Question about Frigidaire 27" Built-In Double Electric Wall Oven - White
The top oven of our double oven will not heat up. However the fan still comes on...could this have to do with the elements or is it something else?
    Scholar:
  • 62 Answers
Hi.
Did you notice whether the mains circuit breaker tripped while you were cooking last?
Howvever if your temperature light comes on and also the fan then the most likely cause is a fan element.
Should you need any help with obtaining a replacement part please email me on: aardvark.repairs@btinternet.com
regards
Aardvark repairs
Posted on Nov 17, 2009
  • 190 Answers
SOURCE: Bosch oven not heating to temp
Dear customer,
i recommend u to try the following routine to sort out this problem
  • Check timer and clock settings
  • Reseat the element
  • Test the element
  • Test the element connectors
  • Test the oven temperature control
  • Test the oven selector control
  • Recalibrate the temperature control
  • hope u find this useful. thank you.
    Posted on Jul 09, 2008
    barkencoa
    • 3463 Answers
    SOURCE: SMEG DO4SS-5 double oven not heating up
    If the fan is running, then it is safe to say that the oven element has gone.
    Replace with a new one,(element that is).,
    Plz rate this solution.
    Thanks.
    Posted on Dec 15, 2008
    SOURCE: fridgiaire Gallery series Model GLEB30T8CBA lower elements dont work
    I replaced the relay board for the top oven (the one with the transformer) and it works properly now. My issue was only for the top oven so you probably have to replace both relay boards since both ovens have only the top element working.
    318022002 is the part number for the relay board with transformer
    318022001 is the part number for the relay board without transformer
    Yes the one without the transformer is more expensive for some reason.
    The boards are on the top of the oven, I was able to pull out the oven about 75% of the way out of the cabinet and easily get to the boards. Just unplugged the connections and plugged them into the new board.
    To get the oven out there are two small screws that go into brackets inside the top oven door. Highly recommend taking the doors off the oven to pull it out, much easier to work with.
    NOTE: On my old board I noticed one solder joint that was burned out and I since I already had the new board I just replaced but you might want to check that first and see if just a solder fix gets you working again before you spend $$ on a new board.
    Posted on May 13, 2009
    • 13 Answers
    SOURCE: Neff U1721 bottom oven not heating fan & light are ok
    Yes it will need a new element, if the fan runs and temperature light comes on then the element is gone.
    Posted on Jul 29, 2009
    barkencoa
    • 3463 Answers
    SOURCE: Zanussi ZDQ 595 fan oven not heating
    You need to replace the round fan oven element located at the rear of the oven compartment behind a removeable cover where the fan is located.
    Posted on May 14, 2010
    Testimonial: "Thankyou - i did not know there was another element in there!! I cannot believe how expensive these ovens are considering the simplicity of their construction and low cost of the components inside.. Thanks again..!"
    Grill not working after replacement element - any ideas?
    I would say you are right on your wondering. look at your manuel and it will show you a diagram
    May 07, 2012 | Zanussi ZHQ575 Electric Double Oven
    Just moved, can not get stoves double oven to work light and fan comes on both ovens but no heat
    On the main oven, does the circulating fan at the back of the oven start to rotate when you switch it on and does the fan oven neon illuminate as well.
    For the top oven, the heating element is not very big so the oven takes a long time to warm up. Does the top oven neon illuminate when you switch this on as well?
    Aug 02, 2011 | Stoves 720EF Electric Double Oven
    Neff oven not heating have replaced fan element
    it has to be the temperature control itself...thats the only other component, aside from the high-heat cut out switch which rarely goes bad.
    Jun 05, 2010 | Neff U1721 Double circotherm Electric Oven
    Zanussi electric double oven. Top oven not working.
    It sounds like a faulty thermostat, because when you turn the thermostat on it should supply the oven element and the neon light, so even if the element is faulty, the neon light should still come on regardless of the element working or not.
    Hope this helps.
    Feb 10, 2010 | Ovens
    AEG Competence Oven not working
    If you are certain that the element is o/k, and it is not heating, then thwere are 2 possibilitues.
    1- the oven thermostat could be faulty, whereby it is giving a feed to the element.
    2-some ovens have a fan only setting, as well as heat and fan, make sure that it is not on a fan only setting.
    Hope this helps.
    Feb 05, 2010 | AEG Ovens
    Fan in main oven boken
    Sounds as if your oven heating element has failed. You need to fit a new one.
    Usually you have to get the back off, disconnect the old element, remove the fixxing screws and element, fit new one, reconnect and it should be fixed. Don't forget to switch the power off before starting work.
    Dec 31, 2009 | Zanussi Ovens
    Top oven on uy46 working, bottom oven light coming on but no heat coming in??
    If the fan is working o/k, then you need to replace the oven element, located behind cover at rear of oven compartment, very straightforward repair to do.
    Please rate my solution.
    Thanks.
    Nov 07, 2009 | Hotpoint UY46 Style Line Stainless Steel...
    The fan and oven light in bottom oven works but not heat.
    The heating element is the likely culprit as they burn out and go open
    circuit..(ie ...disconnected and will not heat up )
    If you can use a multi-meter , then the element can be tested using the resistance range (with the oven SWITCHED OFF )
    Aug 30, 2009 | Neff U1721 Double circotherm Electric Oven
    Jun 08, 2009 | Neff U1721 Double circotherm Electric Oven
    Frigidaire 27" Built-In Double Electric Wall Oven - White Logo
    91 people viewed this question
    Top Frigidaire Ovens Experts
    Dan Webster
    Dan Webster
     Fix Your Board
    Fix Your Board
    ashburton
    Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
