Question about Canon PIXMA MP600 all-In-One InkJet Printer
I have a Pixma MP610. In the course of priting a
I have a Pixma MP610. In the course of prineting a paper sheet I did not want to print started to feed and i jerked it out. Since that event I have been getting a message- The paper is jammed. Clear the paper and press OK. There is no paper in the machine to clear and pressing OK just gets the same message. I have inspected the interior of the printer as much as as possible without disassembling it and make no progress. Can you help me?
Jim Sauter sauterje@gmail.com
  • 62 Answers
  1. Clean all feed wheels and guides with methylated spirits.
  2. Look for any switch or guide that may be bent or out of place. This could have been damaged when a jam was removed.
  3. Look for any small piece of paper or staple that may have lodged in the paper path somewhere.
  4. Ensure the paper is dry. Not stored in a cupboard in the kitchen or the printer is not setup infront of an air vent.
Posted on Nov 17, 2009
My cannon pixma mx360 won't print. The paper gets jammed and it won't print.
Look for a fragment of paper or other foreign object in the paper path. Often feeding a sheet of thin card back through the paper path will push any offending object out. May include insects, paper clips, leaves, rubber bands (the worst), pens and pencils, and of course torn or scrunched paper.
Jan 30, 2017 | Canon PIXMA Office Equipment & Supplies
When printing I keep getting lines on my image, all inks are full???
Step First - Alignment, if refilled cartiridge there is air bubbles, pull out all inks by seperated injections & Reriffle, 3- paper setting - photo paper glossy, high quality, & get approx 150-200 sheets photo prints (mention help canon error help E5) your cartiridge not short still working after it, when colors invariants use only plain paper standard quality setting. pls vote
Jul 25, 2010 | Canon PIXMA MP610 InkJet Printer
Error no paper in cassette, but there IS paper in the cassette
i closed the front facing paper tray flap (where the paper should end up after being printed) and hit print again. for some reason it was able to process that there was paper in the top tray, and proceeded to print. strange.
Apr 17, 2010 | Canon PIXMA MP610 InkJet Printer
My Canon Pixma MP610 printer will not print. It
Possible causes: Empty cartridges or new cartridges with cover strip still on the contacts, plugged printhead, wipe with warm water on paper towel to see if all colors are there, also physicallyclean the black cartridge. Try to print. If not working, use the printhead clean and or prime in the printer's maintenance tab.
Mar 09, 2010 | Office Equipment & Supplies
Will not print text from computer (paper feeds
PGBK cartridge was totally blocked. Deep cleaning did not resolve block. Replaced ink cartridge (large black).
Feb 07, 2010 | Canon PIXMA MP160 All-In-One Printer
Do pixma Mp610 support duplex printing
The MP610 does support duplex printing.
Duplex Printing
The duplex printing function allows you to print data on both sides of a sheet of paper.
The procedure for performing duplex printing is as follows:
Performing automatic duplex printing
You can perform the duplex printing without having to turn over the paper.
1. Open the printer driver setup window, check the Duplex Printing check box, and confirm that Automatic is checked.
2. Select Normal-size Printing (or Fit-to-Page Printing, Scaled Printing or Page Layout Printing) from the Page Layout list.
3. When printing a document that has small margins, click Print Area Setup... and set the print area.
When you perform duplex printing, the print area of the document becomes slightly narrower than usual and the document may not fit on one page.
sub.gifTo print without reducing the page:
Select Use normal-size printing.
sub.gifTo reduce the page slightly during printing:
Select Use reduced printing.
4. Specify Staple Side.
The printer analyzes the Orientation and Page Layout settings, and automatically selects the best staple position. Check the Staple Side setting. If you want to change the setting, select another value from the list.
5. If necessary, click Specify Margin... and set the Margin width.
6. Click OK.
Duplex printing will be started.
Performing duplex printing manually
You can perform the duplex printing manually.
1. Check the Duplex Printing check box and uncheck the Automatic check box on the Page Setup tab.
3. Specify Staple Side.
4. If necessary, click Specify Margin... and set the Margin width.
5. Click OK.
sub.gifIf a media type other than Photo Paper Plus Double Sided is selected for Media Type on the Main tab:
When you execute print, the document will be printed on one side of a sheet of paper. When printing is complete, reload paper according to the displayed message and then click OK. The document will be printed on the opposite side.
sub.gifIf Photo Paper Plus Double Sided is selected for Media Type on the Main tab:
When you execute print, the document will be printed front and back alternately for one sheet at a time. Load the paper according to the displayed messages.
caution.gif Note sub.gifDuplex Printing is unavailable when:
- A media type other than Plain Paper, Photo Paper Plus Double Sided or Hagaki is selected from the Media Type list.
- Poster Printing is selected from the Page Layout list.
sub.gifWhen Booklet Printing is selected from the Page Layout list, Duplex Printing and Staple Side appear grayed out and are unavailable.
sub.gifAfter printing the front page, there is an ink drying wait time before starting to print the back page (Operation stops temporarily). Do not touch the paper during the time. You can change the Ink Drying Wait Time at Custom Settings on the Maintenance tab of the printer driver.
sub.gifWhen you perform the automatic duplex printing for Hagaki, print an address first and then print your message.
refer.gif Tip sub.gifIf you select Photo Paper Plus Double Sided for Media Type on the Main tab, the Duplex Printing check box on the Page Setup tab is not checked automatically. To perform duplex printing, check the Duplex Printing check box.
sub.gifIf the Media Type dialog box appears when performing borderless printing during duplex printing, select Plain Paper or Photo Paper Plus Double Sided.
sub.gifWhen performing the automatic duplex printing, do not use any plain paper smaller than A5. Also, do not select any type of paper other than Plain Paper, Photo Paper Plus Double Sided or Hagaki at Media Type.
sub.gifPhoto Paper Plus Double Sided is highly recommended for printing photographs on both sides of a page.
sub.gifIf the back side of the paper becomes smudged during duplex printing, perform Bottom Plate Cleaning in the Maintenance tab.
Aug 17, 2009 | Canon PIXMA MP610 InkJet Printer
Paper Abrasion
first open the printer option by cliking start -->settings-->printer and fax,right click on canon pixma printer cancel all printings, then off the pring again on it.
Aug 13, 2009 | Canon PIXMA MP610 InkJet Printer
Canon Pixma MP610 custom paper size problem
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Jan 04, 2009 | Canon PIXMA MP610 InkJet Printer
Canon PIXMA MP600 all-In-One InkJet Printer Logo
128 people viewed this question
old marine
old marine
