Question about Coleman Powermate Premium Plus 6250W Portable Generator
My craftsman generator model # 580.32672 starts but will not put out any power ive tried a few suggestions but nothing has worked
  • cijntje elvis Apr 12, 2013
    my craftsman gen wil not run fast and put out power slow
  • 776 Answers
Look in the manual. There is likely something about field flashing the magnetic field. According to the Briggs and Straton web site, the easiest way to do this is to.
1) start the generator
2) plug an electric drill into the generator (without drill bit)
3) make sure drill is set to forward direction (if a reversable drill.
4) pull the trigger on the drill.
5) If the drill does not start, spin the drill's chuck clockwise (When looking down at the chuck from the drill bit end). Spin counter-clockwise if holding it like a pistol and pointing away from yourself.
6) Do this several times (hard) until the the generator will kick in and suddenly make the drill spin at full speed.
Be careful not to drop the drill or poke someone with it as you celebrate success.
Posted on Nov 17, 2009
I have a craftsman 725 series Briggs and Stratton engine power propelled electric start 22" multi-cut model # 917.370930 that will not move when I pull the handle
ive gotten this one brought into me a few times for this exact problem , seems the problem allways stems from the safety handle cable , stretching and not providing the relief of the safety blade stop break , I just install a new cable on the handle and the trip arm and it works again
Jul 07, 2015 | Craftsman Garden
No power output
Excessive load on the generator may have damaged the power head, but verify that the circuit breaker at the output plug is not tripped before yuo attempt any other repairs.
Dec 06, 2013 | Craftsman Electrical Supplies
Start switch does nothing
Try the easy thing first, check connections and lube switch with mfg suggested lubricant. Sounds like a corrosion problem to me.
Nov 10, 2013 | Generac Guardian Ultra Source 15,000 Watt...
Craftsman 5600 watt generator won't stay on and white smoke pours out when started.
try running it with nothing hooked up if it runs fine, then the power draw is to much for it that would cause it to hunt !!!
Jan 30, 2013 | Craftsman 5600 watt Generator
2007 Craftsman riding mower 16.5 HP 1000LT model. It sat up for 2 years, Everything is working good, except now the reverse isn't working. any suggestions what to check for or how to solve this?
try putting mower in neutral and push backward and rock a few times,, then start it and put in reverse,,if it wont move have some one to push you, good luck ,, hope this help you,, trying to help you, this is not my strong point....
Aug 26, 2009 | Garden
Y generator starts but not putting out any power
plug in a electric drill into the generator. start the generator and let it idle. depress the trigger on the drill with the drill set in the forward position and by hand turn the drill in the opposite direction. it should excite the generator and start the drill
May 15, 2009 | Coleman Powermate 5000W Home Backup...
Colman powermate 5000 no putting out any electric
If you are getting some power, even if it only 2vac then you may have to flash the excitor circuit. If nothing then take the end cap off the generator and clip your meter to the metal portion of the brush holders or exposed wire from them. Start the generator and see if any voltage is coming from the brushes. Even if there is nothing try flashing the excitor.
To flash the excitor circuit on a coleman ( the generator is built by generac) you need a 12 volt battery. You quickly apply 12 volts via your 120vac recepticals. NO MORE THAN ONE OR TWO SECONDS! Then check you ac voltage.
Give this a few attempts and if this does not do it, I would say the winding repair did not work. Buy another generator and use the engine for a go cart or backup engine since this generator is so cheap.
Mar 17, 2009 | Coleman Powermate Powermate 5000W...
Coleman Powermate Premium Plus 6250W Portable Generator Logo
781 people viewed this question
Top Coleman Electrical Supplies Experts
John Trevino
Shawn DuRee
Phil Walker
Phil Walker
Are you a Coleman Electrical Supply Expert? Answer questions, earn points and help others
