Question about RCA DCM425 DIGITAL CABLE MODEM (RCADCM425)
I have a dcm435c modem wat kind of router do i need?
    Brigadier General:
  • 10,406 Answers
Because the cable-modem has an RJ-45 ("Ethernet") output-port,
and because any router has an Ethernet WAN ("Wide Area Network") input-port, any router will do ("wired-only" or "wired-plus-wireless").\
Posted on Nov 17, 2009
I already set up the router to the computer and the modem, the problem is I cannot connect it to the internet. the lights are all working in the modem and on the router. How will I fix it?
First check the modem ,connect modem cable direct your system ,if modem is ok then you have problem with your router.Try to reset your router.
normally connection problem depends on your physical connection setup your router...
If you need any kind of technical assistance you can contact support cell at http://www.vtechsquad.com/
Jan 04, 2013 | Linksys Wireless-G WRT54G Router
Im trying to connect to the internet and it says error code 051030 wat do i do
Your wireless router may need to be power cycled, or the connection settings have changed.
How to fix: Power cycle your router; redo the connection settings on the Wii and try again.
  • Did this connection used to work but has suddenly stopped? "Power cycle" your router and modem. To do this, unplug both the modem and the router from the power outlet. Wait a few minutes, and plug the modem back in. Wait a couple of minutes for the modem to initialize, then plug in the router. Try to connect the Wii, Nintendo DS, or Nintendo 3DS online and test for proper response.
  • Erase your old connection settings on the Wii and set up a new one, as your router's settings may have changed since you last connected. We suggest following our guide to create a new connection file and start over. If at the end you still need help, you'll find contact information to reach our specially-trained representatives.
http://www.nintendo.com/consumer/wfc/en_na/ds/results.jsp?error_code=051030&system=Wii&locale=lang
May 06, 2011 | Nintendo Wii Console
I try 2 plug my modem up 2 my ps3 but the ip address timed out wat do i do
After you have the Ethernet cable from your modem plugged into your PS3 press and hold the reset button on the back of the modem for about 5-10 seconds. This will reset the modem so that it will recognize the connect to your PS3. Once your done using your PS3 and reconnect the Ethernet cable back to your computer you will have to reset the modem again. Any time you move the Ethernet cable from one device to another you need to reset it after you have the cable connected to what ever device you want to get online with at that time. If you do not want to keep resetting your modem all the time a router will allow for you to have more then one device online at a time. The router will connect to your modem and then your devices will connect to your router.
Sep 24, 2010 | Arris Touchstone 450a (CM450) Modem
I purchased encore router 2 yrs ago and i need to install it again but the installer is missing wat will i do?
Are you trying to set up the router.
You can do it manually without the CD.
Make sure that your computer is able to go online through the modem.
If your computer is able to go online through the modem
Then you need to connect the computer to the router ad the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Click Here for step by step by instructions
Feb 06, 2010 | Encore 802.11G WIRELESS LAN ROUTER...
I've connected the cat 5 wire from my cable modem to the linksys cable router with 8 ports but it does not give access to the internet on the other computers that are networked. If I let it find an...
hey, you need to create bridge between your cable modem and router and you need to give one static IP in the router. kindly note you need to keep cable modem and router in the same class eg-( cable modem ip is 192.168.1.2 then router should be the same range.) and provide gateway of your ISP in the router.
Jun 09, 2009 | Arris SURFboard SB5120 Modem
Help me please
I think Not.
There are ADSL wireless routers however.
I guess your purpose is to make your ADSL modem available wirelessly, you can connect the
modem via lan line to the wireless and use that as a router.
Nov 16, 2008 | Linksys Wireless-G WRT54G Router
Ps3
Hi mon3ymik3,
1. First of all, connect your routers Internet/WAN port to your cable/DSL modem.
2. Configure your router with the settings your Internet Service Provider gave you. The router usually needs to be configured via either a install disc or it's internal webpage. Look up it's default IP and type it into your browser after: http://
(If you don't know them, call their tech. support).
3. Make sure the internet connection works.
4. Look up the settings for a DHCP server and make sure it's on. This will give all the devices connected to the router an IP address within the range or scope you set in there.
5. Connect your PS3 to one of the other ports of the router.
6. Go to your PS3's network settings, make a new connection and set everything to Automatic. Your PS3 will "ask" your router for it's settings.
7. Run a connection test.
8. If test succeeded you should be on your way.
P.S. If you need help configuring your router I will need more information about it. It's brand, it's type etc.
Tell me if it worked.
Greetings,
DarkNeogen
Jan 17, 2008 | Sony Playstation 3 (PS3) Console
RCA DCM425 DIGITAL CABLE MODEM (RCADCM425) Logo
231 people viewed this question
Top RCA Computers & Internet Experts
Julie Endres
shaun taylor
Are you a RCA Computer and Internet Expert? Answer questions, earn points and help others
