Question about IDEAL Vol-Con Xl Voltage/Continuity Tester
When we measure from hot to neutral we get between 40 & 50 Volts
I am assisting my sister and her husband with some fix-it problems. When we measure from hot to neutral, or ground, we get between 40 and 50 volts on a receptacle we are testing on an enclosed patio where they have not had power since they bought the house in 2006.
The house wiring is a mix of old two wire service without ground and current three wire service with ground. The breaker box is a mess. I am concerned for their safety.
I am looking for the wiring logic that would show only 40 to 50 volts on a circuit. There are also other examples of low voltage readings at other locations in the house.
Our friends at Lowes, Home Depot and Menards have been of little help other than an open neutral or ground. To my understanding, if there is no ground or neutral, there is no circuit and no voltage.
This is "phantom voltage." To be sure of this you can try shorting the hot with the ground. Should not short. The voltage isn't dangerous. It often happens when two hot wires are in the same cable. For example a 12/3 romex with a shared neutral. When one hot wire is turned off and the other is still energized, voltage can leak from one wire to the other, causing a reading of 50 or so volts on the non powered wire.
Posted on Nov 24, 2009
    Problem Solver:
  • 16 Answers
I would recommend checking the meter to make sure it's set for AC. If it is set on DC the meter will show an inaccurate reading. There are polarity testers available @ places like home depot, etc. it's usually a small yellow plastic block with 3 LEDs showing hot, neutral & ground with "prongs" so it can be plugged into any wall plug. it's a quick & easy way to find out the status of an outlet.
Posted on Nov 17, 2009
How many Horse power Dei-815/E freezer
Freezers are not measured in horsepower, only mechanical engines. This is the specs, and it is basically a 25 amp freezer, with an additional 7 amps or fans lighting and door heater, both at 250 volts AC. However, running an Amps to HP converter gives 6.971 horsepower.
DEI-815 dual controller with external probe box d
  • DEI-815 dual controller boxed With external probe
    Set Temperature range: -40 to +40
    Tolerance of 1 ° C
    Contact compressor outlet 25 Amp. 250 VAC
    25 Amp Output contact resistances. 250 VAC
    Contact Fans, lighting and perimeter heater 7 Amp. 250 VAC.
    Connection 110- 220 V 50/60 Hz.
    NTC sensors 02 1.5 mt.
Mar 16, 2016 | Cars & Trucks
PLEASE, I HAVE A WHIRLPOOL DRYER DWSR-ELE-2406026-CV54, THE QUESTION IS HOW MANY PHASE HAVE FOR POWER SUPPLY?
It requires two hot wires measuring 240 volts across them and 120 volts from either of them to the neutral connection. Some people refer to the two 'hots' as 'two-phase' and some refer to it as 'single-phase'. At any rate, you do NOT have three phase requirements with that dryer.
Most of the dryers have a 120volt motor which is why you need two hots and a neutral. To complicate matters, recent changes to the code now require 4 wires on newly constructed structures. Two hots, a neutral AND a bare ground wire.
Mar 05, 2015 | Whirlpool Dryers
Power from electical outlet to power a travel trailer,AC,MW,LIGHTS 110to 220
all trailers use 120 volts a 30 amp cord 3 pronged is wired a hot a neutral and a ground a 50 amp cord 4 pronged is 2 lines of 120 volts but its not 220 volt it has 2 separate 120 volt hot lines a neutral and a ground you should see a dealer to explain for safety
Jun 30, 2013 | Cruiser RV 2013 Fun Finder X X-214WSD
What size wire and how does it hook to thr unit rpkb-036jaz
Look at rating plate on side of unit for Volts, Amps, Watts.
Volts x amps = watts.
If unit is 240Volts, then you need double-pole 240Volt breaker
If unit is 8500 watts at max power, then 8500 watts divided by 240Volts = 35 amps.
What size breaker for 35 amps?
When electricians figure load rating for breakers, they use the 80% rule.
40 amp breaker x 80% = 32 amp safe maximum load for 40 amp breaker. Use 8 gauge wire with 40 amp breaker.
50 amp breaker x 80% = 40 amp safe maximum for 50 amp breaker. I use 6 gauge wire with 50 amp breaker.
60 amp breaker x 80% = 48 amp safe maximum for 60 amp breaker. Again, use 6 gauge wire with 60 amp breaker.
How to connect wires to unit.
First of all, all outdoor HVAC units require power cut off located next to unit.
This lets the mechanic, or service tech turn power off to work on unit, even if the mechanic does not have access to main breaker box.
