Question about Kenwood KDC-MPV619 CD Player
When I Hook up the head unit and turn on power, It ask for the security code. I entered it but it will not go to regular settings.
  • 106 Answers
Look in the book for a reset button or method
Posted on Nov 17, 2009
How do you put in the code for a kenwood kdc-4022 head unit
1:-Select SOURCE Select ALL OFF
2:-Press MENU for 1 second, When "menu" is displayed "security"/"SECURITY" is displayed
3:-Press the [<<] or [>>] for one second. When "ENTER" is displayed "CODE" is displayed
4:-Select the digits to enter by pressing [<<] or [>>] button.
5:-Select the security code numbers by pressing [am] or [fm] button.
Repeat steps 4 & 5 to complete the code.
7:- Confirm the code by pressing [>>] for at least 3 seconds
When "RE-ENTER" is displayed "CODE" is displayed.
Go through steps 4,5,6,&7 again to re-enter the code and "APPROVED" should now be displayed? The security code activates?
Press the re-set button and remove from power source Turn ON go through steps 4,5,6,&7 to enter CODE and "APPROVED"" should be displayed.
Crikey need a beer now, Happy tunes, have a good drive.
Regards, Dave
Mar 20, 2011 | Kenwood KDC-4022 CD Player
How to reset security code on panasonic cd player CQ-VD7003U
ID-CODE
ID Code Setting
Prior to operating this unit, it is advisable to assign a 4-
digit ID code for security. Once the ID code has been set,
the unit cannot be operated if the main power supply is
disconnected then re-connected. It is electronically locked
so that a thief cannot use the stolen unit unless that person
knows the code you have set.
The ID code operation must be performed only by the
person to whom the unit belongs.
Generally, it is not necessary to enter the ID code each
time when using the unit if it has not been disconnected
from the main power supply (car battery).
to 4 digits numeric code
default: none
How to set your ID code (for the first time)
q Enter an 4 digit ID code.
w Enter the same 4 digit ID code again.
How to change your ID code
q Enter the preset (old) 4 digit ID code. If the wrong ID
code is entered, a new ID code cannot be registered.
w Enter a new 4 digit ID code.
e Enter the new 4 digit ID code again.
How to cancel the known ID code
code is entered, it is not possible to cancel the ID code
function.
w Touch and hold until "COMPLETED!" is displayed.
The ID code canceling procedure is completed.
The unit now works without an ID code.
Note:
¡Should your unit ever require service, cancel your ID
code before sending for repair.
¡The ID code setting cannot be eliminated even by the
memory clear function.
¡The inputted code is not displayed for your security.
0 9
Caution
¡Record your registered ID code and keep it in a
secure location. (Fill in the ID code memo (a
page 46).) If you forget it, you will be unable to use
the unit. In case you forget the ID code, please
consult your nearest Panasonic Service Center.
Dec 09, 2010 | Panasonic CQ-VD7003U Car DVD Player
When i power on my mobile that asks security code?
If you haven't changed the code, enter 12345 and press ok, that should work. You might have turned on the security from the security settings. If you don't like being asked next time, go to settings, security and turn off the security. Don't try with any other security except the phone security.
If you have problem, let me know. Good luck.
Thanks for using FixYa.
Sep 17, 2010 | Nokia 6070 Cellular Phone
I forgot my pin and I need to unlock it
You have to go to the orig location you programmed your number. It uses the coordinates of that location in memory as a "Home" See below.
The Garmin Lock is a theft-deterrent system that locks your nuvi. Each time you turn the on the nuvi, you would have to enter the PIN or drive to the security location.
To set the Garmin Lock on the device:
  1. From the Main Menu, touch the Wrench (Tools) icon.
  2. Touch Settings.
  3. Touch Security. (you may need to touch the down arrow button)
  4. Touch the tab labeled Off next to the Garmin Lock heading.
  5. The nuvi will prompt you to enter a four-digit pin number.
  6. Enter a four-digit code as your pin.
  7. Re-enter the four-digit pin.
  8. Go to a 'Security Location' and let the unit acquire satellites (the security location will unlock the unit if the pin is forgotten or lost).
  9. Set the 'Security Location' by touching Set.
The Garmin Lock has now been turned On.
Dec 25, 2009 | Garmin nuvi 260W GPS Receiver
How to turn off security code on nokia 1661?
