Question about Powercom King Pro 3000VA (powkingpro3000va) UPS System
When i connect 4 batteries in series for a total of 55 Volt, the ups tells me there is a problem with my battery. is the ups overcharging my battery or are the batteries overcharged. i bought them with 13,6 Volt each. i have a 3000VA powercom ups, light grey of colour
  • cool159 Nov 17, 2009
    The ups uses a step up transformer . It uses 48Volt to get to 220Volt. So the batteries must be coupled in series.When they are fully charged, like in buying them from a dealer, they are together 54 Volt. Now when i install them in my ups, the machine says, " Check batteries, Faulty "
    President:
  • 1,884 Answers
I think UPS' are supposed to run on 12 volt batteries. You must connect them in parallel and not ie series as you are doing now. Connect all the Positives together and all the negatives together to give 12 volts and four times the amperage of each battery for longer backup. With series connection you may burn the system. Please check the manual that came with the UPS.
Posted on Nov 17, 2009
  • Vinay Tevatia
    Vinay Tevatia Nov 17, 2009
    OK. Are the batteries fine. I mean they may have the required voltage of 13.5 each, but do they have the required ampereage? You can get 54 volts from flash lite batteries, but they can not run anything more than a small bulb. Similarly, if one of the batteries is having 13.5 volts but is it also having the required ampereage to run the UPS. that should be checked with an amp meter on full load. Thus any battery not meeting the requirement should be replaced.
It does not seem to be charging the batteries. 12 volt lights work good for about 2 days then go dim until I put a charger on the batteries and bring them back into working order. The battery connect...
The Parallax 7155 converter should not require battery support for any 12 volt load amperage that is less than the maximum amperage capacity of the converter. A standard RV incandescent 12 volt lamp draws about 1.5 amperes for each bulb. With the battery disconnected and other 12 volt loads off, turn on lamps (not fixtures) and calculate the number of bulbs which can be turned on. If you run out of lamps, turn on vent fans etc. The idea here is to try to get to 55 amperes of DC load if possible without going over 55 amperes. At a sustained DC load of about 25-30 amperes or higher, the fans should cycle on continuously after about 5 -10 minutes. Lamp brightness should be normal and the measured voltage from the converter should be above 13 volts if under 55 amps of DC load. If the voltage drops with only a few lamps on, a converter issue would be likely.
Diagnostic tests an RV technician should make would be to:
1. Disconnect the battery system.
2. With the converter system powered on, measure the DC amperage with a DC ammeter capable of reading at least 60 amperes DC from the blue lead at the DC fuse panel terminal VCC.
3. Measure the DC voltage at terminal VCC and DC ground.
4. Record both readings.
At any DC load amperage less than 55 amps, the voltage should be above 13.0-13.2 volts DC. This method should take out all guesswork and confirm a DC converter section issue or not.
Nov 04, 2013 | Parallax Power Supply Parallax 7100 Series...
48 volt club car 4 12 v batteries one batterie checks 20 v when I single it out when I unhook it it checks 12 v
If you have 4 off 12 volt batteries connected in series (positive to negative leaving a positive terminal and negative terminal with no wires on then that is 48 volts. To check the batteries you have to disconnect each battery and have a load test done on each battery for 12 volts and dead cells. To get 20 volts you still have 2 batteries connected together with a good battery connected to a battery with a dead cell or else you would have 24 volts.
Oct 03, 2013 | Cars & Trucks
Hooking up a 36 volt charger to three 12 volt batteries in series
first of all do you have 3 or 4 batteries your cranking battery is not to be wired into this 36 volt if you have 4 batteries you have 3 for trolling motor and 1 cranking battery look on your charger see if the banks or numbered 1 2 3 4 .... you got to find what battery is # 1 depends on how they hooked in series if you hook charger on wrong battery most the time a red light comes on telling you wrong battery move wires till green lights come on all batteries.# 4 goes to cranking battery if you only have 3 batteries you don't have 36 volts you have 24 volts and a cranking battery if so # 3 goes to cranking battery
Aug 29, 2013 | Minn Kota Boating
I overcharged my peg perego 12 volt battery, will it be ok?
how did you overcharge it, the chargers are designed to trickle charge once it reaches a full charge
Dec 24, 2011 | Peg Perego 12 Volt Rechargeable Battery
I have 4 x 12v batteries 7ah each. if i put these 4 batteries together . how many volt and AH would this be. please reply . thank you
It depends on how you connect the batteries. If you connect the negative of battery one to the positive of battery 2, the negative of battery 2 to the positive of battery 3 the negative of battery 3 to the positive of battery 4 then the positive of battery 1 and the negative of battery 4 will give you 48v 7AH. (This is known as connecting in series.)
If you connect the four positives together. Connect the 4 negatives together it will give you 12v 28 AH. (This is known as parallel connection.)
If you connect the negative of battery 1 to the positive of battery 2. Connect the negative of battery 3 to the positive of battery 4. Connect the positive of battery 1 to the positive of battery 3 and the negative of battery 2 to the negative of battery 4. You'll get 24v 14AH from the connection of the positive of battery 1 and battery 3, and the negative of battery 2 to battery 4. (This is known as series parallel connection)
Jul 19, 2011 | Electric Cycling
How can i connect my external charger with my powercom kin-1200ap ups.Im using external two battries of 12 volt 40 amp .
your charger should be 24v and more then that but how can you stop charging after full charging overcharge may damege the batteries
Feb 07, 2010 | Powercom King Pro 1200VA...
Volt meter shows 26 volts(2 12 volt in series) but wont run lawn mower. jumped 12 volt car battery and this runs mower at slow speed. is battery dead
Sounds as if battery has internal short. Also have charging system checked. If doing yourself check amperage also. Charging volts and no amps wont work or overcharging. Over charging will ruin a new battery. Also make sure you have clean solid connections between cable ends and battery. Take cables off and clean very good poor contacts will give false readings when checking system.
Jun 27, 2009 | Panasonic LC-X1220P - UPS battery - 1 x...
Belkin UPS F6C900-UNV burns up after replacing the battery.
I just replaced the batteries on my Belkin F6C900-UNV. They died just short of 3 years of use, which is what I would expect. My unit contained two 12 volt, 4.5 amp-hour batteries that were connected in series. When connected in SERIES (one battery's red terminal is connected to the other battery's black terminal), the two batteries behave as if they were one 24 volt battery. Therefore, this UPS is designed to charge a 24 volt battery. When replacing the batteries, you cannot use a single 12 volt battery. This will fry the battery. You can use either two 12 volt batteries connected in series, or one 24 volt battery.
I measured the charging voltage of my two new batteries (connected in SERIES), and find it charging at 24.6 volts. This is an ideal float voltage to maintain these sealed AGM (absorbed glass mat) lead acid batteries (13.2 volts per battery). The replacement batteries are similar to the originals, each measuring about 2.7x3.5 inches and 4 inches high and rated at 12 volts, 5 amp-hours. They can be purchased for $20 or less each, so for $40 I now have a fully functional UPS, good for another 3 years.
Feb 25, 2009 | Belkin (f6c900-unv) UPS System
Battery voltage not known for UPS-DELTEC PRR 2200i
It uses 4x12v @ 26AH batteries in series, making a total of 48v (more like 52v if charged).
Jan 19, 2009 | Compaq UPS T2200 XR UPS System
Powercom King Pro 3000VA (powkingpro3000va) UPS System Logo
424 people viewed this question
Top Powercom Computers & Internet Experts
vimal
vimal
Shekar Avadhani
Are you a Powercom Computer and Internet Expert? Answer questions, earn points and help others
