Question about RCA Audio Players & Recorders
Only three speakers work not all 6 RT2870 Home theather centr.
  • 3 Answers
Need to change the surround mode
Posted on Dec 29, 2009
Subwoofer not working
The subwoofer is normally the main power supply for the other speakers. When setting up the system, there is a set up guide which allows you to control the power supplied to each speaker. You may have inadvertently set the subwoofer to have 0 output.
Nov 10, 2013 | RCA RT2870 Theater System
How to connect the RT2870 to the pre amp out ?
Since the RT2870 doesn't have and preamp outs, to WHAT are you referring?
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/RCA-RT2870-Home-Theater-Systems-manual/id/23608dj493/t/2/
Any external device that provides a fixed or variable (preout) Line Level signal could feed either of the RCA
Mar 30, 2011 | RCA RT2870 Theater System
I have a problem with my samsung ht-up30 home theather system. When i turn it on it only shows "PROTECTION" and turns itself off right after that. How to fix it? Regards!!!
The amplifier has a bad channel, or is bad itself. It is trying to either output too much current or is not putting out enough. If you have multiple speakers wired to one channel, you will either have to change the wiring to series(unit positive to first speaker red, first red to second BLACK, second red to unit negative) or remove on speaker. (If this is the case, then you might want to look at this. It is a tip/rick to place and properly/successfully run three subwoofers, but the main concept can be used on all channels.) If all channels are wired to he correct speaker, then the amp is in fact at fault.
Jun 22, 2010 | Samsung HT-X20 Home Cinema 600W Theater...
I need more treble
It looks like there are no user controls for tone.
The User Manual says:
Fine Setting of the Speakers
All the basic settings have already been pre-set for the speakers included in the box.
May 29, 2010 | RCA RT2870 Theater System
5.1 channel home theather
place the speakers at the prescribed angles with the base tube in the centre to get 5.1 sound system fixed.
Dec 03, 2009 | Cars & Trucks
When I turn my unit on, it will turn itself off in a few second.
have you checked to see if any of your speakers are shorted out? the rt2870does have a self protection system in place such that if theres too much power being drawn from the system or if a short occurs it will shut off. or the switch that powers the sub may have gone bad so try disconnecting the sub and see if that helps. i have the same system and i had the same problem and i had to replace the onboard sub-woofer power switch.
Mar 15, 2009 | Audio Players & Recorders
Left surround channel don't work
the problem you have seems to be on programing the master effects to get to it go to main menu and see the distribution and effects you want to hear on you home theather.remember that home surround needs some decoders to send the sound where the images come and its right built in....
Nov 17, 2008 | Denon AVR-887
75 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
