Question about RCA HD52W56 52" Rear Projection HDTV
Showing picture in three segments
Took my brand new RCA projection Tv out of the box and it only shows the picture in three equal size segments on the screen. thought it was a convergence problem at first , but ran test through the menu to no avail.
  • 1,030 Answers
Test through MENU? explan that please. are there different colors that lead you to idea that is convergence.
Posted on Jan 16, 2008
My RCS HD52W67 is showing three pictures on the screen. I have tried zooming, but it only makes all three pictures larger. I cannot get it to only show one screen. What can I do?
Your TV most likely has a convergence failure. You can get parts and instructions from Here are some of the most common symptoms and example photos of a convergence problem Screen looks 3D Colors don't line up One or more colors can't be adjusted when using the convergence menu. Screen is bowed or warped.
Nov 22, 2012 | RCA HD52W59 HDTV Projection Television
My tv is showing the green light but the screen is still black. what should i do?
If your tv is RCA P52926 then it is rear projection tv that does not have a Lamp inside, this rear projection tv three picture tubes to make picture/ image on front screen.
I disagree with previous expert given info about Lamp in this tv.
Since tv is an old model so it might got problem in deflection circuit or power supply stop working properly that is why tv is not turning On to show you picture.
Local tv repair shop will help you to get it fix.
Aug 10, 2010 | RCA P52926 52" Rear Projection Television
My tv is showing three different pictures in three different colors how do i solve this?
more than likely your having a color wheel issue. check the panel on your tv the color wheel is probably damaged.
Apr 14, 2010 | RCA D52W19 52" Rear Projection Television
Double screen and rainbow like colors
my media player does not play occur eror in error show capture video failed, show no sound device or show input is failed
Feb 27, 2010 | RCA Televison & Video
How to adjust pitcher size
Try this setting and see if it helps: Menu>Picture>Advance Picture Settings>Scan Velocity Modulation (Check mark it) Then the TV will try to auto adjust it's picture size to the source you are using. I noticed it most on ESPN News HD. If you are using a HD cable box, you might be able to use the cable box settings to change the picture size. Sometimes the box is on "Zoom" and it takes the top of heads off.
May 25, 2009 | RCA R52WH76 Television
ok you have convegence problem. i suggest you read "fl231 problems under tips in tricks of my profile. this could be a simple easy inexpensive repair. i believe you can get to it under my profile. if that dont help then let me know i will help you further
Sep 20, 2008 | RCA HD52W59 HDTV Projection Television
Cant get picture on 56' tv from my laptop
connect your s video then using your remote press remote key "input"> your s video is label vid 1 this should get your video flowing
Dec 28, 2007 | RCA HD56W66 56" HDTV
there should only be three colors.. can they be aligned?
Sep 16, 2007 | RCA HD52W59 HDTV Projection Television
RCA HD52W56 52" Rear Projection HDTV Logo
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
