Question about Garden
How to remove rear wheels of a yth1342xp huskyvarna lawn tractor
  • 460 Answers
Just like the wheel bearing hubs are on a car. you might need snapring pliers channel lock poliers and possibly a slide hammer.. the reason is some have snap rings and others have cotter pins with a crown nut. was this of any help?
Posted on Nov 17, 2009
When I removed the rear wheel of my lawn tractor,the keyway fell out. how do I reinstall it?
I assume you are having trouble keeping the key in place while you slide the wheel back on?
I've sometimes used a bench grinder and taken the leading edge off the key (the edge catching the first part of the wheel as you slide it on) to stop it catching on the wheel slot, also a dab of thick grease under the key to help hold it in position.
Some coppercote or similar anti-seize grease in the wheel's key slot would be a good thing too.
Sep 08, 2013 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Can't remove the rear wheel from a cox lawn boss
it is common for the rear wheels to get stuck to the axle i just change the tires or add a tube while its on the axle you will damage more trying to get them off
Sep 30, 2012 | Garden
I put the rear end of my craftsman lawn tractor on a cinderblock to take the rear wheel off and fix it. It was on the block for a couple of day. Now my tractor won't go forward or backward. the belt...
Did you forget to reinsert the key or did it slide out while putting the wheel on. A quick way to check is if you remove the center cap and have someone put it in gear and try to go while you are watching the axle. If the axle is turning and the wheel is not then the key is missing.
Sep 12, 2011 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Poulan Lawn Tractor 42" 14.5 hp Model 733-864 How do you remove the rear wheel to fix flat tire?
I need the diagram for a drive belt for a 42'' lawn tractor - 14.5 hp Can ANY ONE help me?
May 21, 2010 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
I need to replace the two 21-inch blades on my Craftsman rideable lawn mower.
I just watched the service technician change mine. He pulled the rear differential release out, then after removing the hood, he put a hoist on the front and stood it upright on it's rear wheels, and easily replaced both blades with a socket wrench. That beats all the work of removing the deck and turning it upside down.
Apr 21, 2010 | Craftsman 20 Hp 42" Deck Lawn Tractor
Getting Rear Wheel Off A Sraes Craftsman Riding
pull off plastic axle cover in the center of the wheel, remove large e-clip seen on the end with small screwdriver and large washer. take care not to let it fly off somewhere. lift tractor with a jack, pull off wheel then note the location of the square shear pin and save it for reverse assembly
Apr 16, 2010 | Craftsman 20 Hp 42" Deck Lawn Tractor
How to remove rear wheel of lawn tractor
You should be able to remove the bolt from the center with a 1/2" socket an slide it off the axle. You do not want to do any heavy hammering on the wheel because you could possibly drive the axle out of the transmission. MTD mowers are notorious for being hard to get the rear wheels off. If you do get them off or ever buy a new one, remove the rear wheels and coat the axles with anti-seize compound. Good luck
May 15, 2009 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
Remove rear wheet
YOU'LL NEED AN EXTENTION FOR A SOCKET,BUT 1'ST REMOVE THE LITTLE CAP AND REMOVE THE COTTERPIN,MAKE SURE IT'S IN GEAR IT WILL KEEP THE WHEEL FROM TURNING.hope this helps
Apr 25, 2009 | Mtd 46" Dozer Blade, Fits All & Yard -...
Removing tire from SEARS CRAFTSMAN LT1000 TRACTOR.
You need to remove the black rubber cap from the center of the wheel. Remove the "C" clip from the axle and the wheel should come off. The rear tires will have a square key in it. Do not loose the key.
Jan 26, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Garden Logo
64 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
