Question about Kenwood Car Audio & Video
I have a kenwood kvt 719 were does the reverse sensor wire go to? or does it even need to go hooked up?
How to start wire in a kenwood kvt-719 dvd deck
Posted on Nov 23, 2009
Kenwood KVT-617DVD - Rear Camera Option Not Working
Since "...everything else is working..." indicates that there is no blown fuse or chances are nor any hardware is at fault.
When the battery was disconnected, the Kenwood KVT-617DVD may have suffered a memory failure and would require a reset.
Have you tried doing a reset? It's a small recessed button near the bottom right side of the font panel underneath the protection panel (right of the Joystick Track/Station Key & above the Eject Disc Key). Pressing the reset button should restore the Kenwood KVT-617DVD to default factory settings. Of course this will also remove any special programming that you may have such as favorite stations, etc.
You also posted "...Parking brake requirement...bypassed..." this is only to allow the display to be always ON. This is the green wire that must be grounded
You need also to check that the "Reverse" wire/trigger is also bypassed that is to set the "...camera...full time...rear view mirror and back-up monitor for the truck camper..." This is the pink wire that must be attached to the ACC of the vehicle's Ignition Switch. Alternately, it may be connected to the red wire of the Kenwood KVT-617DVD.
If the reset does not correct the problem, you may need to run the setup menu again following the user's manual. Should you need a copy, it is available on line here. Pls verify that you set R-Cam Interruption to ON & R-Cam Mirror to Reverse. This is better explained with appropriate illustrations in page 69 of the User's Manual.
Hope that this be of some help/idea. Pls post back how things turned out or should you need additional information.
Good luck and kind regards.
Dec 10, 2007 | Kenwood KVT-617DVD Car DVD Player
I loking for a brain for kenwood kvt-719 in dash only brain an wires
i have the brain and wires for the exact model i had it a month before someone ripped the screen out of the reciver.. it still plays cds and radio so i know the rest is fine i have all of the wires and harnesses.. 200$
jk2184.jk@gmail.com
Apr 13, 2010 | Kenwood KVT-719DVD 7 in. Car Monitor
Kenwood kvt-719 in dash
partstore.com
110.95
part # TDF-719DVD
Mar 02, 2009 | Kenwood Car Audio & Video
Kenwood kvt 815
I NEED HELP TO UNLOCK A KENWOOD KVT 815 PLEASE HELP THANKS CHARLES
Jun 24, 2008 | Car Audio & Video
I cant getta dvd picture on my kenwood kvt 719dvd...brake wire???
Did you install it, they generally sense whether youre moving by having a connection to your handbrake, if this is not connected the unit thinks youre moving but usually gives an on screen message.
To disable this you usually have to ground the brake sensor wire( connect it to the body of the vehicle)
YOU TRY THIS AT YOUR OWN RISK!!!!!!!!!!!!!!!!!!!!!!!!!!
Apr 24, 2008 | Kenwood KVT-719DVD 7 in. Car Monitor
How can I watch the backup camera when the car is in drive
unfortunately this model does not work unless the emergency brake is applied or if it is in reverse
Mar 30, 2008 | Kenwood KVT-617DVD Car DVD Player
Kenwood kvt m700 help
Bu the sounds of it, you will only need to enter the mask code if the memory wire becomes disconnected, so I would assume that you have your power(red) and memory/constant 12v backword, or both hooked up to the power wire
Feb 17, 2008 | Kenwood KVT-M700 Car DVD Player
Car Audio & Video Logo
197 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
