Question about Brother MFC-8660DN 5-in-1 Laser Multifunctional Printer
Says paper jam but there is nothing in there
I have a brother mfc 8660dn and it says clear paper jam from scanner. there is nothing in there!! can't get it to clear. what am i missing?
  • Kelly Pye Jan 10, 2008
    no code. just says "clear paper jam from scanner then press stop/exit. I have done this a million times and it still won't clear off. It's about to become gator food.
  • 589 Answers
Can you tell me the jam code (if any), or where it is saying it is jammed?
Posted on Jan 10, 2008
  • brian c
    brian c Jan 10, 2008
    Ha... don't give up just yet. Unfortunately, that seems to be a generic code. I would check in the top feeder for any obstructions / blocked sensors, and inside the machine.
    The term "scanner" is making me thing it's in the top feeder.
    Question, does it have two separate glasses on it? Like a large pane of glass, and then a thin strip?
Paper jam on screen will not reset
To clear the error message Paper Jam after you removed the jammed paper, open and close the scanner cover.
If you still receive the error message, a small piece of paper may be stuck inside your Brother machine.
Refer the below link for the steps to remove any ripped paper remaining inside your Brother machine:
still receive the error message Paper Jam after removed the jammed paper...
Apr 22, 2014 | Brother International Brother MFC-J4510DW
Problems printing to Brother MFC 8660DN printer
Pull the paper tray, likley a small black lever to the left of the roller called the edge actuator is dislodged and hanging down. When in position the actuator should easily push up and appear flat next to the roller.
Dec 09, 2009 | Brother MFC-8660DN All-In-One Laser...
Document jam brother mfc 8460n
you cannot clear this unless there is still a presence of paper inside the machine.
or you can open and close your machine once you are cleared of any paper jammed, be sure not to leave and removed all residual paper in the paper path, the tiny sensor would recognize any sort of this and thus make your machine unoperable.
Jul 25, 2008 | Brother MFC-8460N All-In-One Printer
MFC 8660DN
"MP" means "Manual Paper" Tray. Is paper in the manual paper tray or the main tray?
Jun 03, 2008 | Brother MFC-8660DN 5-in-1 Laser...
Paper jam in brother MFC 240C
Usually small pieces of paper are jammed at the print head area. Lift up the scanner and see if you can find the paper at the print head parking area, clear the paper . If you can't find the paper, remove the scanner cables, then the scanner. You will see 2 screws at the rear and one near the USB connection. Another 3 screws towards the front will remove the front panel. Under the panel remove 4 screws and the two panel harnesses. The is a speaker harness which you must remember to attach back later (most people don't remember to put back). Lift up the top cover and you can see the whole engine. Clear any pieces of paper that might be there.
Apr 20, 2008 | Brother MFC-7220 All-In-One Laser Printer
Document Jam Error Message on Brother MFC-8660DN
I had the same problem with a Brother MFC-8460 and called Brother's support line. The solution that worked for me was to lift the top cover where the sheets of paper go through when you fax. On the right of the black rectangluar piece with grey roller there is a slot in the tray with a black lever inside. The black piece was stuck down inside the slot and had to be popped back out. Once it was out I hit the stop button and it was fixed!!
Mar 03, 2008 | Brother MFC-8660DN 5-in-1 Laser...
Paper jam
try removing the back door where you are supposed to clear a paper jam from, and then replace it. If that does not work try leaving the printer unplugug for a few minutes. If this does not work, try printing a document with the printer, and see if it clears the error then.
Jan 10, 2008 | Brother MFC-8660DN 5-in-1 Laser...
Brother MFC-8660DN 5-in-1 Laser Multifunctional Printer Logo
519 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
