Question about Acer AL1916W 19" LCD Monitor
My Monitor Colors are wrong
When I hit reset, the color is perfect for just a second, then all colors get darker. I've tried reset and auto, and have even tried every user config (rgb) I can change all to no avail... Any clue how to get it to behave?
  • 1 more comment
  • Anonymous May 22, 2008
    I have the same problem! Can somebody help us??
  • DCDW Jun 09, 2008
    I have the same issue. When watching a movie and the scene is dark the color almost seem to go into a "negative" view like you see in film (black is almost silver). But pressing the Auto button makes the color perfect while in its "setting up configuration" which lasts a few seconds. I've tried just about everything with the brightness/contrast/whatever else and no luck duplicating.
  • necreto Feb 13, 2009
    I have the same problem. When I hit the contrast button, it arrives at it numbers 88. When it reaches 90, the monitor is black and recommences to clarear up to 100. But it is not more clearly. As if the auto-adjustment lost the beginning. It has a form of reset this control ??? Thank for help.
I have the same problem first I think change the cable I buy one nothing happen, and than install the driver for monitor and problem persist only I see correct color went press auto or reset maybe the configuration is no save in the memory how I can fix that...
Thank.ss
Posted on May 07, 2008
    Champion:
  • 238 Answers
Do u mean that whatever settings you do does not stay in the memory..??let me know
Posted on Jan 10, 2008
My monitor gives 16-bit color at 640x480, but will only offer 256 colors at 1024x768 -- and only displays 16 colors when I select that... In order to access resolution options, I have to go into Advanced...
The monitor has no influence here - something is wrong with your video card: either its driver is missing (or corrupted) or the video chip has failed.
Uninstall all the drivers for the video(except the generic VGA one), from Programs and Device Manager
http://pcsupport.about.com/od/windows7/f/open-device-manager-windows-7.htm
and reboot several times then go to Dell
http://support.dell.com/support/downloads/index.aspx?c=us&cs=19&l=en&s=dhs
select your pc and get the correct driver.
If that doesn't fixes it then the video chip has failed, you will need to buy a new video card.
Aug 02, 2011 | Dell Dimension 4600 PC Desktop
I have a 1440x900 21" soyo monitor SHAKING!!!
please boot on the safe mode. you can adjust it there on its default settings.
Mar 05, 2010 | Soyo DYLM1788 Monitor
Color is pale
Reset colors,back to factory setting.Colors will be alot darker in ,can turn down colors after reset.
Jan 10, 2010 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
Cant figure out color issue with computer.
Well...it's a Dell and even when it's well...it's still a Dell.
Have you tried the monitor on different system to eliminate the tower being the problem? Some have updated and/or rolled back drivers to help cure this problem, which seems to be a common issue with this LCD. Personally i think the contrast ratio is inadequate.
Good luck with your Delllll...
May 14, 2009 | Dell E176FP 17" LCD Monitor
Screen colour not matching the printed pages
Unfortunately that's the age old problem of matching colors between computers and printers. Your printer is probably not the problem, that's why he couldn't fix it. Even though your monitor is set to default values it doesn't mean that your colors are correct as colors can vary from monitor to monitor and the color temperature is probably too high causing the colors to look lighter than the printout. The picture on the monitor may look good to you, but it's not set right for matching printer colors. Monitors use RGB (Red, Green & Blue colors) colors and printers use CYMK (Cyan, Yellow, Magenta & Black) colors and you have to make them get the results you want. You will have to do some tweaking of your monitor's settings to get it to match the printer output. Below are some links that will help explain things better and maybe help you adjust your monitor.
http://www.colorwiki.com/wiki/How_To_Get_My_Monitor_To_Match_My_Printer
http://answers.yahoo.com/question/index;_ylt=AjWgmLYL.EGyC5z6hTuiEILty6IX;_ylv=3?qid=20090405191851AAl0xOq&show=7#profile-info-R3GCvDlKaa
http://www.hex2bit.com/products/product_mcw.asp
Feb 28, 2009 | HP LaserJet 3600dn Printer
ViewSonic VX2235wm working fine on old computer, wrong on new
especially the old drivers. If you didnt remove them then you will have issues.
Dec 19, 2008 | ViewSonic VX2235WM Monitor
Not true color
I seem to have found the solution (and the cause, perhaps?) for this problem!
I was having the EXACT same problem with a monitor I'm repairing for a friend. The capacitors on the power supply board were blown (CapXon capacitors, who'd've guessed), which was keeping it from powering up. After replacing the capacitors, the screen worked beautifully. But it had this weird yellow tint!
The strange part was that pure colors - red, green, blue - all appeared perfectly OK on screen. Curiously, the menus would show in the proper colors, except for one: the manual color adjustment menu, which illustrated "Blue" as a sort of off-green in the icon. Auto-Adjust would always fix the colors for a split second, then go back to yellow. Reset didn't fix it. Color reset didn't either. So, exactly the same problem as above.
The solution I found was hidden within the main menu itself, a sort of "easter egg". <b>Hold the Menu button down while pressing Power, and hold it down until the screen, and menu, appear</b>. There will now be a hidden selection, "Auto Color", printed in a red-on-black font at the bottom of the menu. Use the +/- buttons to access it, and press Menu. Voila! PERFECT COLOR! Perhaps this menu was accessed by accident, and calibrated to an incorrect color key. But now my picture works great, and the setting lasts through Auto-Adjusts and Resets!
Hope this helps some people, it sure saved my ****! ;)
Jul 25, 2008 | AOpen 19" LCD
Colors are off after auto adjust
Dec 05, 2007 | AOpen 19" LCD
Colors in QL-711V shifted to green
Hi, I had the same problem and I wrote an email to Nu. They wrote me back that I should use the Factory reset feature which you have to go through the Factory Menu to get to. Instructions to do this are as follows. I got to the menu my first try but it has been a pain to get back to it. I hope it will be easier to access for yours.
Hope this helps
-Nate
Page 1
You will need to display a gray scale picture which varys from black to white
You will need to display a gray scale picture which varys from black to white. Displaymate 16 grays pattern is good or something like the picture to the right. 1 Press and hold SEL/AUTO and press the power button. Then release the SEL/AUTO button. 2 Press the MENU key to display the factory menu. Sencore 11 gray Pattern 3 Press the and select FACTORY2 menu. Factory2 is at the bottom. Press SEL/AUTO to select the FACTORY2 menu. 4 Press the to select AUTO COLOR. 5 Press the to run AUTO COLOR. Wait until finished. You will see the colors changing and then become stable when finished. About 10 seconds. 6 Press the and select COLOR UPDATE. 7 Press the to run COLOR UPDATE. It will finish quickly. < 1second. 8 Press MENU to exit the menu. Power off/on.
Nov 05, 2007 | NuTech QL-711V 17" Flat Panel LCD Monitor
Acer AL1916W 19" LCD Monitor Logo
371 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
