Question about Kenmore 21.7 cu. ft. Side-by-Side Refrigerator with Thru-the-Door Ice & Water with Water Filtration 4659267
Ice Maker I have a Kenmore 106.9547610 with ice maker. The ice started tasting funny so I turned off the ice maker and put in a filter. Then is would run through its cycle but didn't fill with water. I have replaced the solenoid and put in a new ice maker and still no ice. THe new ice maker doesn't run through the normal cycle.
  • 833 Answers
First, are you getting water at the door? If not, the filter is installed wrong or there is some packing on the filter you didn't remove.
Posted on Jan 10, 2008
6ya staff
SOURCE:
The ice tastes funny, what could be the issue?
Your water filter needs replacing?
If you are at a cottage or using well water, it often contains iron which DOES taste odd.
Commercial ice makers recommend that you clean the system every 3 months.
Take some ice and put it in a saucepan and boil it until it runs dry. WATCH IT NEAR THE END AND DONT LEAVE IT! See what is left and the colour.
Sep 10, 2015 | Refrigerators
Kenmore refrigerator model# 70192001 has funny chemical tasting ice
Do you have a water filter, either inline or inside the fridge side? There is nothing in the water lines or valves within the fridge that will contribute to chemical taste. Unless it's just been connected and the line was dirty. It's either your water supply, and if so install a quality inline water filter will help. Some times if the fridge filter is clogged the water flow to the ice maker is restricted and little bubbles get trapped in the ice and they taste off. You should have crystal clear ice. If not get a filter.
Sep 26, 2009 | Kenmore Refrigerators
Whirlpool ED25RF Does ice maker have a filter? My ice taste funny and sometimes its dirty
The ice maker doesn't have a filter , the problem could be the ice maker itself that the tray ,which is made out of aluminum is losing particles.Look at the conditions of the ice maker tray ,if you see like white spots replace the ice maker.
Aug 30, 2009 | Whirlpool Refrigerators
Ice maker ice tasting funny
have yopu tried a filter on the unit yet sometimes that is the only way to rid of the taste.
Feb 02, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice maker filter
No, they do not. If the ice is old it can absorb taste from the air. You can also buy an in-line filter for your unit. Hope this helps!
Jan 15, 2009 | Kenmore 18.3 cu. ft. Top Freezer...
Bad water & ice cube taste
then change your filter. the new filter could be different with the old filter. check the new filter, see if there is odor removal and taste removal with it.
if not then get the filter with carbon filter, odor and taste removal.
then with a new filter, run about 5 gallons of water before using the water for drinking.
tnx 4 using fixya,
drcool
Oct 07, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Water and ice has a funny taste
THANKS FOR YOU QUERY JACK.FIRSTLY DEPENDING ON HOW OLD THE APPLIANCES IS MOST MANUFACTURES USE THE SAME OR SIMALAR WATER FILTER SO THAT WILL BE YOUR BEST BET TO CHECK WITH THEM.NORMALY WEN THE ICE AND WATER TASTE FUNNY I HAVE FOUND THAT IT IS WHAT WE CALL ICE BURN AND THAT IS NORMALY WHEN THE ICE HAS GONE STALE OR IS STANDING FOR A LONG TIME TO SOLVE THAT IT IS BEST THAT YOU USE THE ICE UP AS SOON AS POSSIBLE.HOPE THAT THIS SOLVES YOUR PROBLEM.
Aug 20, 2008 | Kenmore 50522 / 50524 Side by Side...
Ice maker's ice taste funny
You may consider pulling out the ice maker and tossing it in the trash if you look at it and see that where the ice sits it's corroded or its close to a 10 year old in age (IT'S DUE TO GO OUT ANYWAY).Other than that:you have a 3% chance that the tube that goes to your ice maker is bad. Please Rate This !
Jun 12, 2008 | KitchenAid Superba Architect KSCS25INSS...
Refrigerators Logo
177 people viewed this question
Top Kenmore Refrigerators Experts
Jimmy
geob91
John Tripp
John Tripp
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
