and now stove is loc
Since the door is open and the lock is engaged, you will need to hold the "door closed" switch in located in the top left door opening. Push and hold the switch in, push the clean button, set the time at 3:00 hours, keep holding the switch in for 20 seconds, then push cancel button. The motorized locking mechanism should disengage. Then, you can release the switch. Hope this helps.
Dec 06, 2008 | Frigidaire FEF352 Electric Kitchen Range
Stove 2001 i cleaned my sove but the lock never released and i cant close the oven.
The lock motor may have failed. On many freestanding stoves the lock motor is located in the right rear (looking from the front) with a long rod connected to the lock. remove the motor and unhook the rod from the motor cam to operate the lock manually
Jun 17, 2008 | Whirlpool Kitchen Ranges
Oven Lock stuck open before start of self-cleaning cycle
push in on the oven light switch and hit clean then cancel you have to hold the oven light switch thats what tells the eoc the door is closed if this dont work reply to me
Jun 05, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
DCS gas oven locked
I let the door stay open, hold the switch closed with my finger, activated self clean. Let it run for a minute then hit cancel, the stove heating element shut off and the locked door blinked for 5 seconds then finally stopped. Back to normal.
Dec 26, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
Frigidaire FEF352 Electric Kitchen Range Logo
83 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
