Question about Pool & Spa
Motor gets hot & the thermal cut-out shuts
Emerson 1081 pool motor gets hot & the thermal cut-out shuts down the motor. What would cause this ? How do I fix ?
  • 95 Answers
One of the windigs in the stator has an open circuit
Posted on Nov 18, 2009
  • snjhubbard Aug 31, 2010
    So... I guess the fix for one of the windings in the stator being bad is to replace the motor? I have had the same problem and already replaced the motor once due to this problem and still having this problem with the new motor.. So I guess my next question is how likely is it to get 2 motors that have the same problem?
  • Lou Leo Sep 28, 2013
    I had this problem every two years. Emerson motors are junks. What brand is better?
I need a manual
For what?
its just a motor.
do you need wiring assistance?
what is the model, code or serial number of the Emerson motor?
and... 1081 does not help!
That just means it's a 'Pool' motor casing.
Feb 16, 2014 | Emerson Pool & Spa
Emerson pool spa pump leaking water-how to change gaskets
Emerson is not the name of the pump, that's the brand of the motor attached to the wet end, and the two together make a pump.
1081/1563 only means that it meets the standards for a pool motor.
provide make and model, for your pump.
Jan 23, 2014 | Emerson Pool & Spa
Emerson 1081 manual
What Emerson model, serial and or catalogue number do you have? 1081 is the basic and generic code indicating that it meets the standards for a pool motor, that's all.
Oct 16, 2013 | Emerson Pool & Spa
How to replace the capacitor on emerson 1081 pool pump motor
remove the bump on the motor make sure power is off then discharge by shorting a screwdriver from the leads to the case then take a picture of wiring or make a note then match it up at a electrical supply store then replace
Jul 07, 2012 | Emerson Pool & Spa
I have an Emerson 1081 Pool pump motor. After 2+/- hours it overheats and shuts off. Suggessions?
How old is the motor? Is it operating louder than normal as it runs indicating a bad bearing? Have you or can you check the incoming line voltage to ensure it is correct? If it is a new motor have you made sure the motor is set to the correct incoming line voltage? Has anything in the plumbing changed recently?
John
Mar 16, 2011 | Emerson THREADED SHAFT UP RATED - 1.00 HP...
Motor shuts off after 30 seconds looks like it is overheating
More than likely the motor is overheating or at least the thermal overload thinks it is. The thermal overload could be bad but if the motor has burnt windings then it probably is pulling too many amps which will cause the overload. Sounds like you need a service call or take the motor to a motor shop.
Sep 13, 2009 | Emerson Threaded 1.5hp Fullrate 115/230v
Hot tub pump stops and control panel says there is a flo problem
Yes a pump does have a thermal cut out. When the motor gets too hot the thermal cut out will activate and the pump won't restart until the motor has cooled.
If you were an electrician, or highly confident/competent with electrics, you could test the motor with a volt meter. Run the spa and as soon as the pump stops running, check the voltage at the pump. If there is voltage at the pump, then the thermal cut out on the motor has activated. Do not try checking this yourself if you're not competent to do so.
You could also do the same test at the spa pack if it's easier to do so, just locate the output to the pump.
What spa and which spa pack have you got?
Cheers,
Ian.
Apr 24, 2017 | Aqua Flo Aquaflo Flo Master Xp2 Spa Pump...
Pool & Spa Logo
1,027 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