When you power up the phone if it asks for a security code and you haven't set it up previously to use a security code, power it down and up 2 or 3 more times, then enter 12345 which is the default security code for this phone. I don't know why you need to cycle the power several times. However, it you don't do the power cycling, the default security code often doesn't work. I hope this helps you out.
Dec 24, 2009 | Nokia 1661 Cell Phone
How can i restart or change the code on a kdc-mp435u kenwood
there is a small button just to the right and under the control knob. Push and hold this button in standby mode. That will reset the unit. Once the unit is reset, you will need to set all of your other settings as well as the security code.
Once reset, press the SRC display until you are in standby mode. Now Press Enter. Code set should be displayed. using the control knob (Up, down left and right) set the security code. The unit will ask you to confirm this. Once you enter it twice, the unit will read "APPROVED." Now you can set your filters and other settings and enjoy!
Nov 28, 2009 | Kenwood KDC-MP435U CD Player
I lost my l6 password
dont worry if you have lost your unlock code.
you can use the security code in place of the unlock code.
what you need to do is just press the Menu button (the "-" button just above the ) when it asks you to enter the unlock code.
now it asks you for the security code. if you have not set the security code, just enter 6 zeros. (000000).
if you have changed the security code, just enter it.
now you can set a new unlock code even you dont know rhe old unlock code.
go to settings --> go to security--> goto New Passwords-->select unlock code..
it asks you to enter the old code, just press the menu button, it asks you for the security code, enter it, now enter a new UNLOCK code of 4 Digit.
Hope this helps..
Nov 14, 2009 | Motorola Mobility L6 Cellular Phone
I recieve a garmin as a gift @ it now has a code lock on it how can i unlock my garmin 260
The Garmin Lock is a theft-deterrent system that locks your nuvi. Each time you turn the on the nuvi, you would have to enter the PIN or drive to the security location. (where it was orig programmed)
  2. Touch Settings.
Nov 08, 2009 | Garmin nuvi 260W GPS Receiver
When I turn on my kenwood car stereo it says enter
this is the security setting that is pretty much on all kenwood head units. you could talk to kenwood about this and see if they can help. if you dont have the code you're stuffed
Jul 31, 2009 | Kenwood Car Audio & Video
Kenwood KDC-322
Common Kenwood Security Codes
Many Kenwood radios are configured with the same security codes:
KCAR - This seems to be a "backdoor" to some Kenwood models.
3051 - This is the security code which is printed in the manual of many Kenwood models.
1234 - This is a security code commonly chosen by Kenwood owners.
Entering Your Kenwood Security Code
If the car battery fails or is disconnected, the Kenwood will ask for the security code.
The procedure to enter your security code differs on various models of Kenwood car stereos. Here are three of the more common procedures:
Type 1
During the code request mode, while holding the DISP key depressed, press and hold the Volume UP or DOWN key for 3 seconds until the "..." display disappears.
Enter the security code using your Kenwood remote.
Type 2
Press the "Auto" button and "Track up" on the face of radio at the same time until the four dash lines disappear.
Type 3: Model# DPX-4020 and DPX-4030
Press and hold the 1 then the 6 preset keys until the display shows the letter 'C'.
Entering Letters on your Kenwood Remote
To enter a letter using your Kenwood remote, press a button once for the first letter, twice for the second letter, and three times for the third letter -- then press the Track Up or Next Track key to send the letter.
To send the letter 'A', press the 2 key once and then press the Track Up key. To send the letter 'B', press the 2 key twice and then press the Track up key.
Finally, when you are done entering all of the letters, press and hold the Track Up button for 3 seconds.
The key sequence to enter the security code KCAR is:
5
5
Track Up
Track Up
Track Up
7
7
Track Up
Your Kenwood should then enter tuner mode.
A Security Code Bug in some Kenwoods
There is a reported bug in the security code handling of some Kenwood stereos. In models with thie bug, the security code is stored incorrectly. The workaround is to enter the wrong security code.
In models with this bug, you have to decrement the third character of the security code by one. If your security code was 1111, you would enter your security code as 1101. If your security code was 9999, you would enter 9989.
May 27, 2009 | Kenwood KDC-322 CD Player
Kenwood KDC-MPV619 CD Player Logo
152 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
