Question about Samsung HL-R6167W 61" HDTV
I have a 61 ' samsung hlr6167w and it has a great picture but when there is black background the spots seem to appear negative like its missing kind of blurry only when it a dark show.
    President:
  • Samsung Master
  • 1,779 Answers
I suspect a Light Engine problem. I would call a service company for that particular problem.
Posted on Nov 17, 2009
White dots on screen
http://www.metacafe.com/watch/yt-XeIOwN1CIp8/samsung_mitsubishi_toshiba_dlp_hd_tv_repair_tips_black_white_dots_on_tv_problems_bad_dlp_chip/
I believe it is the digital projection chip that is beginning to fail. Causing white and black spots to appear. To repair this may cost more than a new tv. If you want to attempt it yourself check out the above link. Hope this helps
Jan 12, 2014 | Samsung Hl61a750 61" LED Powered DLP HDTV
I want to change the desk top picture on my Dell Inspiron Mini . When I right click on the desk top , I do not get the option to personlize. Seems like something is missing. Could you give me some kind of...
Right click on an open spot on the desktop. Select Properties from the drop down menu, select DESKTOP from the tab menu and choose your background from the list
Nov 26, 2010 | Dell Inspiron Mini 10 Notebook
Black spot on screen
Your son turned on the closed captioning text mode. The black box is where it would appear if there were any text. Go into your setup menu and turn off the captioning, or restore the factory presets.
Jul 20, 2009 | InFocus ScreenPlay 61" Rear Projection...
Black and white screen...
The color wheel can cause a black and white picture but not the jumpy or negative look.
Those symptoms are usually caused by the DMD assy which drives the color wheel and is somewhat expensive, most of the time you can purchase the whole Light Engine which includes the DMD assy for the same price.
Mar 20, 2009 | Samsung HLN617W 61" Rear Projection HDTV
Samsung Model HLR6167W
Does the TV appear to be cycling on and off, like its attempting to boot up? Or, does it just not come on at all? Don't miss the lamp door interlock switch. Many Samsung DLPs have tempermental door switches. Try re-installing the door or manually hold the switch in the closed postion and try to power it up. If the lamp comes on and stays lit, you've found your problem.
michtech
Feb 19, 2009 | Samsung HL-R6167W 61" HDTV
I have a SAMSUNG DLP model HLR6167w with a problem. I just changed the light hoping this would fix the problem. When the problem first occurred, I could barely make out the picture, and it was very green...
You need to do an aggressive reset on the TV. This solved problem completely for me. You must unplug the TV when it is on. Repeat this several times until the TV is jolted back into the factory default settings. The issue is actually with the programming I believe. The clue was that the display worked 100% perfect in HDMI mode, and the problem only existed in the cable setting, no matter if wires were attached or not.
Again, do an aggressive reset to the TV by unplugging it several times while it is on. It may not register the reset at first because after all, the actual problem is a programming issue and it's having trouble recognizing commands in the first place.
Good luck!!
Jun 18, 2008 | Samsung HL-R6167W 61" HDTV
No picture, but it does have sound. HLN617W
This sounds similar to the same problem I had with my TV. I went out and purchased a new light thinking it was the source of the problem, but I was wrong. It turns out the color wheel and fan went bad and it cost roughly $575.00 for the parts and labor to fix it. My tv was the hlr6167w
Feb 24, 2008 | Samsung HLN617W 61" Rear Projection HDTV
Display images missing on MP3, background black!
You can set one of your own pictures as the background by viewing it and holding down the center touch pad button. The bottom of the screen will say Set Wallpaper and you can let go of the button. now that picture will be set as your background image
Jan 16, 2007 | Samsung Yepp YP-Z5AB / YP-Z5AS MP3 Player
Samsung HL-R6167W 61" HDTV Logo
138 people viewed this question
Jerry Greenberg
Jerry Greenberg