Next, open unit to see where wires connect.
If unit has wires, then connect both hot wires from 240 breaker to the wires inside unit. Connect bare ground wire to green ground screw.
If unit has terminals. The terminals will be labeled L1 L2. Connect each hot wire from 240Volt breaker to either one of the screw terminals. Then bare ground goes to green ground screw.
Copy following links for basic illustrations connecting wires to terminals, and to breakers, and selecting wire size.
http://waterheatertimer.org/How-to-wire-Tankless-electric-water-heater.html
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Jul 21, 2012 | Rheem R-410A Complete Split System Heat...
Back up generator 240 volt output is off balance?
So there is a problem. Where are you measuring voltage?
Say there is L1 - N - L2. Line1 to Neutral is 120 volts, Line2 to Neutral is also 120 volts, Line1 to Line2 is 240 volts. N or Neutral ( the grounded conductor ) is center tap between line 1 and 2.
With this system, the N wire carries the unbalanced load in amperes .
Now we are talking of L1 and L2 and amperes. When L1 and L2 are conducting 10 amperes each, N carries 0 amperes, Line1 and L2 are balanced. When L1 carries 10 amperes and L2 carries 5 amperes, Line1 N carries 5 amperes, the difference of L1 and L2. This is normal.
When there is a problem with a loose connection on N, there is a resistance and will not carry the unbalanced load normally, the voltages will Chang's under load, the problem will worsen with time, a fire hazard, connected loads may burn up from excessive voltage or not work at all.
Bottom line: Make sure the N line ( white wire ) is tight at every connection and inspect for overheating damage. You may have to open the generator connections panel to check there too.
Aug 06, 2017 | Electrical Supplies
40 amp gfi on hot tub keeps tripping.I have a 50 amp.can I use?
Your hot tub needs GFI protection because it is electrical, and people sit inside water that could be exposed to electric current.
You have a fault to ground that needs to be fixed.
Size 8 wire for 50Amp breaker.
Size 6 if tub is 50-100' feet away
http://waterheatertimer.org/Color-codewire.html
Nov 09, 2010 | Spa Parts Plus GFCI, Circuit Breaker, 40...
When hot is hard to find neutral goldwing gl 1100 inter 1981
You probably need to use a full synthetic motor oil. Use JASO MA certified 10W-40 or 20W-50 . I use Amzoil 20W-50 and it solved the problem of not being able to find neutral in rush hour traffic when the bike gets really hot.
Jul 29, 2010 | 1982 Honda GL 1100 Gold Wing
HAVE A ACR 2000 THAT WONT TURN ON,CHECKED POWER AT BREAKERS AND SWITCH HAVE 120 VOLTS
Please try the following: 1# Turn on the main power switch(ON/OFF) & press 15amp & 3amp circuit breaker at the same time to re-set the breaker.2#With line voltage is present at ''Main'' 15amp circuit breaker,Check connection between circuit breaker & power switch(ON/OFF).3# Verify line viltage is present at the power supply input connectior 44,(Brown=hot,Buue=neutral).4# Check connection between power switch & 15amp circuit breaker.Hope this will help you.
Mar 17, 2010 | Measuring Tools & Sensors
I'm hooking a 50 amp plug to this dryer , i have 4 wires the old 1 has 3 my colors are black, red, white,and green from left to right which way do they go on
Hello. I can assist you. first of all, please do not use a 50 amp plug on a dryer. A dryer requires a 30 amp plug. The plug you are using is for an electric range or oven. The black and the red wires are both hot wires. The white is neutral and the green is ground. read the device it will say LINE and LINE for the hot wires and neutral for neutral. It should have a green screw on it for your ground [green].
Nov 02, 2009 | Dryers
COOK TOP WIRING
 You have Red and Black HOT wires and a Green Neutral - That is 220 volts. From the wall - Black is Normally HOT and White is Neutral. That is 110 volts. If that is a typical household outlet, is will only supply a demand at about 15 amps while running at 110 volts. Your Cooktop will most likely demand somewhere around 50 amps at 220 volts. - Short Answer - You will need to have a 220 volt supply line ran to the cooktop from the breaker. Easy to do but dangerous if you are unfamiliar with high voltage.
Apr 30, 2008 | Jenn-Air JED8430 Electric Cooktop
IDEAL Vol-Con Xl Voltage/Continuity Tester Logo
392 people viewed this question
Top IDEAL Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you an IDEAL Measuring Tool and Sensor Expert? Answer questions, earn points and help others
