Question about Kenmore 20.3 cu. ft. / 575 liter Upright Freezer 23024
I came home from work and the alarm was going off on the freezer, i unloaded the food and discovered that the dial in the back of the frezer was turn all the way to the left i then turned it all the way to the right is this dial like an on and off switch
  • Kenmore Master
  • 43,501 Answers
Yes, it is a temperature control. You will want to turn the dial back to about the center position and then go higher or lower from there. All the way to the right will probably make the freezer try to be colder than you need and ice cream may be impossible to dip for instance. Also if you are running colder than you need to be the freezer will use much more energy. If you have a thermometer that you can stick in there go for around 0 degrees F
Posted on Nov 17, 2009
My high temp alarm has been on all day
the warming up will be because the unit is not operational and the door hasn't been opened
call a service technician and check for a failed start/run capacitor for the compressor
the high temp alarm indicates that the food is in danger of spoiling
Sep 06, 2015 | Frigidaire White Frost Free Upright...
Temp Alarm going off and not very cold inside.
I think you should see if the circulation fan is working inside. Sometimes they need a little push and some WD 40 let me know. I might have another idea. The Raz Shack
Apr 20, 2010 | Kenmore 20.3 cu. ft. / 575 liter Upright...
Freezer defrost cycle
If the defrost timer sticks in the defrost mode,yes. Normal defrost time is 30 minutes or less depending upon which timer is installed.
If it happens again,locate the defrost timer and turn the dial manually to see if the compressor comes back on. If so,replace the timer.
It is probably on the rear near the compressor. Some are under the front behind the dust guard.
Feb 24, 2010 | Frigidaire 20 cu. ft. / 566 liter Upright...
Can't get alarm to turn off while temperature stabilizes
My wife solved it for me :-) You turn the alarm off with a switch at the bottom. The alarm turns off, but the light stays red for another 4 hours. After that the red light goes off too, and you can turn the switch back on without the alarm going off, if the freezer is back to operating temp.
Aug 06, 2009 | Frigidaire Upright Freezer FFU12F2H
I just moved into a home with a kenmore chest freezer. This is a real dumb question, but which symbol means on. Should the circle be showing for "on" or should the line be showing for "on"?
Some freezer models feature a temperature
monitor that provides an audible
alarm. The temperature monitor alarm is
located near the temperature control
The alarm sounds if the temperature in
the freezer rises 10° F (12° C) or more
above normal for selected setting. Alarm
may sound if temperature control dial is
turned to a much colder setting or if a
large amount of unfrozen food is added at
one time. Alarm is controlled by a three
position switch
0 = OFF prevents alarm from sounding
when freezer is warm, such as during
initial start-up or defrosting.
• ✓ = TEST sounds alarm regardless of
temperature. Alarm system should be
tested at least once a month.
1 = ON is proper setting for normal
freezer use. Return switch to 1 after
defrosting.
Jul 07, 2009 | Kenmore Freezers
Running non stop!
Sadly these old freezers use way too much electricity. You will be better off junking this one and purchasing a good used or brand new one.
Apr 02, 2009 | Kenmore 22.7 cu. ft. / 643 liter Chest...
Freezer compressor runs steady & getting -30F
You probably have a defective thermostat or sensor for reading the temperature.
Mar 23, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
The fridge on my fridge freezer has stopped
just about all friges work off the frezer .the evap fan moves the air fromthe frezer to the frig.so you would here fan noise.i dont know your brand but on most frezers if you turn the frezer temp to the highest setting thats acomplished by keeping the air from going to the frige.hence warmer frig temps .also make sure fan on out side back is working and condenser is clean.again turn air damper control from frezer to frige to lowest setting .somthimes this could be in frig section.God bless ,tom
Jan 01, 2009 | Freezers
Kenmore Upright Freezer Model 253.9239780 Temp alarm, Temp rising slowly
you have a refrigeration issue partner let her go 16 yrs. is good service you can replace it for 3 to 5 hundred the repair will be that IF you can find someone with the r-12. don't go for a top it off and go deal the food you lose is to expensive for that to be economical.
Mar 22, 2008 | Kenmore 20.3 cu. ft. / 575 liter Upright...
BEKO FRIDGE FREEZER
The best way is open freezer door wait 30 seconds then shut if the door pulls shut further then machine is working if not not working.
Thanks J
Dec 23, 2007 | Freezers
Kenmore 20.3 cu. ft. / 575 liter Upright Freezer 23024 Logo
272 people viewed this question
Top Kenmore Freezers Experts
Charles T Nevin
Charles T Nevin
christian nielsen
Dan Webster
Dan Webster
Are you a Kenmore Freezer Expert? Answer questions, earn points and help others
