Question about GE Wireless Optical Mouse
Will not connect - GE Wireless Optical Mouse
    Sergeant:
  • 194 Answers
Usb mouse can be plug and play...try to detect the hardware through device manager and scan hardware changes
Posted on Nov 17, 2009
Connected with limited connectivity
Go to your local area connection from Control panel>Network and internet connection>Network connection.There choose the property of your local area connection.
In property,uncheck the option Notify me when this connection has limited or no connectivity.And choose OK button.Now you have done.Now disable and enable local area connection from network connection.You will seenotification saying acquiring network address and connected.The error of limited area connectivity will never disturb you again.
Resource : http://www.ehowportal.com/fix-limited-connectivity-laptops-wireless/
Apr 26, 2012 | Computers & Internet
Wii says needs update in order to connect with Wii Store which would allow me to download NetFlix Ap. It is connected to the net but I keep getting error message that says update could not go through. It...
Hi there!
There are two ways to connect your Wii to the internet; you can connect to your wireless network (if you have a wireless modem set up in your house), or you can connect using a wired connection directly to your modem.
If using a wired connection, you will need to purchase a Wii LAN adapter and connect that from your WII into your wired router.
Once you have figured out what connection type you will use (and if using a wired connection, purchased and connected your Wii LAN adapter) you will need to take the following steps:
FOR WIRELESS CONNECTION:
  • Turn on your Wii and click on the "Wii" button on the bottom left of the screen
  • Click on "Wii Settings"
  • Click on the arrow on the right side of the screen and select "Internet"
  • Select "Connection 1 : none" (if you don't see "None" in Connection 1, click the Connection 1 button, then choose "Clear Settings")
  • Click on "Wireless Connection" and then "Search for an Access Point"
  • Select "OK" and the Wii will display all the wireless networks it finds.
  • Select the wireless network that is yours.
  • If it asks you to enter a password or key, then your wireless connection is password protected and you will need to enter the password that was setup to allow access to your network.
  • Select "OK," "Save Settings," and then "Yes."
  • Your Wii will test the connection and you should get a message saying connection was successful.
FOR WIRED CONNECTIONS:
  • Connect your Wii to the Wii LAN adapter and connect that to your modem or broadband adapter. Please not that you will need to unplug your modem for a few minutes to reset the connection and you will also need to unplug the connection to your computer when you want to connect your Wii to the internet.
  • Turn on your Wii and select the Wii icon on the bottom left
  • Click the arrow on the right side of the screen and select "Internet"
  • Click "Connection Settings"
  • Click "Connection 1 : none" (if you don't see "None" in Connection 1, click the Connection 1 button, then choose "Clear Settings")
  • Click "Wired Connection"
  • Click "Ok"
  • Your Wii will now do a connection test
  • You should see a message saying the test was successful
Hope this helps!
Jul 06, 2011 | Nintendo Wii Console
I have S5350 model mobile, how can i transfer photos from mobile to my laptop?
Try to connect it in bluetooth connection. (Wireless connection.). Or try to connect your phone in USB connection. (Wired connection) For wireless connection:
-open your first your bluetooth connection. (phone and laptop) -send the the files/photos via bluetooth connection. -accept the files from your laptop.
For wired connection: -connect your usb to your phone -set your phone connection to mass storage -connect to your laptop, if your laptop detect your phone, search your files, then copy it.. =)
May 21, 2011 | Cameras
[CS Raw] Connecting to connection server port '5050'... [FAILED] *** 'COMPONENT_TYPE_YCP' YCPError: 'FND.0203' ***
Solve this problem
Checking connection servers...
*** 'COMPONENT_TYPE_YCP_EX' YCP EX Error: ('FND.0210', 0, 0) ***
[CS Raw] Connecting to connection server port '80'... [PASSED]
[CS Raw] Sending port check command... [FAILED]
*** 'COMPONENT_TYPE_YCP' YCPError: 'FND.0000' ***
[CS Raw] Connecting to connection server port '23'... [FAILED]
[CS Raw] FAILED
*** 'COMPONENT_TYPE_YCP' YCPError: 'PortSelector::AllPortsFailed' ***
Dec 08, 2010 | Yahoo Messenger
How do i connect dial up connection
If you want to connect your pc/laptop with a dial-up connection you need to make a dial up connection but you didn't mention your operating system.But no problem just go to control panel and there you find network connections in it you notice a create a new connection then new wizard will open press next then select which ever connection you want make then it ask how to connect to internet in it choose set up connection manually press next then choose appropriate option then its done. Your connection is just made up try to connect and you internet will start working.
Nov 19, 2010 | Acer Aspire One PC Notebook
Cant connect to wireless away from home
You have to manually connect to your University's wireless connection. Double 9maybe single) click the wireless icon bottom right screen and then untick the box for connect automatically under your home connection. Then double click on the wireless connection that you would like to connect to from the list of available wireless networks.
Jan 31, 2010 | Advent Netbook
Instructions how to connect ps3 to internet
THERE 2 MANY WAYS YOU CAN CONNECT THE PS3 TO INTERNET:
1) WIRED CONNECTION
2) WIRELESS CONNECTION
1) WIRED CONNECTION
JUST CONNECT THE ADSL WIRE TO THE PS3. GO TO NETWORK SETTINGS AND CREATE A CONNECTION. THEN TEST CONNECTION.
2) WIRELESS CONNECTION ( THE BEST WAY TO CONNECT TO THE INTERNET)
IF YOU HAVE A WIRELESS ROUTER YOU CAN CONNECT YOUR PS3 TO THE INTERNET. GO TO NETWORK SETTINGS AND CREATE A CONNECTION. THEN TEST CONNECTION.
Jul 11, 2009 | Sony PlayStation Portable (PSP) Console
Can't connect to 3Com Office connect wireless from Apple Mac Pro
PPPoE connection is set up
1. Control Panel, double-click Network Connections. 2. Click the PPPoE connection under the Broadband group that you want to share, and then click Change settings of this connection under Network Tasks. 3. On the Advanced tab, click to select the Allow other network users to connect through this computer's Internet connection check box. 4. PPPoE connections behave in a similar way as do dial-up networking (DUN) connections, and you may want the connection to be automatically dialed when another computer on your network attempts to connect to the Internet. To do this, click to select the Establish a dial-up connection whenever a computer on my network attempts to access the Internet check box. 5. If you want to allow other network users to enable or disable the shared Internet connection, click to select the Allow other network users to control or disable the shared Internet connection check box. 6. Under Internet Connection Sharing, in Home networking connection, click the LAN (Local Area Network) connection that connects the computer that is sharing its PPPoE Internet connection to the other computers on your network.
Feb 07, 2008 | 3Com OfficeConnect Wireless 11g Cable/DSL...
Wont connect to the internet
Try this, assuming you're using Internet Explorer: Go to Tools > Internet Options and select the Connections tab. Does it show your old dial-up connection in the list? If so highlight it and click on REMOVE. Close IE and re-open it. It should now use the Belkin LAN connection.
Aug 18, 2007 | Belkin (F5D7231UK4) Wireless Router
GE Wireless Optical Mouse Logo
174 people viewed this question
Top GE Computers & Internet Experts
micky dee
mukhtar21 shaikh
mukhtar21 shaikh
Ricky Ostrom
Ricky Ostrom
Are you a GE Computer and Internet Expert? Answer questions, earn points and help others
